查看: 949|回复: 2
[VBA程序]:求助:关于optional
发表于 2006-6-9 09:49:27 | 显示全部楼层 |阅读模式
请高手帮我看一下如下代码,代码意图是要求最小值,比较的值不少于2个,其他可选,但是执行结果不对,虽然我知道optional对double数据类型不起作用,但如何解决?
Public Function MinN(a1 As Double, a2 As Double, _
Optional a3, Optional a4, _
Optional a5, Optional a6, _
Optional a7, Optional a8, _
Optional a9, Optional a10) As Double   '求最小值
Dim Xxx As Double
Xxx = a1
If a2 < Xxx Then
    Xxx = a2
    'MsgBox a2
End If
If Not IsMissing(a3) And a3 < Xxx Then
    Xxx = a3
    MsgBox a3
End If
If Not IsMissing(a4) And a4 < Xxx Then
    Xxx = a4
End If
If Not IsMissing(a5) And a5 < Xxx Then
    Xxx = a5
End If
If Not IsMissing(a6) And a6 < Xxx Then
    Xxx = a6
End If
If Not IsMissing(a7) And a7 < Xxx Then
    Xxx = a7
End If
If Not IsMissing(a8) And a8 < Xxx Then
    Xxx = a8
End If
If Not IsMissing(a9) And a9 < Xxx Then
    Xxx = a9
End If
If Not IsMissing(a10) And a10 < Xxx Then
    Xxx = a10
End If
MinN = Xxx
End Function
发表于 2006-6-10 11:43:49 | 显示全部楼层
Function Min(ParamArray vals())
    Min = vals(0)
    For i = 1 To UBound(vals)
        If Min > vals(i) Then Min = vals(i)
    Next i
End Function
 楼主| 发表于 2006-6-13 11:42:43 | 显示全部楼层
多谢斑竹,哈哈,还是帮助的不想看,看了就不用麻烦斑竹了,再次感谢
GMT+8, 2026-11-3 06:06 , Processed in 0.512292 second(s), 36 queries , Gzip On.
