查看: 1094|回复: 1
[求助]:请大家帮我分析一下自定义填充图案为何在vb中不能填充?
发表于 2006-3-8 14:28:29 | 显示全部楼层 |阅读模式
Dim hatchObj As AcadHatch '定义填充对象变量
Dim patternName As String '定义图案填充名称
Dim PatternType As Long '定义图案填充类型
Dim bAssociativity As Boolean '定义图案填充与边界是否关联的布尔变量
PatternType = acHatchPatternTypeCustomDefined '使填充类型为自定义的图案填充,在此如果换成acHatchPatternTypepredefined,把下面的b056换成ANSI31,程序则不出错
patternName = "b056" '填充文件名为b056.pat的自定义图案填充文件
bAssociativity = true '关联边界
Set hatchObj = acadapp.ActiveDocument.ModelSpace.AddHatch(PatternType, patternName, bAssociativity)
'创建填充对象
Dim outerLoop(0 To 3) As AcadEntity
Dim innerloop(0 To 3) As AcadEntity
Dim startpoint1(0 To 2) As Double
Dim endpoint1(0 To 2) As Double
Dim startpoint2(0 To 2) As Double
Dim endpoint2(0 To 2) As Double
Dim startpoint3(0 To 2) As Double
Dim endpoint3(0 To 2) As Double
Dim startpoint4(0 To 2) As Double
Dim endpoint4(0 To 2) As Double
Dim pa As Double
startpoint1(0) = -50#: startpoint1(1) = -50#: startpoint1(2) = 0#
endpoint1(0) = 50#: endpoint1(1) = -50#: endpoint1(2) = 0#
startpoint2(0) = 50#: startpoint2(1) = -50#: startpoint2(2) = 0#
endpoint2(0) = 50#: endpoint2(1) = 50#: endpoint2(2) = 0#
startpoint3(0) = 50#: startpoint3(1) = 50#: startpoint3(2) = 0#
endpoint3(0) = -50#: endpoint3(1) = 50#: endpoint3(2) = 0#
startpoint4(0) = -50#: startpoint4(1) = 50#: startpoint4(2) = 0#
endpoint4(0) = -50#: endpoint4(1) = -50#: endpoint4(2) = 0#
'为填充边界四边形定义数组及为其赋值
Set outerLoop(0) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint1, endpoint1)
Set outerLoop(1) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint2, endpoint2)
Set outerLoop(2) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint3, endpoint3)
Set outerLoop(3) = acadapp.ActiveDocument.ModelSpace.AddLine(startpoint4, endpoint4)
'创建填充边界四边形
hatchObj.AppendOuterLoop (outerLoop)
'用自定义库为四边形填充
hatchObj.Evaluate
'用Evaluate方法进行求值,程序在此出错
acadapp.ActiveDocument.Regen acActiveViewport
acadapp.ActiveDocument.SaveAs "c:\wxy.dwg"
acadapp.Application.Visible = True
ZoomExtents
'显示图形
发表于 2006-3-29 12:11:18 | 显示全部楼层
b056.pat文件放置位置对不对?
GMT+8, 2026-11-22 10:45 , Processed in 0.181495 second(s), 10 queries , Gzip On, File On.
