查看: 1031|回复: 2
[下载]:根据图层得到它的颜色号
发表于 2006-3-20 20:13:12 | 显示全部楼层 |阅读模式
如果知道了某一层的名称  (assoc 8 s)
怎样得到某一层的颜色号
发表于 2006-3-20 20:20:32 | 显示全部楼层
  1. [FONT=courier new];;;取得物体的颜色(含随层)
  2. (defun XYP-GET-COLOR (ename / col)
  3.   (if (or (= (vla-get-color (vla-obj ename)) 256)
  4.           (= (vla-get-color (vla-obj ename)) 0)
  5.       )
  6.     (progn
  7.       (setq laname (dxf 8 (entget ename))
  8.             la1           (tblnext "layer" t)
  9.             la           (dxf 2 la1)
  10.       )
  11.       (while (/= la laname)
  12.         (setq la1 (tblnext "layer" nil)
  13.               la  (dxf 2 la1)
  14.         )
  15.       )
  16.       (setq col (dxf 62 la1))
  17.     )
  18.     (setq col (dxf 62 (entget ename)))
  19.   )
  20.   col
  21. )[/FONT]
发表于 2006-3-20 21:16:23 | 显示全部楼层
[php]
(defun get-color ()
  (setq        AcadObject   (vlax-get-acad-object)
        AcadDocument (vla-get-ActiveDocument AcadObject)
  (setq util (vla-get-utility AcadDocument))
  (setq Layers (vla-get-Layers AcadDocument))
  (vla-getentity util 'obj 'ip "\n选择一个物体: ")
  (setq color (vla-get-color obj))
  (if (= color 256)
    (progn
      (setq lay (vla-get-layer obj))
      (setq lay (vla-item layers lay))
      (setq color (vla-get-colorindex (vla-get-truecolor lay)))
  (princ "\n 当前所选物体的颜色号为:")
  (princ color)
  (princ)
)[/php]
GMT+8, 2026-11-7 01:32 , Processed in 0.407219 second(s), 36 queries , Gzip On.
