查看: 777|回复: 3
[求助] [求助]:如此倒角标注?
发表于 2006-2-15 09:36:52 | 显示全部楼层 |阅读模式
能否用VLISP实现如此的倒角标注?
已领礼包: 12483个
发表于 2006-2-15 10:26:43 | 显示全部楼层
写了一个,不知是否满足楼主的要求。
[php]
(DEFUN C:DCORNER ()
(SETVAR "CMDECHO" 0)
(SETQ OLDOS (GETVAR "OSMODE"))
(SETQ DL (ENTGET (CAR (ENTSEL "\nPlease Select a Line 请选择一条直线 :"))))
(WHILE (/= (CDR (ASSOC 0 DL)) "LINE")
  (PRINC "\nError!")
(SETQ P1 (CDR (ASSOC 10 DL))
       P2 (CDR (ASSOC 11 DL))
       X (ABS (- (CAR P1) (CAR P2)))
       Y (ABS (- (CADR P1) (CADR P2))))
(SETVAR "OSMODE" 0)
(IF (EQUAL X Y 1E-4) (PROGN
  (SETVAR "SNAPANG" (ANGLE P1 P2))
  (SETVAR "ORTHOMODE" 1)
  (SETQ PT1 (POLAR P1 (ANGLE P1 P2) (/ (DISTANCE P1 P2) 2))
        PT2 (GETPOINT PT1 "\n标注方向 :")
        PT2 (POLAR PT1 (ANGLE PT1 PT2) (/ X (SQRT 2.0))))
  (COMMAND "DIMALIGNED" PT1 PT2 PAUSE)
(SETVAR "SNAPANG" 0)
(SETVAR "OSMODE" OLDOS)
(SETVAR "CMDECHO" 1)
(PRINC)
[/php]
 楼主| 发表于 2006-2-15 10:48:15 | 显示全部楼层
谢谢zxq0220!我试试zxq0220  你有QQ号吗?
发表于 2006-2-15 13:13:09 | 显示全部楼层
没有倒角的功能!
GMT+8, 2026-11-3 11:16 , Processed in 0.567246 second(s), 39 queries , Gzip On.
