查看: 885|回复: 1
[求助]:[求助]:如何制作IP54机柜
发表于 2006-5-18 17:18:22 | 显示全部楼层 |阅读模式
今天接到一份订单是制作IP54的机柜,柜体需要散热,有散热分散,由于第一次制作请问哪位大虾知道怎么做?谢谢
发表于 2006-5-18 18:08:05 | 显示全部楼层
Please refer to BSEN60439, all requirement should be stated. There should be no any opening allowed on the casing. If you want to know the heat distribution. "Temperature Rise Test" should be carried out.
GMT+8, 2026-11-3 13:53 , Processed in 0.615916 second(s), 34 queries , Gzip On.
