楼主: lixuedong
[求助]:提取文字中的数字
发表于 2007-8-5 14:13:48 | 显示全部楼层
所有的数字都被抽出来放在一个表里面了
(defun dyq-get-number (str / num i numlist key1 key2 stri) ;获得文字中的数字
  (setq num (strlen str))
  (setq i 1)
  (setq numlist '())
  (setq        key1 0
        key2 0
  (repeat num
    (setq stri (ascii (substr str i 1))) ;转成ascii码
    (if        (and (= key2 0)
             (or (= stri 46) (and (>= stri 48) (<= stri 57)))
        ) ;如果是数字,并且是第一次碰到
      (setq key1 i ;起始
            key2 i
    (if        (and (> key2 0)
        ) ;如果是数字,并且不是第一次碰到
      (setq key2 i) ;起始
    (if        (and (> key2 0)
             (and (/= stri 46) (or (< stri 48) (> stri 57)))
        ) ;如果不是数字了
      (setq numlist (cons (atof (substr str key1 (- key2 key1 -1))) numlist) ;将数字存起来
            key2    0
      ) ;起始
    (setq i (+ i 1))
  (if (> key2 0)
    (setq numlist (cons (atof (substr str key1 (- key2 key1 -1))) numlist))
  ) ;将数字存起来
  (reverse numlist)
发表于 2007-8-9 18:51:53 | 显示全部楼层
也不是太明白哦
已领礼包: 2个
发表于 2007-8-11 09:20:05 | 显示全部楼层
看看是不是你所要
  1.   [FONT=courier new]
  2. (defun txt5-nump-nump (str / nump subs)
  3.   (setq subs (substr str 2))
  4.   (cond
  5.     ((and
  6.        (= (substr str 1 1) ".")
  7.        (not (vl-string-position (ascii ".") subs))
  8.        (not (vl-string-position (ascii "+") subs))
  9.        (not (vl-string-position (ascii "-") subs))
  10.      )
  11.       (setq nump (numberp (read subs)))
  12.     )
  13.     ((and
  14.        (or
  15.          (= (substr str 1 1) "+")
  16.          (= (substr str 1 1) "-")
  17.        )
  18.        (= (substr str 2 1) ".")
  19.        (not (vl-string-position (ascii ".") (substr str 3)))
  20.      )
  21.       (setq nump (numberp (read (substr str 3))))
  22.     )
  23.     ((/= (vl-string-position (ascii ".") str) (vl-string-position
  24.        (ascii ".")
  25.        str nil t
  26.                                               )
  27.      )
  28.       (setq nump nil)
  29.     )
  30.     ((or
  31.        (vl-string-position (ascii "+") subs)
  32.        (vl-string-position (ascii "-") subs)
  33.      )
  34.       (setq nump nil)
  35.     )
  36.     (t
  37.       (setq nump (numberp (read str)))
  38.     )
  39.   )
  40.   nump
  41. )
  42.   [/FONT]
发表于 2007-8-13 00:14:30 | 显示全部楼层
这个估计比较难吧
发表于 2007-8-15 18:36:06 | 显示全部楼层
·提取字符串内数字1:
(setq str "a-.3A0.0+9.5d-1.3 1.2e-58d4d-15.1d5.6asf-1.2"
       pat "[+|-]?\\d*\\.?\\d+(e[+|-]*\\d+)*")
(xxexp  pat str "")
;;返回:("-.3" "0.0" "+9.5" "-1.3" "1.2e-58" "4" "-15.1" "5.6" "-1.2")
;;下面再验证是否是数字.
   (mapcar 'distof (xxexp  pat str ""))
   ;;返回:(-0.3 0.0 9.5 -1.3 1.2e-058 4.0 -15.1 5.6 -1.2)
函数下载:
http://dreamskylxx.ys168.com/
  1. 在lisp中应用正则表达式
  2. [序]
  3.    长久以来,文本的编辑一直是lisp编程的重点、难点之一,有不少活跃在xdcad和明经通道论坛的高手为此写了不少有代表性的文字处理工具,比较知名的如:   。而我自己也写过不少这方面的程序,多数没有发表,少数零星地发布在以上两个论坛。但由于lisp对文本编辑(*注)的支持函数不够丰富,而实际工作中遇到的情况又多种多样,使得诸多lisp程序对文本编辑的深度和灵活性上还有很多不足之处,不免遗憾。
  4.    为此,我一直以来寻求更好的方法,最终只有一个答案:正则表达式。正则表达式对文本编辑很强,有多强?看看vb或vbs参考就知道,也可上网一搜。但是,也许本人孤陋寡闻(或是有的高手潜水潜得很深),在网上一直没有见过在lisp中比较充分地应用正则表达式的程序。其实,我很早就想将正则表达式移植到lisp里面来,近几日一鼓作气,终有小成。谨奉献两个函数:(xxexp)(xxexpr),这两个函数提供了正则表达式的接口,使在lisp中得以应用其强大的功能成为可能。
  5.                                                         ―――――梁雄啸.2007.7
  6.
  7. [*注:“文本”在本文均指对文本字符串内容,非指文本实体(0 . “*TEXT”)]
  8. 函数下载:
  9. [url]http://dreamskylxx.ys168.com/[/url]
  10. [函数介绍]
  11. 函数:(xxexp pat str key)
  12. 功能 对字符串进行正则表达式匹配测试.
  13. 参数: pat = 正则表达式模式 ,对应vbs正则表达式的模式(expression)。说明: \ 号要用 \\ 替代.
  14.      str = 字符串
  15.      key = "i" "g" "m" , "i"不区分大小写(Ignorecase),"g"全局匹配(Global).”m”多行模式(Multiline),以上几个关键字可以组合使用,或用 ””.
  16. 返回: 返回匹配的字符列表,或无一匹配返回nil
  17. 函数:(xxexpr pat str nstr key)
  18. 功能 对字符串进行正则表达式替换.
  19. 参数: pat = 正则表达式模式 ,对应vbs正则表达式的模式(expression)。说明: \ 号要用 \\ 替代.
  20.      str = 被替换字符串
  21.      nstr = 替换字符串
  22.      key = "i" "g" "m" , "i"不区分大小写(Ignorecase),"g"全局匹配(Global).”m”多行模式(Multiline),以上几个关键字可以组合使用,或用 ””.
  23. 返回 :返回替换后的字符串.
  24. [正则表达式模式]
  25.  正则表达式核心就是其模式(expression),此部分资料可从网上或vb,vbs参考中得到。以下是vbs参考中关于模式的描述列表(本文略)。在xxexp,xxexpr函数应用中,注意”\”符要按”\\”来写。
  26. [实战]
  27.    也许只有通过一些实例,大家才真正知道正则表达式的强大。有的功能是仅仅用lisp提供的函数很难或无法做到的,而在这里,可一一化解。
  28.
  29. 1. 汉字和非汉字提取
  30.    先来点简单的,好让大家进入状态,虽然简单,但是在论坛上是经常被问到的问题:
  31.
  32. ·;;提取汉字及空格。
  33.     ;每字分断,汉字按1个字.
  34.      (xxexp "[^!-~]" "a 测π啊d4少1数★M=3;is=正,2确" "")
  35.     ;返回: (" " "测" "π" "啊" "少" "数" "★" "正" "确")
  36.     ;连字不分断.
  37.     (xxexp "[^!-~]+" "a 测π啊d4少1数★M=3;is=正,2确" "")
  38.      ;返回:(" 测π啊" "少" "数★" "正" "确")
  39.
  40. ·;;提取汉字
  41.     (xxexp "[^ -~]" "a 测π啊d4少1数★M=3;is=正,2确" "")
  42.     (xxexp "[^\\000-\\377]" "a 测π啊d4少1数★M=3;is=正,2确" "")
  43.     ;返回: ("测" "π" "啊" "少" "数" "★" "正" "确")
  44.     (xxexp "[\\u0C04-\\uFFFF]" "a 测π啊d4少1数★M=3;is=正,2确" "")
  45.     ;;返回: ("测" "啊" "少" "数" "★" "正" "确") ;;(注: 查到16进制汉字从\\u0C04开始,这个方法应该是最准确的.)
  46.     (xxexp "[^ -~]+" "a 测π啊d4少1数★M=3;is=正,2确" "")
  47.     (xxexp "[^\\000-\\377]+" "a 测π啊d4少1数★M=3;is=正,2确" "")
  48.      ;返回:("测π啊" "少" "数★" "正" "确")
  49. ·;;提取非汉字
  50. (xxexp "[ -~]" "a 测π啊d4少1数★M=3;is=正,2确" "")
  51. ;返回:("a" " " "d" "4" "1" "M" "=" "3" ";" "i" "s" "=" "," "2")
  52. (xxexp "[\\000-\\377]+" "a 测π啊d4少1数★M=3;is=正,2确" "")
  53. ;返回: ("a " "d4" "1" "M=3;is=" ",2")
  54. ·;;提取字母及数字
  55. (xxexp "\\w" "a 测π啊d4少1数★M=3;is=正,2确" "")
  56. ;返回:("a" "d" "4" "1" "M" "3" "i" "s" "2")
  57. ·;;提取非字母及非数字
  58. (xxexp "[^\\w]" "a 测π啊d4少1数★M=3;is=正,2确" "")
  59.   ;返回:(" " "测" "π" "啊" "少" "数" "★" "=" ";" "=" "正" "," "确")
  60. (xxexp "[^\\w]+" "a 测π啊d4少1数★M=3;is=正,2确" "")
  61. ;返回:(" 测π啊" "少" "数★" "=" ";" "=正," "确")
  62. ·;; 提取连续两个相同的字符
  63.     (SETQ S (xxexp "(.)\\1" "aa看看 测试"M==33";is=,,2" ""))
  64.     ;返回: ("aa" "看看" "==" "33" ",,")
  65. 2. 字符串处理
  66.  看了上面的实例,大家也许有点兴趣了,好,接着来。
  67.
  68. ·;; 提取由分界符界定的字符,呵呵,这个是论坛上被编写的比较多的程序之一.
  69. (xxexp "[^ ;,]+" "a 测试M=3;is=,2" "") ;;返回: ("a" "测试M=3" "is=" "2")
  70. 是不是很容易? 但这只不过是牛刀小试,现在才刚刚开始。
  71. ·拆分字符串,1个汉字算1个.
  72. (xxexp "."  "少1 ,至.2e-5a‖〉∑∵∩∪チネヒжъμㄜ啊d4少1数" "")
  73. ;返回: ("少" "1" " " "," "至" "." "2" "e" "-" "5" "a" "‖" "〉" "∑" "∵" "∩" "∪" "チ" "ネ" "ヒ" "ж" "ъ" "μ" "ㄜ" "啊" "d" "4" "少" "1" "数")
  74. ·按每两个字符进行分断。1个中文按1个计算。
  75. (xxexp ".{2}" "aa 测试M==33;is=,,2" "")
  76. ;;返回: ("aa" " 测" "试M" "==" "33" ";i" "s=" ",,")
  77. ·;;在两个连续字符处分断.(包含指定的分界符,本例指"|")
  78. (setq s1 "aa 测看看试M==33;is=,,2")
  79. (xxexp "[^|]+" (xxexpr "(.)\\1" s1 "|" "") "")
  80. ;返回: (" 测" "试M" ";is=" "2")
  81. ·倒排文字(按字倒排,支持中文)
  82. (setq str "The quick brown 啊 fox jumped 至 over ∑ the lazy dog.")
  83. (apply 'strcat (reverse(xxexp "." str "")))
  84. ;返回: ".god yzal eht ∑ revo 至 depmuj xof 啊 nworb kciuq ehT"
  85.   (apply 'strcat (reverse(xxexp "." "i开头,跟至少1个s" "")))
  86.   ;返回:  "s个1少至跟,头开i"
  87. ·简单替换,(但是用lisp写也不见得简单:) )
  88.    (setq str "IS11 is01 ISa1 iss11 id1 isss1 is1 IS1 ISa")
  89. 2.1 替换 is 为*,不分大小写
  90. (xxexpr "is" str "*" "") ;-> "*11 *01 *a1 *s11 id1 *ss1 *1 *1 *a"
  91. 2.2 替换 i开头,跟s(至少1个)的字符 为*
  92. (xxexpr "is+" str "*" "") ;-> "*11 *01 *a1 *11 id1 *1 *1 *1 *a"
  93. 2.3 替换 非数字和非空格 为*
  94. (xxexpr "[^0-9 ]" str "*" "") ;->"**11 **01 ***1 ***11 **1 ****1 **1 **1 ***"
  95. 2.4 替换 i开头,至少跟2个s的字符为*
  96. (xxexpr "Is{2,}" str "*" "") ;-> "IS11 is01 ISa1 *11 id1 *1 is1 IS1 ISa"
  97. 2.5 替换 i开头,跟1个非换行符的字符为*
  98. (xxexpr "I." str "*" "") ;-> "*11 *01 *a1 *s11 *1 *ss1 *1 *1 *a"
  99. 2.6 替换 i开头,跟至少1个s,+至少1个数字的字符 为*
  100. (xxexpr "is{1,}\\d+" str "*" "") ;-> "* * ISa1 * id1 * * * ISa"
  101. 下面的加点难度:
  102. ·.倒排文字(按空格划分)
  103. (setq str "The quick brown 啊 fox jumped 至于 over ∑ the lazy dog")
  104. (setq lst1 (xxexp "[^ |.]+" str ""))
  105.   ;;返回: ("The" "quick" "brown" "啊" "fox" "jumped" "至于" "over" "∑" "the" "lazy" "dog.")
  106. (setq lst2 (xxexp " +" str ""))
  107. ;;返回: (" " " " " " " " " " " " " " " " " " " " " " ".")
  108. (apply 'strcat (mapcar 'strcat (reverse lst1)(reverse lst2)))
  109. ;;返回: "dog lazy the ∑ over 至于 jumped fox 啊 brown quick "
  110. ·.字符倒置
  111.  ;; 将符合匹配(词1+空格+词2)中词1和词2对调
  112. (xxexpr "(\\S+)(\\s+)(\\S+)" "brown  啊 fox a" "$3$2$1" "") ;;返回:"啊  brown a fox"
  113. ;;将 = 号左右两边的字符对调.
  114. (xxexpr "(.)([-|=])(.)" "a-b=1 : c=d : a" "$3$2$1" "") ;;返回: "b-a=1 : d=c : a"
  115. 3. 有条件的文本替换:
  116. 再加点难度。
  117. ·; "*(*)" 替换为 "*[*]",论坛上只见过lzh写过这样一个程序,是用vba写的。
  118. (xxexpr "(\\()([^\\(\\)]*)(\\))" "a(顶-啊)5()" "[$2]" "")
  119. ;返回: "a[顶-啊]5[]"
  120. ·; A*B*替换为B*C*
  121. (xxexpr "(A{1})([^ABab]*)(B{1})" "A48.B小4Axa8b5" "B$2C" "") ;替换所有匹配
  122. ;返回: "B48.C小4AxB8C5"
  123. (xxexpr "(A{1})([^ABab]*)(B{1})" "A48.B小4Axa8b5" "B$2C" "g");替换第一个匹配的字符串
  124. ;返回:"B48.C小4Axa8b5"
  125. ·;将符合 "*写程序*Yes*" 的字符串替换为 "*测*试*" .这个是不等式替换,用vlisp写起来容易么?
  126. (xxexpr "(.*)写程序(.*)Yes(.*)" "33写程序74=YesYb" "$1测$2试$3" "")
  127. ;返回:"33测74=试Yb"
  128.  再来几个对比测试,什么功能?有点考脑力啊:)
  129. (xxexpr "(.*)写程序(.*)Yes(.*)" "33写程序74=YesYb" "$1测$2$3" "")
  130.   ;->"33测74=Yb"             ;将”写程序”替换为”测”,去掉”Yes”
  131. (xxexpr "(.*)写程序(.*)Yes(.*)" "33写程序74=YesYb" "$1测$3" "")
  132.  ;->"33测Yb"                 ; 去掉”写程序””Yes”及其之间的字符。
  133. (xxexpr "(.*)写程序(.*)Yes(.*)" "33写程序74=YesYb" "$2" "")
  134. ;->"74="                        ; 仅保留”写程序*Yes”之间的*部分.
  135. (xxexpr "(.*)(写程序)(.*)(Yes)(.*)" "33写程序74=YesYb" "$1$4$2$3$5" "")
  136. ;->"33Yes写程序74=Yb"           ;将各部分随意倒置.
  137. (xxexpr "(.*)写(程序)(.*)(Yes)(.*)" "33写程序74=YesYb" "$1看$2$3$5,$4!" "")
  138. ;->"33看程序74=Yb,Yes!"   ; 将"*写程序*Yes*"中的”写”改为看,”Yes”放到最后并加标点
  139. · 替换字符串.将=号后的10~99的数字字符改为*
  140. (xxexpr "(.=)(\\d{2})([^\\d]+)" "M=56变量" "$1*$3" "") ;;返回:"M=*变量"
  141. (xxexpr "(.=)(\\d{2})([^\\d]+)" "M=6变量" "$1*$3" "") ;;返回:"M=6变量"
  142. (xxexpr "(.=)(\\d{2})([^\\d]+)" "M=556变量" "$1*$3" "") ;;返回:"M=556变量"
  143. ·;; 更改字符中包含 M=数字 的字符,将M改为X
  144. (xxexpr "(M)(=)(\\d+)" "2至M=56变量" "X$2$3" "") ;;返回:"2至X=56变量"
  145. ·;; 将字符中a*d分别改为M*N
  146. (xxexpr "(a)(.+)(d)" "测试a=c,d=e,a=3,d=1" "M$2N" "")
  147. ;;返回: "测试M=c,d=e,a=3,N=1" (全字按顺序匹配)
  148. (xxexpr "(a)([^a|d]+)(d)" "测试a=c,d=e,a=3,d=1" "M$2N" "")
  149. ;;返回:"测试M=c,N=e,M=3,N=1"  (所有按顺序匹配).
  150. ·将字符 "我们*测试" 中的* 改为"不"字
  151. (xxexpr "(.*今天)([^测试]*)(测试?.*)" "今天我们一起测试这个函数,你来测试" "$1不$3" "")
  152. ; ;返回:"今天不测试这个函数,你来测试";;(仅匹配第一次遇到的"测试"二字)
  153.   (xxexpr "(.*今天)(.*)(测试.*)" "今天我们一起测试这个函数,你来测试" "$1不$3" "")
  154. ;;返回:"今天不测试" (;; 匹配最外层的"测试"二字)
  155. 是不是越来越晕了?还有呢,下面是两个测试,是有一定实践意义的更改文本内数字的程序。
  156. ·;; 更改字符中包含 M=数字 的字符,将数字加1.5。可能还有更好更有效的写法。
  157. (defun c:test1()
  158. (setq str "2至M=56.5变M=3量M=.22"
  159.        pat "(M)(=)(\\d{0,}\\.{0,1}\\d{1,})")
  160.   (setq lst (xxexp pat str ""))
  161.   ;; 此步返回: ("M=56.5" "M=3" "M=.22")
  162.   (setq lst2(mapcar '(lambda(x)(strcat "M=" (rtos(+ 1.5(distof(vl-string-subst "" "M=" x)))2 2)))lst))
  163.   ;此步返回:("M=58.00" "M=4.50" "M=1.72")
  164.   (mapcar '(lambda(x y)(setq str (xxexpr x str y ""))) lst lst2)
  165.   str)
  166. ;;最后返回: "2至M=58.00变M=4.50量M=1.72"
  167. · ;; 将a=或d=开头的数字加一个数(1.75).。另外一种写法。
  168. (defun c:test2()
  169.     (setq str "测试a=2,d=3结果f=2,aa-3"
  170.        add 1.75
  171.        jd 2) ;精度
  172.     (setq str2 (xxexpr "([a|d])(=)(\\d+)" str (strcat"$1$2(+ " (rtos add 2 jd) " $3)") ""))
  173.     ;;返回: "测试a=(+ 1.75 2),d=(+ 1.75 3)结果f=2,aa-3"
  174.     (setq as (mapcar '(lambda(x)(eval(read x))) (xxexp "(\\([^()]*\\))" str2  "")))
  175.     ;;返回:("(+ 1.75 2)" "(+ 1.75 3)");返回:(3.75 4.75)
  176.     (mapcar '(lambda(x)(setq str2 (xxexpr "([a|d])(=)(\\([^()]*\\))" str2 (strcat "$1$2" (rtos x 2 jd)) "g"))) as)
  177.     str2
  178. ) ;;最后返回: "测试a=3.75,d=4.75结果f=2,aa-3"
  179. 4. 提取数字文本:
  180.    之所以把这个专门做一小节,是因为现实意义较大,而我以前也用vlisp写过这样的程序,但写起来难免有些考虑不到的情况,总是不爽,现在,终于可以松一口气。
  181.    先说说字符中的数字可能出现的情况。其实很简单,就是distof认得的就应该看做数字。如:
  182. “+1“ “+1.0““+.3““1.3““1.3e1“ “1.3e2““1.3e-2“ 等.
  183. 虽然乍一看简单,但是如果遇到“..2.3 +-2.5.6e-3.6 -1d.+3e.1“等不规范的字符串,要正确提取数字用lisp写起来可就困难了。
  184. 现在看看正则表达式的功能如何,下面是我摸索到的,pat也许有更科学的写法。
  185. [复制代码到剪贴板]
  186. ·提取字符串内数字1:
  187. (setq str "a-.3A0.0+9.5d-1.3 1.2e-58d4d-15.1d5.6asf-1.2"
  188.        pat "[+|-]?\\d*\\.?\\d+(e[+|-]*\\d+)*")
  189. (xxexp  pat str "")
  190. ;;返回:("-.3" "0.0" "+9.5" "-1.3" "1.2e-58" "4" "-15.1" "5.6" "-1.2")
  191. ;;下面再验证是否是数字.
  192.    (mapcar 'distof (xxexp  pat str ""))
  193.    ;;返回:(-0.3 0.0 9.5 -1.3 1.2e-058 4.0 -15.1 5.6 -1.2)
  194. ·提取字符串内数字2:
  195. (setq str "-1e4-31++3485..3.1a.38 3..14f-.86e-1d3.a4f8.48"
  196.        pat "[+|-]?\\d*\\.?\\d+(e[+|-]*\\d+)*")
  197. (xxexp  pat str "")
  198. ;;返回: ("-1e4" "-31" "+3485" ".3" ".1" ".38" "3" ".14" "-.86e-1" "3" "4" "8.48")
  199. ;;下面再验证是否是数字.
  200.    (mapcar 'distof (xxexp  pat str ""))
  201.    ;;返回:(-10000.0 -31.0 3485.0 0.3 0.1 0.38 3.0 0.14 -0.086 3.0 4.0 8.48)
  202. 5. 函数各参数对比
  203.   结束前,对函数的各参数的用法做一些实例,以便通过对比加深理解。
  204. ·xxexp参数及partten对比测试
  205. (setq str "IS11 is01 ISa1 iss11 id1 isss1 is1 IS1 ISa")
  206. 1.1;查找 str 中符合 is开头跟至少1个数字的字符. i 大小写敏感;g 全局(仅找第一个符合条件的字符)
  207. (xxexp "is\\d+" str "iG") ;-> ("is0") ; 小写,第一个
  208. (xxexp "is\\d+" str "i") ;-> ("is01" "is1") ;小写,全局
  209. (xxexp "is\\d+" str "g") ;->("IS11");大小写,第一个
  210. (xxexp "is\\d+" str "") ;-> ("IS11" "is01" "is1" "IS1");大小写,所有.
  211. 1.2 查找IS开头,跟非换行单字符,跟0-9数字
  212. (xxexp "IS.[0-9]" str "") ;-> ("IS11" "is01" "ISa1" "iss1")
  213. 1.3 查找IS开头,跟非A或a,跟0-9数字
  214. (xxexp "IS[^Aa][0-9]" str "") ;->("IS11" "is01" "iss1")
  215. 1.4 查找IS开头,至少两个S的字符
  216. (xxexp "IS{2,}" str "") ;-> ("iss" "isss")
  217. 1.5 查找IS开头,跟两个数字
  218. (xxexp "IS[0-9][0-9]" str "") ;-> ("IS11" "is01")
  219. 1.6 查找IS开头,跟两个数字,大小写敏感.
  220. (xxexp "IS[0-9][0-9]" str "i") ;-> ("IS11")
  221. 1.7 查找IS开头,跟1个数字.
  222. (xxexp "IS[0-9]" str "") ;-> ("IS1" "is0" "is1" "IS1")
  223. 1.8 查找IS开头,跟1个数字,跟空格.
  224. (xxexp "IS[0-9] " str "") ;-> ("is1 " "IS1 ")
  225. ·xxexp和xxexpr的配合使用
  226.    Xxexp 可提取符合条件的字符(列表),得到的表可提供给别的程序进行进一步处理。
  227.    Xxexpr 替换的结果(个数),可以用xxexp预知。
  228.      (xxexp "\\band\\b" "weekend,endfor,end" "") ;返回: nil ;没有一个匹配
  229.  (xxexpr "\\band\\b" "weekend,endfor,end" "start" "")
  230.   ;返回:"weekend,endfor,end" ;不改变字符串
  231. (xxexp "\\bend\\b" "weekend,endfor,end" "")
  232. ;返回: ("end") ;; 仅仅有一个匹配. \\b:指单词边界.
  233. (xxexpr "\\bend\\b" "weekend,endfor,end" "start" "")
  234. ;返回: "weekend,endfor,start" ;仅替换一个.
  235. (xxexp "end" "weekend,endfor,end" "")
  236.   ;返回: ("end" "end" "end") ;;有三个匹配
  237. (xxexpr "end" "weekend,endfor,end" "start" "")
  238.   ;返回: "weekstart,startfor,start" ;替换3个.
  239.
  240. [结语:“一刀屠文”]
  241.    通过pat,和key的不同设定,可以看到正则表达式的功能不是一般的强,对应一种要求,pat可能有不只一种写法,只要pat写的好,在字符处理上,你能做的很多很多,而且也轻而易举,免去写n个程序的痛苦。呵呵,我以前写的几十个字符串处理函数很多都要下岗贱卖了。
  242.    差点忘了给这两个函数起个名号了,鉴于文字处理方面叫的好听的名号都被用的差不多了,大师之类的又不敢叫,一时间也想不到更好的,暂时叫“一刀屠文”吧,“屠”,表示对文字的深入解析,刀随心动,所向披靡,物我两忘。(%^$哎哟!谁砸的砖头!$%#)
  243.    今天就到这里吧,更多更强的功能等待你去发现。
  244.
  245.
  246.                                                            梁雄啸
  247.       2007.7.28夜
发表于 2007-8-24 13:17:29 | 显示全部楼层
谢了,收下。
发表于 2007-8-28 15:24:57 | 显示全部楼层
还是不明白。
发表于 2007-8-31 18:01:52 | 显示全部楼层
太好了
学习中
发表于 2007-9-11 22:05:00 | 显示全部楼层
实在是高手啊, 有了这个东西,我们就可以直接把图上的数字进行运算了,这样能够开发出不少的图形计算工具呢!!
GMT+8, 2026-11-3 07:26 , Processed in 0.569198 second(s), 41 queries , Gzip On.
