查看: 853|回复: 4
[编程申请]:等差、等比阵列!
发表于 2006-1-8 13:14:07 | 显示全部楼层 |阅读模式
请问怎么在cad里面实现同一个方向的等差或者等比阵列呢?
就是多条直线临近两条直线的间距在x方向等差或等比变化的!
高手请帮帮我,十万火急啊!
已领礼包: 12490个
发表于 2006-1-8 16:20:48 | 显示全部楼层
编程思路:循环执行拷贝命令
 楼主| 发表于 2006-1-9 12:52:46 | 显示全部楼层
编程不怎么会使用,不好意思哈 !!!
你们能不能编一个呢?
多谢le !!!
已领礼包: 12490个
发表于 2006-1-9 23:49:11 | 显示全部楼层
[php]
;等差/等比阵列。晓东 zxq0220
(DEFUN C:TEST ()
(SETVAR "CMDECHO" 0)
(SETQ OLDOS (GETVAR "OSMODE"))
(SETVAR "OSMODE" 0)
(SETQ PP (GETINT "\n阵列方式 (<1=等差>,2=等比) :")
       PP (IF PP PP 1)
       NUM (GETDIST (IF (= PP 1) "\n等差值 :" "\n等比值 :")))
(WHILE (SETQ SS (SSGET))
  (SETQ P1 (GETPOINT "\nFirst Point 第一点 :")
        P2 (GETPOINT P1 "\nSecond Point 第二点:")
        DS (DISTANCE P1 P2)
        AN (ANGLE P1 P2)
        NN (GETINT "\nNumber of Entity 阵列数量 <2> :")
        NN (IF NN NN 2) I 1)
  (REPEAT (1- NN)
   (COND
    ((= I 1) (COMMAND "COPY" SS "" P1 P2))
    ((= PP 1) (COMMAND "COPY" SS "" P1 (SETQ P2 (POLAR P2 AN (+ (* (1- I) NUM) DS)))))
    (T      (COMMAND "COPY" SS "" P1 (SETQ P2 (POLAR P2 AN (* (EXPT NUM (1- I)) DS)))))
   (SETQ I (1+ I))
(SETVAR "OSMODE" OLDOS)
(SETVAR "CMDECHO" 1)
(PRINC)
[/php]
 楼主| 发表于 2006-1-10 00:32:14 | 显示全部楼层
感谢万分!!!
GMT+8, 2026-11-5 16:25 , Processed in 0.456297 second(s), 40 queries , Gzip On.
