查看: 886|回复: 1
[求助] [求助]:谁能编一个这样的求面积的工具??
发表于 2006-6-9 10:53:04 | 显示全部楼层 |阅读模式
急需一个求面积的工具,就是同时选多个封闭曲线,可以直接求出它们的面积和的工具,那位大侠帮帮忙做一个啊
已领礼包: 12496个
发表于 2006-6-9 12:01:24 | 显示全部楼层
  1. (DEFUN C:SUMAREA ()
  2. (SETVAR "CMDECHO" 0)
  3. (COMMAND ".UNDO" "BE")
  4. (IF (SETQ SS (SSGET '((0 . "*POLYLINE") (70 . 1)))) (PROGN
  5.   (SETQ I -1 SUM 0.0)
  6.   (REPEAT (SSLENGTH SS)
  7.    (SETQ EN (SSNAME SS (SETQ I (1+ I))))
  8.    (COMMAND "AREA" "E" EN)
  9.    (SETQ SUM (+ (GETVAR "AREA") SUM))
  10.   )
  11.   (PRINC "\nTotal Area = ")
  12.   (PRINC SUM)
  13. ))
  14. (COMMAND ".UNDO" "E")
  15. (SETVAR "CMDECHO" 1)
  16. (PRINC)
  17. )
GMT+8, 2026-11-7 04:35 , Processed in 0.393586 second(s), 34 queries , Gzip On.
