查看: 941|回复: 4
[求助] [求助]:如何将指定目录下的文件插入到文件中?
发表于 2006-2-14 17:23:21 | 显示全部楼层 |阅读模式
如何将指定目录下的文件插入到文件中?
发表于 2006-2-14 18:58:53 | 显示全部楼层
(defun c:fileddinsert (/ file dir FILE-J N I)
  (setq file (getfiled "" "" "dwg" 4))
  (if (= file nil)
    (exit)
    (progn
      (setq dir (vl-filename-directory file))
      (SETQ FILE-J (vl-directory-files DIR "*.DWG"))
      (SETQ I 0)
      (SETQ N (LENGTH FILE-J))
      (REPEAT N
          (SETQ FILE (NTH  I FILE-J))
          (SETQ FILE (STRCAT DIR "\\" FILE))
          (COMMAND "-INSERT" FILE '(0 0) 1 1 0)
          (SETQ I (1+ I))
发表于 2006-2-14 20:41:38 | 显示全部楼层
  1. [FONT=courier new](defun c:test (/ file dir filelst )
  2.   (if (setq file (getfiled "" "" "dwg" 4))
  3.     (progn
  4.       (setq dir            (vl-filename-directory file)
  5.             filelst (vl-directory-files dir "*.DWG")
  6.       )
  7.       (foreach n filelst
  8.         (COMMAND "-INSERT" (strcat dir "\" n) '(0 0) 1 1 0)
  9.       )
  10.     )
  11.   )
  12.   (command "zoom" "e")
  13.   (princ)
  14. )[/FONT]
 楼主| 发表于 2006-2-15 09:04:02 | 显示全部楼层
谢谢两位,不知如何在加入文件时同时设定比例,最还同DCL文件一起使用?
发表于 2006-2-15 12:36:07 | 显示全部楼层
  1. [FONT=courier new](load "xyp_lib.vlx")  ;版本 V.20060211(2064)
  2. ;|下载和加载通用函数(可在签名栏直接下载后放到搜索路径下)
  3. 利用以下任何一种方式(首选第一种)即可加载和运行通用函数内的所有子程序:
  4. ★1·在acad.lsp中增加(load"xyp_lib.vlx")
  5. ■2·在每个程序内增加(load"xyp_lib.vlx")
  6. ■3·在command下,输入(load"xyp_lib.vlx")
  7. ■4·在菜单.mnl中增加(load"xyp_lib.vlx")
  8. ■5·将xyp_lib.vlx文件直接拽到cad屏幕
  9. [COLOR=red] ★通用函数下载地址:[/COLOR]
  10. [url]http://www.xdcad.net/forum/attachment.php?s=&postid=1606661[/url]
  11. |;
  12. (defun c:test (/ file dir filelst )
  13.   (cmdla0)
  14.   (if (null sca )(setq sca 1))
  15.   (setq sca (UREAL 7 "" "\n设定比例" sca))
  16.   (if (setq file (getfiled "" "" "dwg" 4))
  17.     (progn
  18.       (setq dir            (vl-filename-directory file)
  19.             filelst (vl-directory-files dir "*.DWG")
  20.       )
  21.       (foreach n filelst
  22.         (COMMAND "-INSERT" (strcat dir "\" n) '(0 0) sca sca 0)
  23.       )
  24.     )
  25.   )
  26.   (command "zoom" "e")
  27.   (cmdla1)
  28. )[/FONT]
GMT+8, 2026-11-7 00:50 , Processed in 0.448291 second(s), 40 queries , Gzip On.
