查看: 524|回复: 0
[下载]:ARRIS 9.0.106 (建筑设计师设计):
发表于 2006-4-18 12:39:43 | 显示全部楼层 |阅读模式
Arris是一款建筑设计师设计软件。运用CAD技术设计、分析以及建模,是建筑设计师的最好设计工具。以下是对它主模块ARRIS CAD的简介:
ARRIS CAD is the centerpiece of the ARRIS family of application solutions. This application incorporates all the drafting and management tools needed to handle architectural projects of any size or complexity.
> Easier to use than standard CAD systems
> Productivity focus on architecture and building
> Designed for user speed and convenience.
> Everything you need for automating your design and drawing production process.
> Easily generate both simple and complex structures
> Simultaneously share drawings with project team members over networks
下载地址:http://www.9iv.com/down/soft/867.htm?eid=267022
GMT+8, 2026-11-3 10:49 , Processed in 0.471318 second(s), 33 queries , Gzip On.
