查看: 1292|回复: 6
[求助] [求助]:如何用lisp实现closeall,但是不保存哦?
发表于 2006-3-8 12:15:46 | 显示全部楼层 |阅读模式
如何用lisp实现closeall但是不保存?
又如何实现closeall,保存?
谢谢!
发表于 2006-3-8 13:28:30 | 显示全部楼层
[php](defun c:closeall-no (/ item cur)
  (vlax-for item (vla-get-documents (vlax-get-acad-object))
    (if        (= (vla-get-active item) :vlax-false)
      (vla-close item :vlax-false)
  (command "CLOSE" "y" "")
(defun c:closeall-yes (/ item cur)
      (vla-close item :vlax-true)
  (command "qsave" "" "CLOSE")
[/php]
 楼主| 发表于 2006-3-8 16:00:31 | 显示全部楼层
呵呵,说来真是奇怪,楼上大哥的程序在CAD2006中过得去,但是在CAD2005中却不行?
谢谢了!
发表于 2006-3-9 11:55:53 | 显示全部楼层
麻烦2楼再改进一下吧
发表于 2006-3-9 13:07:32 | 显示全部楼层
看来2006的vl可以跨文档了?
发表于 2006-3-9 13:10:08 | 显示全部楼层
还没有找到解决的办法
已领礼包: 9347个
发表于 2006-3-9 13:59:18 | 显示全部楼层
;;; 全不保存
;;; I believe Frank Whaley posted this originally.
(defun ax:CloseAll ( / item cur)
        (setq cur item)
    ;(vla-sendcommand cur "_.CLOSE ")      ;; 停等 ....
    ;(command "._VBASTMT" "ThisDrawing.Close True")
    (command "._VBASTMT" "ThisDrawing.Close False")
Ref: info
Date:  Mon, May 1 2000 12:00 am
Email:   LEndres <lend...@sesnet.com>
Groups:   autodesk.autocad.customization
I tried to do something like this myself, but there are several problems with it.
First, it doesn't check to see if a command is running in the drawing.  If there is a command running then the vla-close will give an error.  Is there a way to test to see if a command is running and cancel it (can you use (getvar "cmdactive") inside of the vla-for loop and return the cmdactive from the correct document)?
Second, there is a problem when a new drawing has been started but not saved.  I have used the vla-get-fullname property to test for this (as Frank suggested in an earlier post), but I would like to ask the user if they want to save the drawing, and if so, allow for a save as.  I haven't been able to get this to work either.
Third is that the (vla-sendcommand cur "_.CLOSE") seems to be sending the close command to the command line, but not running it.
I have pasted my very pathetic code below.  Perhaps someone can fix this hack job.  Obviously my knowledge of visual lisp is very low!  Thanks for the help.
(defun CLOSE-ALL-OPEN-FILES (/ ACADOBJ ACTDOC ITEM)
    (vl-load-com)
    (setq ACADOBJ (vlax-get-acad-object))
    (vlax-for ITEM (vla-get-documents ACADOBJ)
        (if (not (= ITEM
                    (vla-get-activedocument ACADOBJ)
                 ) ;_ End =
            ) ;_ End not
            (if (and (= (vla-get-fullname ITEM) "")
                     (= (vla-get-saved ITEM) :vlax-false)
                ) ;_ End and
                (CLOSE-UNSAVED-FILE ITEM)
                (progn
                    ;Cancel command if running
                    (vla-close ITEM)
                ) ;_ End progn
            ) ;_ End if
        ) ;_ End if
    ) ;_ End vlax-for
    (setq ACTDOC (vla-get-activedocument ACADOBJ))
    (if (and (= (vla-get-fullname ACTDOC) "")
             (= (vla-get-saved ACTDOC) :vlax-false)
        ) ;_ End and
        (CLOSE-UNSAVED-FILE ACTDOC)
        (progn
            (command "_.close")
            (while (= (logand (getvar "CMDACTIVE") 1) 1)
                (command "y")
            ) ;_ End while
        ) ;_ End progn
    ) ;_ End if
) ;_ End defun
(defun CLOSE-UNSAVED-FILE (ITEM / OPTION)
    (vla-put-activedocument (vlax-get-acad-object) ITEM)
    (initget "Yes No")
    (setq OPTION (getkword "\nSave drawing? [Yes/No] <Yes>: "))
    (if (or (= OPTION "") (= OPTION "Yes"))
        (progn
            (initdia)
            (command
                "_.saveas"
                (while
                       1
                    ) ;_ End =
                       (command
                           PAUSE
                       ) ;_ End command
                ) ;_ End while
            ) ;_ End command
        ) ;_ End progn
    ) ;_ End if
) ;_ End defun
GMT+8, 2026-11-7 01:46 , Processed in 0.407136 second(s), 44 queries , Gzip On.
