查看: 844|回复: 1
[VBA程序]:请教选择集的selectatpoint方法
发表于 2003-5-20 10:30:48 | 显示全部楼层 |阅读模式
请教选择集的selectatpoint方法怎么回事呀,它的点point参数如何执行?
发表于 2003-5-27 18:41:39 | 显示全部楼层
[code]
Sub Example_SelectAtPoint()
    ' This example adds objects to a selection set by identifying a point.
    ' At first all objects at the point are added to the selection set. Then
    ' only circle objects at the point are added to the selection set.
    ' Create the selection set
    Dim ssetObj As AcadSelectionSet
    Set ssetObj = ThisDrawing.SelectionSets.Add("TEST_SSET1")
    ' Add to the selection set all the objects that lie at point(6.8,9.4,0)
    Dim point(0 To 2) As Double
    point(0) = 6.8: point(1) = 9.4: point(2) = 0
    ssetObj.SelectAtPoint point
    ' Add to the selection set all the Circles that lie at point (6.8,9.4,0)
    Dim gpCode(0) As Integer
    Dim dataValue(0) As Variant
    gpCode(0) = 0
    dataValue(0) = "Circle"
    Dim groupCode As Variant, dataCode As Variant
    groupCode = gpCode
    dataCode = dataValue
    ssetObj.SelectAtPoint point, groupCode, dataCode
End Sub
[code]
object.SelectAtPoint Point, FilterType, FilterData
Object
SelectionSet
The object or objects this method applies to.
Point
Variant (three-element array of doubles); input-only
The 3D WCS coordinates specifying the point to use for the selection.
FilterType
Integer; input-only; optional
A DXF group code specifying the type of filter to use.
FilterData
Variant; input-only; optional
The value to filter on.
但执行结果和公司的说明不一样,只能选到1个
GMT+8, 2026-11-22 10:28 , Processed in 0.326917 second(s), 12 queries , Gzip On, File On.
