查看: 2677|回复: 11
[求助] [求助]:如何使mtext写出的多行文字具有背景遮罩功能?
发表于 2006-5-17 14:38:02 | 显示全部楼层 |阅读模式
求一程序?
如何使mtext写出的文本就具有背景遮罩功能?用lisp实现,而不是有mtext对话框中点右键实现?
(defun c:mt()
  (princ "\n*<创建多行文本>*  指定文字起点:")
  (setvar "cmdecho" 0)
  (setvar "textsize" 300)
  (command "mtext" pause "L" "a" "1x" "s" "standard" "w" "0")
  (princ)
上面这代码只能实现在命令行输入宽度为0的多行文本,如何能在这代码中加入背景遮罩?
谢谢!
已领礼包: 6个
发表于 2006-5-18 19:12:30 | 显示全部楼层
这是个新问题还没想过!
不知道乍的办
等待高人解答!
发表于 2006-5-18 21:02:57 | 显示全部楼层
如有可能,请给出一个例子,贴个图
如下是一个autocad高手编的给多个Mtext加Mask的程序,说不定可以改成你需要的,或者你直接就可以用的,对Mask用的不多,和wipeout有什么区别
[php]
;; Written by: Lee Ambrosius
;; Created on: 4/7/2004
;; This program allows you to add Background Mask to several Mtext objects
;; at one time instead of using the Mtext editor for each object or the Properties Palette.
;; The Properties Palette in 2005 doesn't allow you to set Background Color or Border Offset.
(defun c:MTextMASK ( / kWordBackgroundMaskCurrent dOffsetCurrent ssMtext dxf90 dxf63 dxf45 dxf441)
  (prompt "\nApply Mtext Mask")
  (if (= kWordBackgroundMask nil)
    (setq kWordBackgroundMask "Background" kWordBackgroundMaskCurrent "Background")
    (setq kWordBackgroundMaskCurrent kWordBackgroundMask)
  (initget "None Background Color")
  (setq kWordBackgroundMask (getkword (strcat "\nSpecify Background Mask: [None/Background/Color] <" kWordBackgroundMask ">: ")))
    (setq kWordBackgroundMask kWordBackgroundMaskCurrent)
  (cond ((= kWordBackgroundMask "Color")
            (if (or (= maskClr nil) (/= (type maskClr) 'LIST))
               (setq maskClr (acad_truecolorcli 1))
               (if (= (assoc 420 maskClr) nil)
                 (setq maskClr (acad_truecolorcli (cdr (assoc 62 maskClr))))
                 (setq maskClr (acad_truecolorcli (assoc 420 maskClr)))
        ((= kWordBackgroundMask "Background")(setq maskClr 256))
        ((= kWordBackgroundMask "None")(setq maskClr 0 dOffset 1.0))
  (if (/= maskClr nil)
    (progn
      (if (/= kWordBackgroundMask "None")
        (progn
          (setq dOffsetCurrent dOffset)
          (if (= dOffsetCurrent nil)
            (setq dOffset 1.0 dOffsetCurrent 1.0)
          (setq dOffset (getreal (strcat "\nSpecify border offset factor: <" (rtos dOffsetCurrent 2 3) ">: ")))
          (if (= dOffset nil)
            (setq dOffset dOffsetCurrent)
          (if (> dOffset 5)(setq dOffset nil))
          (if (< dOffset 1)(setq dOffset nil))
          (while (= dOffset nil)
        (if (= dOffset nil)
          (setq dOffset 1.0)
      (if (setq ssMtext (ssget (list (cons 0 "MTEXT"))))
        (progn
          (cond ((= kWordBackgroundMask "None")
                    (setq mask_list (list (cons 90 2)(cons 63 0)(cons 45 dOffset)(cons 441 0))
                          dxf90 2
                          dxf63 nil
                          dxf45 nil
                          dxf441 nil
                ((and (= kWordBackgroundMask "Color")(/= (assoc 420 maskClr) nil))
                    (setq mask_list (list (cons 90 1)(cons 63 1)(cons 421 (cdr (assoc 420 maskClr)))(cons 45 dOffset)(cons 441 (cdr (assoc 420 maskClr))))
                          dxf90 1
                          dxf63 2
                          dxf45 dOffset
                          dxf441 (cdr (assoc 420 maskClr))
                ((and (= kWordBackgroundMask "Color")(= (assoc 420 maskClr) nil))
                    (setq mask_list (list (cons 90 1)(cons 63 (cdr (assoc 62 maskClr)))(cons 45 dOffset)(cons 441 2146608))
                          dxf90 1
                          dxf63 (cdr (assoc 62 maskClr))
                          dxf45 dOffset
                          dxf441 nil
                    (setq mask_list (list (cons 90 3)(cons 63 3)(cons 45 dOffset)(cons 441 0))
                          dxf90 3
                          dxf63 256
                          dxf45 dOffset
                          dxf441 0
          (setq emax (sslength ssMtext)
                sscount 0
          (while (< sscount emax)
            (setq EN (entget (ssname ssMtext sscount))
                  tempEN nil)
            (if (/= dxf90 nil)
              (progn
                (if (/= (assoc 90 EN) nil)
                  (setq EN (subst (cons 90 dxf90) (assoc 90 EN) EN))
                  (setq EN (append EN (list (cons 90 dxf90))))
              (progn
                (setq CNT 0
                      nMembers (member (assoc 90 EN) EN))
                (if (= nMembers nil)
                  (setq nMembers 0)
                  (setq nMembers (length nMembers))
                (repeat (- (length EN) nMembers)
                  (setq tempEN (append tempEN (list (nth cnt EN))))
                  (setq CNT (1+ CNT))
                (if (> nMembers 0)
                  (progn
                    (setq CNT 1)
                    (repeat (- nMembers 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 90 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN
                      tempEN nil)
            (if (/= dxf63 nil)
              (progn
                (if (/= (assoc 63 EN) nil)
                  (setq EN (subst (cons 63 dxf63) (assoc 63 EN) EN))
                  (setq EN (append EN (list (cons 63 dxf63))))
              (progn
                (setq CNT 0
                      nMembers (member (assoc 63 EN) EN))
                  (setq nMembers 0)
                  (setq CNT (1+ CNT))
                (if (> nMembers 0)
                  (progn
                    (setq CNT 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 63 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN
                      tempEN nil)
            (if (/= dxf45 nil)
              (progn
                (if (/= (assoc 45 EN) nil)
                  (setq EN (subst (cons 45 dxf45) (assoc 45 EN) EN))
                  (setq EN (append EN (list (cons 45 dxf45))))
              (progn
                (setq CNT 0
                      nMembers (member (assoc 45 EN) EN))
                  (setq nMembers 0)
                  (setq CNT (1+ CNT))
                (if (> nMembers 0)
                  (progn
                    (setq CNT 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 45 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN
                      tempEN nil)
            (if (/= dxf441 nil)
              (progn
                (if (/= (assoc 441 EN) nil)
                  (setq EN (subst (cons 441 dxf441) (assoc 441 EN) EN))
                  (setq EN (append EN (list (cons 441 dxf441))))
              (progn
                (setq CNT 0
                      nMembers (member (assoc 441 EN) EN))
                  (setq nMembers 0)
                  (setq CNT (1+ CNT))
                (if (> nMembers 0)
                  (progn
                    (setq CNT 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 441 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN)
            (entmod EN)
            (setq sscount (1+ sscount))
(princ)
(prompt "\nType MTEXTMASK to run the command")
(princ)
[/php]
 楼主| 发表于 2006-5-18 23:29:57 | 显示全部楼层
最初由 snoopychen 发布
[B]如有可能,请给出一个例子,贴个图
[php]
;;... [/B]
具体可以看看这个帖子!
http://www.xdcad.net/forum/showthread.php?s=&threadid=558660
谢谢!
[iframe h=600 w=100%]http://www.xdcad.net/forum/showthread.php?s=&threadid=558660[/iframe]
发表于 2006-5-23 12:24:23 | 显示全部楼层
昨天才装了个07,知道了楼主的意思,经过查询,发现这个mask存在以下几个dxf代码中,
63(颜色),90, 45(边框), 441
本来替换就挺容易的,但是楼主这句
(command "mtext" pause "L" "a" "1x" "s" "standard" "w" "0")里面的pause使的子程序始终无法进行
暂时改成一个getstring,不过这个不能够输入空格和多行,需要再改进
代码如下,可试试,在07下通过
[php]
;;; first by andyhua5240
;;;test by qjchen
(defun c:mt2()
(setq fff (getpoint "the start point"))
(setq ddd (getstring "the mtext number"))
(command "mtext" fff "L" "a" "1x" "s" "standard" "w" "0" ddd "")
(setq a (entget (entlast)))
(setq a (xd-modent a (list (cons 63 256) (cons 90 3) (cons 45 1.7) (cons 441 0))))
(princ)
;;;;;eachy版主的程序
(defun xd-modent (el tylst / c)
  (foreach n tylst
    (if        (setq c (assoc (car n) el))
     (setq el (subst n c el))
      (setq el (append el (list n)))
  (entmod el)
[/php]
发表于 2006-5-23 13:55:39 | 显示全部楼层
;; 加一个反应器,在mtext执行之后,马上给实体添加文本遮罩。
[php]
(defun mtfil (a b)
  (if (= "MTEXT" (car b))
    (vla-put-BackgroundFill (vlax-ename->vla-object (entlast)) :vlax-true))
(vla-add (vlr-command-reactor nil '((:vlr-commandEnded . mtfil))))
[/php]
发表于 2006-5-23 16:07:28 | 显示全部楼层
  1. ;;沒那麼簡單的,還要調整MTEXT範圍(未改)
  2. (defun MTFIL (A B)
  3.   (if (wcmatch (car B) "*MTEXT")
  4.     (vla-put-backgroundfill
  5.       (vlax-ename->vla-object (entlast))
  6.       :vlax-true
  7.     )
  8.   )
  9.   (princ)
  10. )
  11. (if (not MTFILL)
  12.   (vlr-command-reactor NIL '((:vlr-commandended . MTFIL)))
  13. )
发表于 2006-5-23 16:51:24 | 显示全部楼层
原来这个pause会导致这么复杂的问题啊
对于1楼楼主的问题,我觉得要不就等快要出图的时候,再用match实现mask不更好(当然,mtext的写法最好是象楼主那样写的)
不然,mask对于后建立的实体也是不起作用的,似乎挺麻烦的。
现在还是不大搞得清楚et中的textmask和这个mask的关系,3楼程序中的那种mask好像在04中也能用。早期的wipeout好像也是这种功能啊
 楼主| 发表于 2006-5-24 00:25:51 | 显示全部楼层
楼上的大侠们!
小弟我只懂一点点lisp皮毛,还算不上是lisp的小小毛毛虫。看了楼上那么多王牌大侠们回帖,我不胜感激!但是偶还是不明白,不怎么如何是好?因为我就不懂呀!
楼上的大哥们,哪位行行好。能不能把意见整理综合一下。能让偶下载一个附件呀?
谢谢啦!太感谢了!
发表于 2008-6-26 22:07:09 | 显示全部楼层
感谢6楼的 "vla-put-BackgroundFill"
发表于 2021-1-31 22:56:55 | 显示全部楼层
大神们,有完善的程序了吗?这个功能很实用啊。
已领礼包: 375个
发表于 2021-2-1 00:33:52 | 显示全部楼层
同样的需求,值得学习!!
GMT+8, 2026-11-3 06:00 , Processed in 0.594817 second(s), 55 queries , Gzip On.
