查看: 1265|回复: 3
[求助] [求助]:求lsp,关于字符串的修改.
发表于 2006-6-5 16:08:11 | 显示全部楼层 |阅读模式
求lsp,关于字符串的修改.
在一字符串中等间距的插入一字符串,
l例如:有一字符串“43543gfdg345657h34tggerg5544dt65897908”
要隔4个字符插入另一字符“aa,”
变为:“4354aa,3gfdaa,g345aa,657haa,34tgaa,gergaa,5544aa,dt65aa,8979aa,08”
已领礼包: 9347个
发表于 2006-6-5 17:07:11 | 显示全部楼层
  1. (defun c:test ( / str InsTxt idx strss)
  2.    (setq str    "43543gfdg345657h34tggerg5544dt65897908"
  3.       InsTxt "aa, "
  4.          idx 1
  5.    )
  6.    (setq strss nil)
  7.    (repeat (fix (/ (strlen str) 4))
  8.      (setq strss (cons (substr str idx 4) strss)
  9.              idx (+ idx 4)
  10.    ) )
  11.    (setq strss
  12.      (apply
  13.        'strcat
  14.          (mapcar
  15.            (function
  16.              (lambda (x) (strcat x InsTxt))
  17.            )
  18.            (reverse strss)
  19.      )  )
  20.    )
  21.    (setq strss (strcat strss (substr str idx)))
  22. )
 楼主| 发表于 2006-6-16 18:02:43 | 显示全部楼层
要隔4个字符插入字符“aa”,“,”
变为:“aa4354,aa3gfd,aag345,aa657h,aa34tg,aagerg,aa5544,aadt65,aa8979,08”
如何??
发表于 2006-6-17 15:27:06 | 显示全部楼层
仔细研究一下字符串函数,你自己就可以写了,很简单
GMT+8, 2026-11-7 04:49 , Processed in 0.453805 second(s), 37 queries , Gzip On.
