查看: 1516|回复: 4
[求助]:如何向setWindowPos传递点坐标
发表于 2002-5-9 01:19:14 | 显示全部楼层 |阅读模式
请问高手:
    我想实现在CAD中当鼠标放开时,对话框弹出,且左上角为鼠标处。鼠标放开返回AcGePoint3d,如何向setWindowPos传递点坐标。
发表于 2002-5-9 01:49:04 | 显示全部楼层
// 1: 获得DCS下鼠标 Mouse coords
  CPoint cPnt (pMsg->lParam) ;
  acedCoordFromPixelToWorld (cPnt, cpt) ;
去OBJECTARX安装目录:...\ObjectARX\SAMPLES\MFCSAMPS\PRETRANSLATE可以看到下面代码:
  1. [FONT=courier new]
  2. BOOL filterMouse(MSG *pMsg)
  3. {
  4. if( pMsg->message == WM_MOUSEMOVE )
  5. {
  6.   acedDwgPoint cpt;
  7.   ads_point ptDCS, ptWCS, norm;
  8.   AcGePoint3d  origin;
  9.   AcGeVector3d e0, e1, e2;
  10.   AcGeMatrix3d  matUcs2Wcs, matWcs2Ucs;
  11.   // 1: Get the Mouse coords in DCS
  12.   CPoint cPnt (pMsg->lParam) ;
  13.   acedCoordFromPixelToWorld (cPnt, cpt) ;
  14.   acdbPointSet ( cpt, ptDCS );
  15.   //acutPrintf ( "\nMouse in Ucs %f, %f, %f",  ptDCS[X], ptDCS[Y],ptDCS[Z] );
  16.    //return FALSE;
  17.   // 2: Transform the Mouse coords from DCS to WCS
  18.   // For this we use the    acdbEcs2Ucs  function with the
  19.   // value of the VIEWDIR system variable as the input normalvector of ECS
  20.   // (Sure we have to transform the VIEWDIR value from UCS to WCS
  21.   struct resbuf rbview;
  22.   acedGetVar( "viewdir", &rbview );
  23.   ads_point_set( rbview.resval.rpoint, norm );
  24.   // If the view direction is 0, 0, 1, then acedCoordFromPixelToWorld()
  25.   // needs special handling -> we only have to translate the thepoint
  26.    // by the distance the origin of the current UCS was moved
  27.   double tol = 1e-10;
  28.   if ((fabs(norm[X]) < tol) && (fabs(norm[Y]) < tol) &&((fabs(norm[Z]) - 1.0) < tol))
  29.   {
  30.    AcGePoint3d acadPt;
  31.    acadPt.x = cpt[0];
  32.    acadPt.y = cpt[1];
  33.    acadPt.z = cpt[2];
  34.    acdbUcsMatrix ( matUcs2Wcs );
  35.    matUcs2Wcs.invert();
  36.    matUcs2Wcs.getCoordSystem( origin, e0, e1, e2);
  37.    acadPt += origin.asVector();
  38.    acutPrintf ( "\nMouse in Ucs %f, %f, %f",  acadPt[X],acadPt[Y], acadPt[Z] );
  39.    return FALSE;
  40.   }
  41.   //transfoming VIEWDIR  to WCS
  42.   acdbUcs2Wcs ( norm, norm, Adesk::kTrue );
  43.   // Transforming the mouse coords from DCS to WCS
  44.   acdbEcs2Wcs( ptDCS, ptWCS, norm, Adesk::kTrue );
  45.   // 3: Get the Mouse coordinates in UCS        //
  46.   // For this we have to project the WCS coordinates to the UCSplane using
  47.   // the VIEWDIR vector as projection direction.        //
  48.   // Getting the UCS->WCS transformation matrix
  49.   acdbUcsMatrix ( matUcs2Wcs );
  50.   matUcs2Wcs.getCoordSystem( origin, e0, e1, e2);
  51.   // Creating a plane which lies on the current UCS
  52.   //
  53.   AcGePlane thePlane ( origin, e0, e1);
  54.   AcGePoint3d  pntMouseInWCS( ptWCS[X], ptWCS[Y], ptWCS[Z] );
  55.   AcGeVector3d vecViewdir( norm [X], norm [Y], norm [Z] );
  56.   // Making the projection
  57.   AcGePoint3d resPnt = pntMouseInWCS.project (thePlane, vecViewdir);
  58.   // Transforming the point coordinates to UCS.
  59.   matWcs2Ucs = matUcs2Wcs.inverse();
  60.   resPnt.transformBy ( matWcs2Ucs );
  61.   //this line prints the same coordinates as the coordinates
  62.   //shown in  AutoCAD's status bar
  63.   acutPrintf ( "\nMouse in Ucs %f, %f, %f",  resPnt[X], resPnt[Y],resPnt[Z] );    }
  64.   return FALSE; // continue
  65. }
  66. NOTE: This doesn't work in perspective view because acedCoordFromPixelToWorld()
  67. doesn't work in perspective view.
  68. [/FONT]
 楼主| 发表于 2002-5-9 06:16:45 | 显示全部楼层
AcGePoint3d p1,p2;
        acedGetPoint(NULL,"\n Select pOINT:",asDblArray(p1));
        ZhouAcEdJig *pJig=new ZhouAcEdJig(p1);
        p2=pJig->doIt();//由鼠标拖动返回点
        delete pJig;
        pDialog=new ZhouDialog(acedGetAcadFrame());
        pDialog->Create(IDD_DIALOG1);
        pDialog->ShowWindow(SW_SHOW);
        pDialog->SetWindowPos(acedGetAcadDockCmdLine(),p2[X],p2[Y] ,0,0,SWP_NOSIZE);
该成以下后还不行
        AcGePoint3d p1,p2;
        CPoint p3;
        CString str;
        acedDwgPoint cpt;
        delete pJig;
        cpt[0]=p2[X],cpt[1]=p2[Y];
        acedCoordFromWorldToPixel(0,cpt,p3);
        str.Format("%g",p2[X]);
        pDialog->m_edit1.SetWindowText(str);
        pDialog->m_edit1.UpdateData();
    str.Format("%g",p3.x);
        pDialog->m_edit2.SetWindowText(str);
        pDialog->m_edit2.UpdateData();
        pDialog->SetWindowPos(acedGetAcadDockCmdLine(),p3.x ,p3.y ,0,0,SWP_NOSIZE);
请帮我想想办法
发表于 2002-5-9 06:26:06 | 显示全部楼层
你要把那个函数定义成HOOK,就能动态监视鼠标的动作了。
 楼主| 发表于 2002-5-9 06:39:59 | 显示全部楼层
我的意思是说:
  p2返回的是wcs坐标,而pDialog->SetWindowPos(acedGetAcadDockCmdLine(),p2[X],p2[Y] ,0,0,SWP_NOSIZE); 显然这样是错误的,需要将p2转换为窗体的坐标,怎么办?
GMT+8, 2026-11-22 10:42 , Processed in 0.253550 second(s), 19 queries , Gzip On, File On.
