楼主: zshutang
[公告]:用过PDS的请进。
发表于 2003-6-14 05:19:19 | 显示全部楼层
大伙等得口水都流光了。
不过如此好的东东,一切都是值得的。
无论结果如何,都非常感谢CADDESIGN和FPSO所付出的努力。
发表于 2003-6-14 06:38:14 | 显示全部楼层
PDS,  做梦都想你呀!
别吊我胃口了,快!
Rebis Autoplant  早玩腻了。
谢谢CADDDESIGN 和FPSO!
发表于 2003-6-14 10:58:26 | 显示全部楼层
各位兄弟, 再不要给我发短信了,因为好像有问题,有好几个短信我无法接受, 显示有短信,但到信箱里却没有短信,奇怪,请管理员检查一下吧.
发表于 2003-6-15 05:07:26 | 显示全部楼层
fpso大哥:
忍不住还是问一下:可以了吗?
请PM我或EMAIL:aliker@sina.com
Thanks
 楼主| 发表于 2003-6-15 10:01:50 | 显示全部楼层
大家不要着急,FPSO兄台正在测试,也是为大家好。
发表于 2003-6-17 18:00:34 | 显示全部楼层
大家不用多费劲了。有时间学学PDMS把。因为pds没有单机版,必须有服务器才能用阿。但是pdms就可以单机版使用。
发表于 2003-6-17 20:26:20 | 显示全部楼层
真的? 真鬼兄能否提供PDMS让大伙学一学?
发表于 2003-6-17 21:14:47 | 显示全部楼层
realghost兄:
好象你对PDS和PDMS都有所了解,趁大家在无聊等待的日子里,给大家讲讲这两个家伙,如何?
发表于 2003-6-17 22:46:17 | 显示全部楼层
smartplant是不是配置项目时也和其他的三维工厂软件一样繁琐
发表于 2003-6-17 22:50:08 | 显示全部楼层
是的,
发表于 2003-6-18 23:21:34 | 显示全部楼层
兄弟们,的确如此,我安装SMARTPLANT时, 必须安装SQL的附件, 而且安装文件巨大,对硬件的要求也苛刻,大家先看看硬件要求吧:
System Requirements
IMPORTANT: You must install the product on a clean machine, which
refers to a fresh installation of Windows(R) 2000 and required
prerequisites. Avoid loading legacy or other products not related
to SmartPlant 3D before loading and testing SmartPlant 3D.
- 500 MHz Pentium(R) II processor, or higher, recommended
- Minimum of 256 MB memory for each workstation
- Minimum of 512 MB memory for server
- Minimum of 519 MB hard drive disk space on the drive where SmartPlant 3D
  Workstation is installed
- Minimum of 530 MB hard drive disk space on the drive where SmartPlant 3D
  Workstation with Project Management is installed
- Minimum of 484 MB hard drive disk space on the drive where SmartPlant 3D
  Administrator is installed
- Minimum of 112 MB hard drive disk space on the drive where SmartPlant 3D
  SQL Server Data is installed
- 36 MB of additional free hard drive disk space, plus the minimum space
  required for Microsoft Office 2000, on the drive where the operating system is
  installed, when SmartPlant 3D Workstation is installed
- 586 MB of additional free hard drive disk space, plus the minimum space
  installed, when SmartPlant 3D Administrator is installed
- 100Mbit or better network with 100Mbit or better NICs in each machine
- Minimum of 1 GB hard drive disk space on the drive where the SQL server
  databases are created
- Access to a CD-ROM drive or network drive
- 21" color monitor, recommended
- Graphics cards designed for 3D intensive applications that generate low CPU
  overhead and meet the following requirements:
  - 32-bit main RGBA pixel buffer
  - Hardware OpenGL 1.1 support
  - Hardware Z buffer: 32-bit
  - 64 MB RAM recommended, 32 MB RAM minimum
  - 4-bit minimum overlay buffer support
  - 8-bit stencil buffer
  - Hardware Alpha blending support
  - Hardware Anti-aliasing support recommended
  - Note on performance:    Many of the recent generation video cards
    provide some level of OpenGL acceleration. Some manufacturers provide poor
    OpenGL drivers that can cause artifacts. Testing has shown that NVIDIA and
    Intense3D provide good drivers. ATI and Matrox often seem to have OpenGL
    problems with their drivers. Cards with double-buffered overlay planes
    (such as the Wildcat cards) have an advantage because highlighting can be
    done without having to do save/restores. Cards without overlay planes rely
    on blits during highlight operations, so good blit performance is needed,
    as well as good drivers. For example the NVIDIA Geforce 2 graphics card
    had unacceptable performance with its initial drivers, but since the
    release of the Detonator 3 drivers, the Geforce 2 card has shown good
    performance while running SP3D.
  - Note on Dual Screen Configuration: Dual Screen configurations should have
    either a single graphics card with two VGA outputs or two identical
    graphics cards.  The graphics card(s) should otherwise meet the
    requirements of the specified graphics card recommendations.
End of System Requirements
发表于 2003-6-19 00:39:59 | 显示全部楼层
怎么办? 我只有一台电脑。
难道我真的与PDS这么无缘?
唉!
FPSO兄,快想办法。
 楼主| 发表于 2003-6-19 06:59:45 | 显示全部楼层
不会吧,这第惨忍,不知道FPSO兄对BENTELY公司的PLANTSPACE是否了解,听说全球全球管道软件除了PDS,PDMS,第三位就是PLANTSPACE。相对来说PLANTSPACE比较容易一些,对硬件要求也较低。
发表于 2003-6-19 09:14:38 | 显示全部楼层
哇,看来要和PDS紧密接触还要狠下一翻苦功。
要赚点钱升级部分硬件了。
安装要求好象有点太苛刻。难怪FPSO兄测试了这么久。
发表于 2003-6-21 07:12:47 | 显示全部楼层
pds 中的各个子系统有自己的lisence, 可以各自在单机上运行。(需要MS/J 7.0) 如果要用pds的lisence ,则可把自己设成服务器。同样可以用.
GMT+8, 2026-11-22 09:52 , Processed in 0.532524 second(s), 35 queries , Gzip On, File On.
