查看: 1489|回复: 3
[LISP程序]:一个简捷实用的修改多义线子段宽度的小程序
发表于 2003-5-22 09:17:24 | 显示全部楼层 |阅读模式
踏破铁鞋无觅处,的来全不费工夫-
点击多义线的子段变知其所在多义线的索引号:
(defun c:test ()
  (setq a (entsel "Pick Polyline:"))
  (setq d (vlax-ename->vla-object (car a)))
  (setq p (vlax-curve-getclosestpointto d (trans (cadr a) 1 0)))
  (setq n (fix (vlax-curve-getparamatpoint d p)))
);defun
 楼主| 发表于 2003-5-22 09:29:53 | 显示全部楼层
[LISP程序]:请看, 一个简捷实用的修改多义线子段宽度的小程序!
  1. (defun c:test ()
  2.   (vl-load-com)
  3.   (setq a (entsel "Pick Polyline:"))
  4.   (initget 7)
  5.   (setq w (getreal "Input Width:"))
  6.   (setq d (vlax-ename->vla-object (car a)))
  7.   (setq p (vlax-curve-getclosestpointto d (trans (cadr a) 1 0)))
  8.   (setq n (fix (vlax-curve-getparamatpoint d p)))
  9.   (vlax-invoke-method d 'setwidth n w w)
  10. );defun
已领礼包: 488个
发表于 2003-5-22 21:25:39 | 显示全部楼层
spline不行
发表于 2003-5-22 22:59:48 | 显示全部楼层
不错,
是关键。受教,呵呵
GMT+8, 2026-11-3 19:11 , Processed in 0.486913 second(s), 38 queries , Gzip On.
