查看: 875|回复: 2
[分享]:Useful Keyins
发表于 2003-5-9 07:02:39 | 显示全部楼层 |阅读模式
VIEW MANIPULATION
OF= Hide view Levels
ON= Display View Levels
RV= Rotate view(s) about centre
WO= Set view origin
SV= Save view
VI= Attach saved view
DV= Delete saved view
DRAWING SETTINGS
AA= Active Angle
AS= Active Scale
XS= Active X Scale
YS= Active Y Scale
ZS= Active Z Scale
GU= Master/Grid
GR= Reference Grid
KY= (Snap) Divisor
UR= (Unit) Distance
ELEMENT ATTRIBUTES
LV= Active Level
CO= Active Colour
LC= Active Line Style
WT= Active Line Weight
PRECISION INPUT
XY=<x,y,z> From origin along design file axes
DI= <distance, direction> From last data or tentative relative to view axes
DL=<Ax, Ay, Az> >From last data or tentative in design co-ordinates
DX=<Ax, Ay, Az> >From last data or tentative in view co-ordinates
AX= From ACS origin
AD= Difference from last data or tentative in ACS co-ordinates
3D MODELING
DP= Display Depth
DD= Distance to move Display Depth
AZ= Active Depth
DZ= Distance to move Active Depth
SX= Save ACS
RX= Attach ACS
PX= Delete ACS
CELLS
AC= Set Active Cell and select Place Active Cell tool with Relative off
AR= Set Active Cell and select Place Active Cell tool with Relative o
CM= Place Active Cell Matrix tool
PT= Active Point
LT= Active Terminator
TS= Terminator Scale
CR= Edit cell information
CD= Delete cell from cell library
CC= Create cell
TEXT & DIMENSIONING
FT= Active Font
DF= View fonts
TH= Active Height
TW= Active Width
TX= Active Height and Width
LL= Active Line Length
LS= Active Line Spacing
TB= Tab spacing for importing text
TI= Tag Increment
LD= Dimension Level
TV= Upper and Lower dimension tolerance limits
DATABASE
AE= define Active Entity
DA= displayable attribute type
DB= attach control file
DS= specify fence filter
FI= set database row as Active Entity
RA= set attribute review selection criteria
RS= name report table
PATTERNING
AP= Active Pattern Cell
PA= Active Pattern Angle
PD= Active Pattern Spacing
PS= Active Pattern Scale
DIGITISING
SD= Active Stream Delta
ST= Active Stream Tolerance
File Management
RD= Open design file
XD= Open design file with active design's view configuration
RC= Attach cell library
RF= Attach Reference File tool
DR= File menu/Display > Text&hellip;
CT= Attach colour table
AM= Attach and activate menu
AT= Activate tutorial
USER COMMAND
UC= Activate user command
UCC= Compile user command
UCI= User command index
OX= Retrieve user command index
OTHER
EL= Create element list file
FF= Copy fence contents to new design file
GO= Global Origin
SF= Move fence contents to new design file
发表于 2003-5-9 08:38:19 | 显示全部楼层
很好,不知从哪儿能找到有关的资料?
 楼主| 发表于 2003-5-10 23:53:05 | 显示全部楼层
小东空间的链接网站上,在国外网站上,有很多,我也是初学者,希望大家共同探讨。
GMT+8, 2026-11-22 10:40 , Processed in 0.331619 second(s), 14 queries , Gzip On, File On.
