查看: 719|回复: 2
[求助]: 乐于助人的高手进
发表于 2006-2-20 21:57:08 | 显示全部楼层 |阅读模式
怎么在VB中获取文本的插入点坐标,并存储
求救,急
发表于 2006-2-21 10:47:03 | 显示全部楼层
Sub TEST()
   Dim sstext As AcadSelectionSet
   Dim FilterType(0) As Integer
   Dim FilterData(0) As Variant
   Dim PT As Variant
   Dim Text As AcadText
   Set sstext = ThisDrawing.SelectionSets.Add("S1")
   FilterType(0) = 0
   FilterData(0) = "TEXT"
   sstext.SelectOnScreen FilterType, FilterData
   For I = 0 To sstext.Count - 1
       Set Text = sstext.Item(0)
       PT = Text.InsertionPoint
       MsgBox "X:" & PT(0) & "Y:" & PT(1) & "Z:" & PT(2)
   Next
   ThisDrawing.SelectionSets.Item("S1").Delete
End Sub
 楼主| 发表于 2006-2-21 16:35:32 | 显示全部楼层
谢谢啊,不胜感激
GMT+8, 2026-11-22 11:38 , Processed in 0.369845 second(s), 14 queries , Gzip On, File On.
