查看: 796|回复: 0
[求助]:ADO 將EXCEL 檔案寫到AS400 問題
发表于 2006-5-4 14:25:04 | 显示全部楼层 |阅读模式
目前 我更改 後如下
可是卻在
但卻在   myRS.AddNew   '新增紀錄 -----------------------這邊出現
執行階段錯誤 3251
目前的資料集不支援更新.這可能成為提供者或所選擇所定類型的限制
可是 我試過用其他鎖定 都不可以
請問 這要如何設定
Dim myCon As ADODB.Connection  '
    Dim myRS As ADODB.Recordset    '
    Dim xlsRow As Integer 'EXCEL 開始匯入欄位
    Set myCon = New ADODB.Connection
    myCon.Open "Provider=IBMDA400.DataSource.1;Persist Security Info=False;Data Source=192.168.1.2 "  '400  CONNECTION
    Set myRS = New ADODB.Recordset   '產生recordset
    myRS.Open Source:="WW.whcd", ActiveConnection:=myCon, CursorType:=adOpenStatic, LockType:=adLockBatchOptimistic, [B]Options:=adCmdTable[/B]
    xlsRow = 2 'EXCEL 從第2行開始
    'On Error GoTo Tran_err2  '攔截錯誤
    myCon.BeginTrans    '開始交易處裡
       With ThisWorkbook.Sheets("temp")
            Debug.Print .Cells(xlsRow, 3).Value
            Do Until .Cells(xlsRow, 3).Value = " " '當第3欄 P#為空白,時停止 寫入
                myRS.AddNew   '新增紀錄 ----------------------出現-有問題
           ' WHVM    CUNR    CPNR    SHTO    HDLB    CRDV    CRTV    MEM1
                myRS![WHVM] = .Cells(xlsRow, 1).Value
                myRS![cunr] = .Cells(xlsRow, 2).Value
                myRS![cpnr] = .Cells(xlsRow, 3).Value
                myRS![shto] = .Cells(xlsRow, 4).Value
                myRS![HDLB] = .Cells(xlsRow, 5).Value
                myRS![CRDV] = .Cells(xlsRow, 6).Value
                myRS![CRTV] = .Cells(xlsRow, 7).Value
                myRS![MEM1] = .Cells(xlsRow, 8).Value
                myRS.Update '實際並不會寫入到DB
                xlsRow = xlsRow + 1
                If xlsRow Mod 100 = 3 Then
                    myCon.CommitTrans  '反應開始
                    myCon.BeginTrans   '開始進行交易處理
                End If
            Loop
        End With
    myCon.CommitTrans   '寫入剩餘的變更
    myRS.Close
    Set myRS = Nothing
    myCon.Close
    Set myCon = Notning
    MsgBox xlsRow - 1 & "以寫入DB"
    Exit Function
Tran_err2:
    myINT = Int((xlsRow - 3) / 100) * 100
    MsgBox "第 " & xlsRow & "發生錯誤 .  目前已經寫入 " & myINT & " 記錄了 ."
    myCon.RollbackTrans  '丟棄錯誤錯誤產生之變更單位
    Set myCmd = Nothing
    myCon.Close
    Set myCon = Nothing
GMT+8, 2026-11-22 11:30 , Processed in 0.325564 second(s), 10 queries , Gzip On, File On.
