查看: 4330|回复: 0
[求助]:AutoCAD 2007.NET API中,在C#中如何给实体设置XData扩展属性
发表于 2006-5-17 10:15:52 | 显示全部楼层 |阅读模式
咨询一下在AutoCAD 2007.NET API中,用C#中如何给实体设置XData扩展属性,希望能把XData彻底弄清楚。
在VC60下的XData的添加方法,Autodesk公司的示例文档中有很好的代码:
void
addXdata()
    AcDbObject* pObj = selectObject(AcDb::kForRead);
    if (!pObj) {
        acutPrintf("Error selecting object\n");
        return;
    // Get the application name and string to be added to
    // xdata.
    char appName[132], resString[200];
    appName[0] = resString[0] = '\0';
    acedGetString(NULL, "Enter application name: ",
        appName);
    acedGetString(NULL, "Enter string to be added: ",
        resString);
    struct  resbuf  *pRb, *pTemp;
    pRb = pObj->xData(appName);
    if (pRb != NULL) {
        // If xdata is present, then walk to the
        // end of the list.
        for (pTemp = pRb; pTemp->rbnext != NULL;
                pTemp = pTemp->rbnext)
    } else {
        // If xdata is not present, register the application
        // and add appName to the first resbuf in the list.
        // Notice that there is no -3 group as there is in
        // AutoLISP. This is ONLY the xdata so
        // the -3 xdata-start marker isn't needed.
        acdbRegApp(appName);
        pRb = acutNewRb(AcDb::kDxfRegAppName);
        pTemp = pRb;
        pTemp->resval.rstring
            = (char*) malloc(strlen(appName) + 1);
        strcpy(pTemp->resval.rstring, appName);
    // Add user-specified string to the xdata.
    pTemp->rbnext = acutNewRb(AcDb::kDxfXdAsciiString);
    pTemp = pTemp->rbnext;
        = (char*) malloc(strlen(resString) + 1);
    strcpy(pTemp->resval.rstring, resString);
    // The following code shows the use of upgradeOpen()
    // to change the entity from read to write.
    pObj->upgradeOpen();
    pObj->setXData(pRb);
    pObj->close();
    acutRelRb(pRb);
问题是在AutoCAD 2007.NET API下:
网上现有的只是关于Xrecord的示例代码,如下:
public ObjectId createXrecord(string name,string salary,string division)
    Database db = HostApplicationServices.WorkingDatabase;
    Transaction trans = db.TransactionManager.StartTransaction();
    try
        BlockTable bt = (BlockTable)MyT.GetObject(db.BlockTableId, OpenMode.ForWrite, false);
        BlockTableRecord br = (BlockTableRecord)MyT.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
        //Create the custom per-employee data
        Xrecord xRec = new Xrecord();
        //We want to add //Name//, //Salary// and //Division// information.  Here is how:
        xRec.Data = new ResultBuffer(
            new TypedValue((int)DxfCode.Text, name),
            new TypedValue((int)DxfCode.Real, salary),
            new TypedValue((int)DxfCode.Text, division));
        //Next, we need to add this data to the //Extension Dictionary// of the employee.
        br.CreateExtensionDictionary();
        DBDictionary brExtDict = (DBDictionary)trans.GetObject(br.ExtensionDictionary, OpenMode.ForWrite, false);
        brExtDict.SetAt("EmployeeData", xRec); //Set our XRecord in the dictionary at //EmployeeData//.
        trans.AddNewlyCreatedDBObject(xRec, true);
        return xRec.ObjectId;
    catch
        return ObjectId.Null;
但为何添加XData扩展数据就会报错eBadDxfSequence呢?
public void addXData(Entity ent,string name,string salary,string division)
            Transaction MyT = db.TransactionManager.StartTransaction();
            try
                BlockTableRecord btr = (BlockTableRecord)MyT.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite, false);
                ent.XData = new ResultBuffer();
                btr.AppendEntity(ent);
                MyT.AddNewlyCreatedDBObject(ent, true);
            catch
后来又试过如下方法:
                    Autodesk.AutoCAD.DatabaseServices.SymbolUtilityServices.IsRegAppAcadName("name");
                    pEnt.XData = new ResultBuffer(new TypedValue((int)DxfCode.ExtendedDataRegAppName,"name"));
                    pEnt.XData.Add(new TypedValue((int)DxfCode.ExtendedDataControlString, "this is a test!"));
也报错……为eRegappIdNotFound,应该是因为未注册应用程序名的原因,
求教全局函数acdbRegApp(appName)在C#中的对应方法!!
GMT+8, 2026-11-2 21:50 , Processed in 0.479410 second(s), 32 queries , Gzip On.
