查看: 2776|回复: 14
[其他]:Delphi为ACAD写的OLE程序中标注时出错
发表于 2006-6-3 15:19:39 | 显示全部楼层 |阅读模式
斑竹留情,因没有OLE板块,不知发这里对不对,错了请留情
我用DELPHI 7 为ACAD2006写的二次开发程序中在没加入标注时一切正常,加入标注后执行到标注语句处就出错,哪位大侠知道是怎么回事?
已领礼包: 12个
发表于 2006-6-4 01:39:56 | 显示全部楼层
贴出你代码看看。
 楼主| 发表于 2006-6-5 13:43:56 | 显示全部楼层
unit Main;
interface
uses
  Windows, Messages, SysUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, OleServer, AutoCAD_TLB, ExtCtrls, StdCtrls, ComObj, Math;
const
  PI = 3.1415926535897932384626433;
  ExtLine = 20;
  Rmin = 3;
  W = 8;
type
  TMainForm = class(TForm)
    Timer1: TTimer;
    AcadDoc: TAcadDocument;
    Button1: TButton;
    procedure FormCreate(Sender: TObject);
    procedure Timer1Timer(Sender: TObject);
    procedure AcadDocObjectAdded(ASender: TObject;
      const Object_: IDispatch);
    procedure Button1Click(Sender: TObject);
  private
    { Private declarations }
    LastDoc: string;
  public
    { Public declarations }
    function CreateDimStyle(AName:string): IAcadDimStyle;
    function CreateLayer(AName: ACAD_LAYER; AColor: ACAD_COLOR;
                         ALineType: ACAD_LTYPE;
                         ALineWeight: ACAD_LWEIGHT = acLnWtByLwDefault;
                         ALineTypeFile: string = 'acadiso.lin'): IAcadLayer;
    function CreateTextStyle(AName: string; AFontFile: string;
                             ABigFontFile: string;
                             AWidth: Double = 1;
                             AObliqueAngle: Double =0;
                             AHeight: Double = 0): IAcadTextStyle;
    procedure DrawN1_N3(L, D, K, Df, C, Dk, Dp, tp, tw, tl: Double);
    function FindDimStyle(AName: string; var AStyle: IAcadDimStyle): Boolean;
    function FindLayer(AName: ACAD_LAYER; var ALayer: IAcadLayer): Boolean;
    function FindLineType(AName: ACAD_LTYPE): Boolean;
    function FindTextStyle(AName: string; var AStyle: IAcadTextStyle): Boolean;
    function SetPoint(x, y, z: Double): ACAD_POINT; overload;
    function SetPoint(base: ACAD_POINT; x, y, z: Double): ACAD_POINT; overload;
    //function AddLine(StartPoint, EndPoint: ACAD_POINT): IAcadLine;
    //function AddLineReXYZ(StartPoint: ACAD_POINT; x, y, z: Double): IAcadLine;
  end;
var
  MainForm: TMainForm;
implementation
{$R *.dfm}
function TMainForm.CreateDimStyle(AName:string): IAcadDimStyle;
begin
  if not FindDimStyle(AName, Result) then
    Result := AcadDoc.DimStyles.Add(AName);
end;
function TMainForm.CreateLayer(AName: ACAD_LAYER; AColor: ACAD_COLOR;
                               ALineWeight: ACAD_LWEIGHT;
                               ALineTypeFile: string): IAcadLayer;
begin
  if not FindLayer(AName, Result) then
    Result := AcadDoc.Layers.Add(AName);
  Result.color := AColor;
  if not FindLineType(ALineType) then
    AcadDoc.Linetypes.Load(ALineType, ALineTypeFile);
  Result.Linetype := ALineType;
  Result.Lineweight := ALineWeight;
end;
function TMainForm.CreateTextStyle(AName: string; AFontFile: string;
                                   ABigFontFile: string; AWidth: Double;
                                   AObliqueAngle: Double;
                                   AHeight: Double): IAcadTextStyle;
begin
  if not FindTextStyle(AName, Result) then
    Result := AcadDoc.TextStyles.Add(AName);
  Result.fontFile := AFontFile;
  Result.BigFontFile := ABigFontFile;
  Result.Width := AWidth;
  Result.ObliqueAngle := AObliqueAngle;
  Result.Height := AHeight;
end;
procedure TMainForm.DrawN1_N3(L, D, K, Df, C, Dk, Dp, tp, tw, tl: Double);
var
  BasePoint: ACAD_POINT;
  Point1, Point2, Point3, Point4, Point5, Point6: ACAD_POINT;
  Point7, Point8, Point9, Point10, Point11, Point12: ACAD_POINT;
  Point13, Point14, Point15, Point16: ACAD_POINT;
  PC1, PC2: ACAD_POINT;
  Points: OleVariant;
  OldDimStyle: IAcadDimStyle;
  OldLayer: IAcadLayer;
  OldTextStyle: IAcadTextStyle;
  Hatch: IAcadHatch;
  PL: IAcadLWPolyline;
  OuterLoop: array of IAcadEntity;
  InnerLoop: array of IAcadEntity;
  R: Double;
  Line1, Line2: IAcadLine;
  DimObj: IAcadDimAligned;
begin
  OldDimStyle := nil;
  OldLayer := nil;
  OldTextStyle := nil;
  SetLength(InnerLoop, 1);
  try
    OldDimStyle := AcadDoc.ActiveDimStyle;
    OldLayer := AcadDoc.ActiveLayer;
    OldTextStyle := AcadDoc.ActiveTextStyle;
    //  Get base point
    BasePoint := AcadDoc.Utility.GetPoint(EmptyParam, 'Base point:');
    //  Draw Center line
    AcadDoc.ActiveLayer := CreateLayer('Center', acRed, 'CENTER');
    PC1 := SetPoint(BasePoint, - ExtLine, 0, 0);
    PC2 := SetPoint(BasePoint, L + ExtLine, 0, 0);
    AcadDoc.ModelSpace.AddLine(PC1, PC2);
    Point3 := SetPoint(PC2, 0, K / 2, 0);
    Point4 := SetPoint(Point3, - C - 2 * ExtLine, 0, 0);
    AcadDoc.ModelSpace.AddLine(Point3, Point4).Mirror(PC1, PC2);
    //  Draw Pipe
    AcadDoc.ActiveLayer := CreateLayer('Pipe', acGreen, 'Continuous');
    Hatch := AcadDoc.ModelSpace.AddHatch(0, 'ANSI31', True, 0);
    if tp <= Rmin then
    begin
      tp := Rmin;
      R := Rmin;
    end
    else
      R := trunc(tp * 0.7);
    Points := VarArrayCreate([0, 7], varDouble);
    Points[0] := BasePoint[0];
    Points[1] := BasePoint[1] + Dp / 2;
    Points[2] := BasePoint[0] + L;
    Points[3] := Points[1];
    Points[4] := Points[2];
    Points[5] := BasePoint[1] - Dp / 2;
    Points[6] := BasePoint[0];
    Points[7] := Points[5];
    SetLength(OuterLoop, 1);
    PL := AcadDoc.ModelSpace.AddLightWeightPolyline(Points);
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.AppendOuterLoop(OuterLoop);
    Hatch.AppendInnerLoop(OuterLoop);
    if tp > R then
    begin
      Points := VarArrayCreate([0, 11], varDouble);
      Points[0] := BasePoint[0] + L;
      Points[2] := BasePoint[0];
      Points[5] := Points[3] - tp + R;
      Points[6] := Points[4] + R;
      Points[7] := Points[3] - tp;
      Points[8] := Points[0] - R;
      Points[9] := Points[7];
      Points[10] := Points[0];
      Points[11] := Points[5];
      PL.Closed := True;
      PL.SetBulge(2, Tan(PI / 8));
      PL.SetBulge(4, Tan(PI / 8));
      InnerLoop[0] := PL;
      Hatch.AppendInnerLoop(InnerLoop);
      Points[1] := BasePoint[1] - Dp / 2;
      Points[5] := Points[3] + tp - R;
      Points[6] := Points[4] - R;
      Points[7] := Points[3] + tp;
      Points[8] := BasePoint[0] + R;
      Points[10] := BasePoint[0];
      PL.Closed := True;
      InnerLoop[0] := PL;
    end
    else
    begin
      Points[4] := Points[2] + R;
      Points[5] := Points[1] - R;
      Points[6] := BasePoint[0] - R;
      PL.Closed := True;
      PL.SetBulge(1, Tan(PI / 8));
      PL.SetBulge(3, Tan(PI / 8));
      InnerLoop[0] := PL;
      Points[4] := Points[2] - R;
      Points[5] := Points[3] + R;
      Points[6] := BasePoint[0] + R;
      PL.Closed := True;
      InnerLoop[0] := PL;
    end;
    Hatch.PatternAngle := 0.5 * PI;
    Hatch.HatchStyle := acHatchStyleNormal;
    Hatch.PatternScale := 3;
    Hatch.Evaluate;
    Hatch.Update;
    //  Draw Flange
    Point2 := SetPoint(BasePoint, L, D / 2, 0);
    Point1 := SetPoint(Point2, -C, 0, 0);
    Point3 := SetPoint(BasePoint, L - C, Dp / 2, 0);
    Point4 := SetPoint(BasePoint, L - C, -Dp / 2, 0);
    Point6 := SetPoint(BasePoint, L, -D / 2, 0);
    Point5 := SetPoint(Point6, -C, 0, 0);
    AcadDoc.ActiveLayer := CreateLayer('Flange', acGreen, 'Continuous');
    SetLength(OuterLoop, 6);
    Line1 := AcadDoc.ModelSpace.AddLine(Point4, Point3);
    Line1.color := acRed;
    if not FindLineType('DASHED') then
      AcadDoc.Linetypes.Load('DASHED', 'acadiso.lin');
    Line1.Linetype := 'DASHED';
    OuterLoop[0] := Line1;
    OuterLoop[1] := AcadDoc.ModelSpace.AddLine(Line1.EndPoint, Point1);
    OuterLoop[2] := AcadDoc.ModelSpace.AddLine(Line1.StartPoint, Point5);
    OuterLoop[3] := AcadDoc.ModelSpace.AddLine(Point2, Point6);
    OuterLoop[4] := AcadDoc.ModelSpace.AddLine((OuterLoop[1] as IAcadLine).EndPoint, (OuterLoop[3] as IAcadLine).StartPoint);
    OuterLoop[5] := AcadDoc.ModelSpace.AddLine((OuterLoop[2] as IAcadLine).EndPoint, (Outerloop[3] as IAcadLine).EndPoint);
    Points[0] := Point1[0];
    Points[1] := Point1[1];
    Points[2] := Point2[0];
    Points[3] := Point2[1];
    Points[5] := BasePoint[1] + (K + Dk) / 2;
    Points[6] := Points[0];
    PL.Closed := True;
    InnerLoop[0] := PL;
    Points[0] := Point5[0];
    Points[1] := Point5[1];
    Points[2] := Point6[0];
    Points[3] := Point6[1];
    Points[5] := BasePoint[1] - (K + Dk) / 2;
    PL.Closed := True;
    InnerLoop[0] := PL;
    Points := VarArrayCreate([0, 9], varDouble);
    Points[1] := BasePoint[1] + Df / 2;
    Points[2] := Point1[0];
    Points[3] := BasePoint[1] + (K - Dk) / 2;
    Points[4] := Point2[0];
    Points[5] := Points[3];
    Points[6] := Point2[0];
    Points[7] := Point3[1] + W;
    Points[8] := Point2[0] - W + (Df - Dp) / 2;
    Points[9] := Points[1];
    PL.Closed := True;
    InnerLoop[0] := PL;
    Points[1] := BasePoint[1] - Df / 2;
    Points[3] := BasePoint[1] - (K - Dk) / 2;
    Points[7] := Point4[1] - W;
    PL.Closed := True;
    InnerLoop[0] := PL;
    Hatch.PatternScale := 1.5;
    Hatch.Evaluate;
    Hatch.Update;
    //  Draw Shell
    Point7 := SetPoint(BasePoint, 0, K / 2, 0);
    Point8 := SetPoint(Point7, tw, tw / 2, 0);
    Point9 := SetPoint(BasePoint, tw, Dp / 2, 0);
    Point10 := SetPoint(BasePoint, tw, - Dp / 2, 0);
    Point11 := SetPoint(BasePoint, 0, - K / 2, 0);
    Point12 := SetPoint(Point11, tw, tw / 2, 0);
    AcadDoc.ActiveLayer := CreateLayer('Shell', acGreen, 'Continuous');
    Line1 := AcadDoc.ModelSpace.AddLine(Point9, Point10);
    OuterLoop[1] := AcadDoc.ModelSpace.AddLine(Line1.EndPoint, Point12);
    OuterLoop[2] := AcadDoc.ModelSpace.AddLine(Line1.StartPoint, Point8);
    OuterLoop[3] := AcadDoc.ModelSpace.AddLine(Point7, Point11);
    Line1 := AcadDoc.ModelSpace.AddLine((OuterLoop[1] as IAcadLine).EndPoint, (OuterLoop[3] as IAcadLine).EndPoint);
    Line2 := AcadDoc.ModelSpace.AddLine((OuterLoop[2] as IAcadLine).EndPoint, (Outerloop[3] as IAcadLine).StartPoint);
    OuterLoop[4] := Line1;
    OuterLoop[5] := Line2;
    Points[0] := Point7[0];
    Points[1] := Point7[1];
    Points[2] := Point8[0];
    Points[3] := Point8[1];
    Points[4] := Point9[0];
    Points[5] := Point9[1] + 2 + (tw - 2) * tan(50 * PI / 180);
    Points[6] := Points[0] + 2;
    Points[7] := Point9[1] + 2;
    Points[8] := Points[0];
    PL.Closed := True;
    InnerLoop[0] := PL;
    Points[0] := Point11[0];
    Points[1] := Point11[1];
    Points[2] := Point12[0];
    Points[3] := Point12[1];
    Points[4] := Point10[0];
    Points[5] := Point10[1] - 2 - (tw - 2) * tan(50 * PI / 180);
    Points[7] := Point10[1] - 2;
    PL.Closed := True;
    InnerLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    Line1.StartPoint := SetPoint(BasePoint, - tl - 3, (K - tl - 3)/ 2, 0);
    Line1.EndPoint := SetPoint(BasePoint, tw + 3, (K + tw + 3) / 2, 0);
    Line2.StartPoint := SetPoint(BasePoint, - tl - 3, - (K + tl + 3) / 2, 0);
    Line2.EndPoint := SetPoint(BasePoint, tw + 3, (- K + tw + 3) / 2, 0);
    //  Draw Lining
    AcadDoc.ActiveLayer := CreateLayer('Lining', acRed, 'Continuous');
    Point13 := SetPoint(Point2, tl, 0, 0);
    Point14 := SetPoint(Point6, tl, 0, 0);
    Point15 := SetPoint(BasePoint, - tl, (K - tl) / 2, 0);
    Point16 := SetPoint(BasePoint, - tl, (- K - tl) / 2, 0);
    AcadDoc.ModelSpace.AddLine(Point15, Point16);
    AcadDoc.ModelSpace.AddLine(Point13, Point14);
    AcadDoc.ModelSpace.AddLine(Point2, Point13).Mirror(PC1, PC2);
    AcadDoc.ModelSpace.AddLine(SetPoint(BasePoint, L, (K + Dk) / 2, 0),
          SetPoint(BasePoint, L + tl, (K + Dk) / 2, 0)).Mirror(PC1, PC2);
    AcadDoc.ModelSpace.AddLine(SetPoint(BasePoint, L, (K - Dk) / 2, 0),
          SetPoint(BasePoint, L + tl, (K - Dk) / 2, 0)).Mirror(PC1, PC2);
    AcadDoc.ModelSpace.AddLine(SetPoint(BasePoint, R, Dp / 2 - tp - tl, 0),
          SetPoint(BasePoint, L - R, Dp / 2 - tp - tl, 0)).Mirror(PC1, PC2);
    AcadDoc.ModelSpace.AddArc(SetPoint(BasePoint, R, Dp / 2 - tp + R, 0),
          R + tl, PI, 1.5 * PI).Mirror(PC1, PC2);
    AcadDoc.ModelSpace.AddArc(SetPoint(BasePoint, L - R, Dp / 2 - tp + R, 0),
          R + tl, 1.5 * PI, 0).Mirror(PC1, PC2);
    //  Draw Welding
    AcadDoc.ActiveLayer := CreateLayer('Welding', acRed, 'Continuous');
    Points := VarArrayCreate([0, 5], varDouble);
    Hatch := AcadDoc.ModelSpace.AddHatch(0, 'Solid', True, 0);
    Points[2] := Points[0] - W;
    Points[4] := Points[0];
    Points[5] := Points[1] + W;
    PL.color := acGreen;
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    Points[0] := Point2[0];
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    Points[5] := Points[1] - W;
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    Points[1] := Point9[1];
    Points[2] := Points[0];
    Points[3] := Points[1] + 2;
    Points[4] := Points[2] + 2;
    Points[6] := Point9[0];
    Points[7] := Points[3] + (tw - 2) * tan(50 * PI / 180);
    Points[8] := Point9[0];
    Points[9] := Point9[1];
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    Points[1] := Point10[1];
    Points[3] := Points[1] - 2;
    Points[6] := Point10[0];
    Points[7] := Points[3] - (tw - 2) * tan(50 * PI / 180);
    Points[8] := Point10[0];
    Points[9] := Point10[1];
    PL.Closed := True;
    OuterLoop[0] := PL;
    Hatch.Evaluate;
    Hatch.Update;
    //  Draw Dimension
    AcadDoc.ActiveLayer := CreateLayer('Dimension', acCyan, 'Continuous');
    AcadDoc.ActiveTextStyle := CreateTextStyle('HZTXT','geditxt.shx',
                                               'hztxt.shx',0.7);
    AcadDoc.SetVariable('DIMCLRT', acYellow);
    AcadDoc.SetVariable('DIMDEC', 0);
    AcadDoc.SetVariable('DIMTXSTY', 'HZTXT');
//    DimObj := AcadDoc.ModelSpace.AddDimAligned(Point1, Point2, SetPoint(Point1, 0, 20, 0));   //就是这句会出错
//    CreateDimStyle('M10').CopyFrom(AcadDoc.ActiveDimStyle);
  finally
    if OldTextStyle <> nil then
      AcadDoc.ActiveTextStyle := OldTextStyle;
    if OldLayer <> nil then
      AcadDoc.ActiveLayer := OldLayer;
    if OldDimStyle <> nil then
      AcadDoc.ActiveDimStyle := OldDimStyle;
    SetLength(OuterLoop, 0);
    SetLength(InnerLoop, 0);
  end;
end;
function TMainForm.FindDimStyle(AName: string; var AStyle: IAcadDimStyle): Boolean;
var
  i: Integer;
begin
  Result := False;
  for i := 0 to AcadDoc.DimStyles.Count - 1 do
    if AcadDoc.DimStyles.Item(i).Name = AName then
    begin
      AStyle := AcadDoc.DimStyles.Item(i);
      Result := True;
      Break;
    end;
end;
function TMainForm.FindLayer(AName: ACAD_LAYER; var ALayer: IAcadLayer): Boolean;
var
  i: Integer;
begin
  Result := False;
  for i := 0 to AcadDoc.Layers.Count - 1 do
    if AcadDoc.Layers.Item(i).Name = AName then
    begin
      ALayer := AcadDoc.Layers.Item(i);
      Result := True;
      Break;
    end;
end;
function TMainForm.FindLineType(AName: ACAD_LTYPE): Boolean;
var
  i: Integer;
begin
  Result := False;
  for i := 0 to AcadDoc.Linetypes.Count - 1 do
    if AcadDoc.Linetypes.Item(i).Name = AName then
    begin
      Result := True;
      Break;
    end;
end;
function TMainForm.FindTextStyle(AName: string; var AStyle: IAcadTextStyle): Boolean;
var
  i: Integer;
begin
  Result := False;
  for i := 0 to AcadDoc.TextStyles.Count - 1 do
    if AcadDoc.TextStyles.Item(i).Name = AName then
    begin
      AStyle := AcadDoc.TextStyles.Item(i);
      Result := True;
      Break;
    end;
end;
function TMainForm.SetPoint(x, y, z: Double): ACAD_POINT;
begin
  Result := VarArrayCreate([0, 2], varDouble);
  Result[0] := x;
  Result[1] := y;
  Result[2] := z;
end;
function TMainForm.SetPoint(base: ACAD_POINT; x, y, z: Double): ACAD_POINT;
begin
  Result[0] := base[0] + x;
  Result[1] := base[1] + y;
  Result[2] := base[2] + z;
end;
function TMainForm.AddLine(StartPoint, EndPoint: ACAD_POINT): IAcadLine;
begin
  Result := AcadDoc.ModelSpace.AddLine(StartPoint, EndPoint);
end;
function TMainForm.AddLineReXYZ(StartPoint: ACAD_POINT; x, y, z: Double): IAcadLine;
begin
                                       SetPoint(StartPoint, x, y, z));
end;
procedure TMainForm.FormCreate(Sender: TObject);
var
  v: OleVariant;
begin
  try
    v := GetActiveOleObject('AutoCAD.Application');
    AcadDoc.ConnectTo((IDispatch(v) as IAcadApplication).ActiveDocument);
  except
    AcadDoc.Connect;
  end;
  LastDoc := AcadDoc.Path + '\' + AcadDoc.Name;
end;
procedure TMainForm.Timer1Timer(Sender: TObject);
var
  v: OleVariant;
begin
  try
    if LastDoc <> AcadDoc.Application.ActiveDocument.Name then
    begin
      try
        AcadDoc.Disconnect;
      except
      end;
      try
        LastDoc:= AcadDoc.Path + '\' + AcadDoc.Name;
      except
      end;
    end;
  except
  end;
  Caption:= LastDoc;
end;
procedure TMainForm.AcadDocObjectAdded(ASender: TObject;
begin
  AcadDoc.Utility.Prompt('Object added' + #13 + #10);
end;
procedure TMainForm.Button1Click(Sender: TObject);
begin
  DrawN1_N3(600, 1175, 1120, 1024, 42, 30, 1020, 11, 16, 8);
end;
end.
报的错误如下图
已领礼包: 12个
发表于 2006-6-8 01:15:32 | 显示全部楼层
代码没有贴全吧?
var
v: OleVariant;
begin
try
begin
try
AcadDoc.Disconnect;
except
end;
try
LastDoc:= AcadDoc.Path + '' + AcadDoc.Name;
except
end;
end;
except
end;
Caption:= LastDoc;
end;
connect ,connectto ,disconnect 在哪里定义了?
我改了一下,将Timer1删除,将MainForm.FormCreate内容删除,在TMainForm.Button1Click中加入与AutoCAD联系的相应语句,编译后无错误。
生成的应用程序传可以给你看看,是否符合要求。
给我发email:taoh@whjs.gov.cn
我传给你。
 楼主| 发表于 2006-6-9 13:25:50 | 显示全部楼层
connect ,connectto ,disconnect是导入ACAD的对象库时自动生成的TAcadDocument的方法
已领礼包: 12个
发表于 2006-6-10 17:15:14 | 显示全部楼层
能否留下你的QQ或email,我们交交流。
 楼主| 发表于 2006-6-12 19:48:17 | 显示全部楼层
ttthhh_hb [] 大侠,我的邮箱是yy29@21cn.com,我给你发了邮件的,可总被退回来,不知怎么回事
已领礼包: 12个
发表于 2006-6-13 01:22:41 | 显示全部楼层
可能是自动拦截了。我将你的邮箱添加到白名单中了。你再试试。
我的邮箱:  taoh@whjs.gov.cn
 楼主| 发表于 2006-6-14 11:11:48 | 显示全部楼层
大哥,还是被退回了啊,我的QQ:348678992
已领礼包: 12个
发表于 2006-6-15 21:11:07 | 显示全部楼层
我QQ: 305991220
另外我的另一个邮箱:taohua_hb@yahoo.com.cn
 楼主| 发表于 2006-6-20 18:08:04 | 显示全部楼层
大侠,给你的邮箱发了信,收到没有?
已领礼包: 12个
发表于 2006-6-21 00:11:21 | 显示全部楼层
收到了。
最近网络不好,未能给你回信,非常抱歉。
 楼主| 发表于 2006-6-26 12:56:52 | 显示全部楼层
大侠,能把您的代码发给我看看吗?
已领礼包: 12个
发表于 2006-6-29 00:08:34 | 显示全部楼层
已发到你的邮箱,请查收.
发表于 2006-7-6 11:31:45 | 显示全部楼层
爽  好东西
谢谢
GMT+8, 2026-11-3 11:30 , Processed in 0.599719 second(s), 61 queries , Gzip On.
