楼主: 前生
[LISP程序]:请大家看看,里面的问题
发表于 2003-5-9 12:27:43 | 显示全部楼层
各位的都太繁琐了! 我曾经编过一个,不过几行. 照来贴上
偏移(更改命令就可以拷贝)多义线pline子段(线段或弧)的小程序
(defun c:test (/ plist pp)
(setq aa (entsel "\nSelect pline:"))
(setq bb (cadr aa))
(setq oo (getdist "\nValue of offset:"))
(vl-cmdf "explode" aa "")
(setq ss (ssget "c" (polar bb (/ pi 4) 0.01)(polar bb (* 1.25 pi) 0.01)))
(vl-cmdf "offset" oo bb (getpoint "\nInput offset point:") "")
(setq dd (entget (entlast)))
(vl-cmdf "undo" 2 "")
(entmake (cdr dd))
);defun
已领礼包: 488个
发表于 2003-5-9 21:28:58 | 显示全部楼层
最初由 zhynt 发布
[B]我看了上面的图片,觉得直线段还行,但是弧线段更象是平移而不是偏移。如图:平移和偏移的区别 [/B]
要offset也简单:
(command "move"..)那一行换成offset,再(entdel f)
今天加了几行字,支持旧pline线,和spline.
现在重贴
  1. (defun c:copypl (/ e ee from to copypl dxf)
  2. (defun dxf(a b)(cdr(assoc a b)))
  3. (prompt "\nBY AEO ,一定要选"*POLYLINE" ")
  4.   (defun copypl (e from to / a b en f is j len li)
  5.     (defun make-pl (ptn / li)
  6.       (setq li (append
  7.                  (list '(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '
  8.                        (100 . "AcDbPolyline") (cons 90 2)
  9.                 )ptn))
  10.       (entmake li)(entlast)
  11.     )
  12.     (setq en (entget e)is (dxf 70 en) li '() )
  13.     (if(= (dxf 0 en)"POLYLINE")
  14.       (progn
  15.        (while (/= "SEQEND"(dxf 0(setq en(entget(setq e(entnext e))))))
  16.         (setq li (cons(list(assoc 10 en)(assoc 40 en)(assoc 41 en)(assoc 42 en)) li))
  17.        )
  18.        ;(setq li(reverse li))
  19.       )
  20.       (progn
  21.        (setq en(member (assoc 10 en) en) li '())
  22.        (while (>= (length en) 4)
  23.         (setq a (list (car en) (cadr en) (caddr en) (cadddr en))
  24.               en (cddddr en)li (cons a li)
  25.         )
  26.        )
  27.     ) )
  28.     (if (= is 1)
  29.       (setq li (reverse (cons (last li) li)))
  30.       (setq li (reverse li))
  31.     )
  32.     (setq a(car li)li(cdr li)j 0 len(length li))
  33.     (while (< j len)
  34.       (setq b (nth j li)
  35.             f (make-pl (append a b))
  36.       )
  37.       (if (vlax-curve-getParamAtPoint (vlax-ename->vla-object f) from)
  38.         (progn(setq j len)(command "move" f "" from to))
  39.         (entdel f)
  40.       )
  41.       (setq j (1+ j) a b)
  42.     )
  43.   )
  44.   (if (and
  45.         (setq ee (entsel"\n选多义线:"))
  46.         (setq e (car ee) from (cadr ee))
  47.         (wcmatch  (dxf 0 (entget e))"*POLYLINE")
  48.         (setq from (vlax-curve-getClosestPointTo
  49.                         (vlax-ename->vla-object e)from
  50.                    )
  51.         )
  52.         (setq to (getpoint from "\nCopy To:"))
  53.       )
  54.     (copypl e from to)
  55.   )
  56.   (princ)
  57. )
已领礼包: 145个
发表于 2003-5-10 00:39:32 | 显示全部楼层
最初由 lsjjm 发布
[B]各位的都太繁琐了! 我曾经编过一个,不过几行. 照来贴上
(setq bb (cadr a... [/B]
构造选择集的时候
  1. (setq ss (ssget "c" (polar bb (/ pi 4) 0.01)(polar bb (* 1.25 pi) 0.01)))
建议不要用具体的数字0.01,这样有可能选不到,因为屏幕有可能画的很大,很小。
建议用当然拾取框的高度代替,通过系统变量 viewsize,screensize,pickbox等等得到拾取框的高度值,这样就可以适合任何屏幕大小了。
另: 你的
  1. (vl-cmdf "offset" oo bb (getpoint "\nInput offset point:") "")
这行是不是有BUG
发表于 2003-5-10 16:06:16 | 显示全部楼层
最初由 aeo 发布
[B]
要offset也简单:
(command "move"..)那一行换成offset,再(entd... [/B]
  1. ...........
  2. (progn
  3.        (while (/= "SEQEND"(dxf 0(setq en(entget(setq e(entnext e))))))
  4.         (setq li (cons(list(assoc 10 en)(assoc 40 en)(assoc 41 en)(assoc 42 en)) li))
  5.        )
  6.       ;;; (setq li(reverse li));;;;;;應取消
  7.       )
  8. ...........
已领礼包: 488个
发表于 2003-5-10 19:22:13 | 显示全部楼层
LUCAS :
是的,
我改掉了
对直线不去掉也对的,以为就对了.
弧就不行了,两个时间写就是不好.
发表于 2004-7-29 15:02:33 | 显示全部楼层
4楼的真好用,但输入这一行命令有点麻烦.
发表于 2004-10-11 16:07:59 | 显示全部楼层
翻个旧贴测试一下:
lsjjm的:拷贝的段位不对?可惜没保留宽度信息.
lucas的,无宽度信息,对pl,lwpl有效
mmmm的:测试时候出错.
xd的:对pl,lwpl有效,保留宽度信息,但是宽度好像有错.我测试的是前后宽度不等的弧段
aeo的:对pl,lwpl有效,操作直观,没有发现其它bug,是测试的程序里面效果最好的.要是改进一下,拷贝出来的时候动态显示.就更完美了.
结论:
推荐使用aeo的程序.
已领礼包: 6530个
发表于 2004-10-11 19:30:48 | 显示全部楼层
江南斑竹最近怎么想起翻旧帖子看了?
我这里也有一个类似的,与本主题同期的(pi.lsp,http://xdcad.net/forum/showthrea ... d=285584#post285584),是支持R14的(没有精力学习VL了),如果有必要以后可以增加对Polyline的支持)。
发表于 2004-10-12 22:31:22 | 显示全部楼层
测了你程序,集成了几个功能,不错:)
拷贝和偏移的时候,步骤多了一些,应该点击线段后,再点一下就可以拷贝或偏移.不用去问输入距离或在哪一边偏移什么的.
还可再改进哦;)
已领礼包: 2个
发表于 2005-11-3 10:30:15 | 显示全部楼层
老外的,參考一下
; Filename    :   CopyPlineSeg.lsp
; Datum       :   23.08.04
; Author      :   jme
; Copyright   :   MENZI ENGINEERING GmbH, Switzerland
; Revision  1 :   19.01.05 jme - Basepoint for copy imroved
;                              - Checking for A2k+ added
; Revision  2 :   __.__.__ ___ -
; Known bugs:
; - None
; Description:
; Copies a segment of a Polyline.
; Global variables:
; Internal LISP-functions:
; MeGetObjLength  MeSelPline
; External LISP-functions:
; Version notes:
; AutoCAD:        Version:        Language:        AddIns:
; 15+                1.01                English                ...
; == Message on loading =======================================================
(princ "\nCopyPlineSeg v1.01")
; == Main =====================================================================
(defun C:CopyPlineSeg ( / BasPnt CpyEnt CpyObj CpySet CurObj CurEnt ObjLen
                          ObjLst OldCmd PicPnt PntDst *Error*)
(if (< (atof (getvar "ACADVER")) 15.0)
  (progn
   (alert "CopyPlineSeg requires AutoCAD 2000 or higher. ")
   (princ)
  (progn
   (vl-load-com)
   (setq OldCmd (getvar "CMDECHO")
         CurEnt (MeSelPline "\nSelect Polyline segment: " T nil)
   (defun *Error* (Msg)
    (setvar "CMDECHO" OldCmd)
    (if Msg (princ Msg))
    (princ)
   (if CurEnt
    (progn
     (setq CurObj (vlax-ename->vla-object (car CurEnt))
           PicPnt (vlax-curve-getClosestPointTo CurObj (cadr CurEnt))
           ObjLst (vlax-invoke CurObj 'Explode)
     (vla-put-Visible CurObj :vlax-false)
     (mapcar 'vla-Update ObjLst)
     (if (setq CpyEnt (nentselp PicPnt))
      (progn
       (vla-put-Visible CurObj :vlax-true)
       (setq CpyObj (vlax-ename->vla-object (car CpyEnt))
             ObjLen (MeGetObjLength CpyObj)
             PntDst (vlax-curve-getDistAtPoint CpyObj PicPnt)
             BasPnt (cond
                     ((<= PntDst (/ ObjLen 3.0))
                      (vlax-curve-getStartPoint CpyObj)
                     ((>= PntDst (/ ObjLen 1.5))
                      (vlax-curve-getEndPoint CpyObj)
                     ((vlax-curve-getPointAtDist CpyObj (/ ObjLen 2.0)))
       (foreach Obj ObjLst
        (if (not (equal Obj CpyObj)) (vla-delete Obj))
       (setvar "CMDECHO" 0)
       (vl-cmdf "_.MOVE" (car CpyEnt) "")
       (setvar "CMDECHO" 1)
       (vl-cmdf BasPnt pause)
   (*Error* nil)
; == Subs =====================================================================
; -- Function MeGetObjLength
; Returns the length of all kind of objects.
; Arguments [Type]:
;   Obj = Object [VLA-OBJECT]
; Return [Type]:
;   > Length of the object [REAL]
; Notes:
;   - Proceedes *Polylines, Splines, Lines, Arcs, Circles and Ellipses
(defun MeGetObjLength (Obj)
(vlax-curve-getDistAtParam Obj (vlax-curve-getEndParam Obj))
; -- Function MeSelPline
; Extended Polyline selection function.
; Arguments [Type]:
;   Pmt = User prompt [STR]
;   3Dp = 3Dpolyline flag (3Dpolyline allowed) [SYM]
;   Cls = Close flag (pline must be closed) [SYM]
; Return [Type]:
;   > List with entity name and pickpoint '((Ename (x y z)) [LIST]
; Notes:
;   - Returns nil when user press 'Return' or 'Space'
(defun MeSelPline (Pmt 3Dp Cls / CurEnt EntFlg EntLst EntNme ExLoop)
(while (not ExLoop)
  (initget " ")
  (setq CurEnt (entsel Pmt))
  (cond
   ((= CurEnt "") (setq ExLoop T CurEnt nil))
   (CurEnt
    (setq EntLst (entget (car CurEnt))
          EntNme (cdr (assoc  0 EntLst))
          EntFlg (cdr (assoc 70 EntLst))
    (cond
     ((or
       (not (member EntNme '("LWPOLYLINE" "POLYLINE")))
       (and (not 3Dp) (= (logand EntFlg  8)  8))
       (= (logand EntFlg 16) 16)
       (= (logand EntFlg 64) 64)
      (princ "selected entity is not a Polyline. ")
     ((and Cls (/= (logand EntFlg 1) 1))
      (princ "selected Polyline is not closed. ")
     ((setq ExLoop T))
   ((princ "1 selected, 0 found. "))
CurEnt
; == Copyright - Note (May be never deleted) ==================================
(princ "\n------------------------------------------------")
(princ "\n ?004-2005 MENZI ENGINEERING GmbH, Switzerland ")
(princ "\nType CopyPlineSeg in the command line to start the programm...")
(princ)
; == End CopyPlineSeg =========================================================
发表于 2014-5-11 12:09:29 | 显示全部楼层
看不太懂,格式很特别,慢慢消化一下吧,长姿势了
发表于 2014-5-16 13:29:55 | 显示全部楼层
虽然不懂,但是帮顶
GMT+8, 2026-11-6 11:13 , Processed in 0.515890 second(s), 48 queries , Gzip On.
