查看: 986|回复: 2
[求助] [求助]:看看这个ykfsx.lisp是为什么
发表于 2006-6-14 00:25:09 | 显示全部楼层 |阅读模式
我运行过liispykfsx这个程式后再用其它程式点选插入点运行后就会出参数错误,怎么改一下呢
已领礼包: 593个
发表于 2006-6-14 00:41:42 | 显示全部楼层
  1. (defun c:YKFSX (/ a d d1 d2 d3 d4 d5 l p0 p0x p0y p1 p1y p2 p2x p2y p3 p4 p5
  2.                   pc pcx pcy pd pdx pe pey pf pg pgx ph phx pi pj pjx pjy
  3.                )
  4.   (setvar "cmdecho" 0)
  5.   (setq l (getreal "\n顶料销有效长度:"))
  6.   (setq d (getreal "\n顶料销直径:"))
  7.   (setq a (getreal "\n插针孔直径:"))
  8.   (setq p0 (getpoint "\n选取生成位置:"))
  9.   (setq p0x (car p0)
  10.         p0y (cadr p0)
  11.   )
  12.   (setq p1y (- p0y (+ l 14))
  13.         p1 (list p0x p1y)
  14.   )
  15.   (if (> a 0)
  16.     (progn
  17.       (setq p2x (- p0x (/ a 2))
  18.             p2y (- p0y 5)
  19.             P2 (list p2x p2y)
  20.       )
  21.       (setq p3 (list (+ p2x a) p2y)
  22.             d4 (list p2x (+ p2y 15))
  23.       )
  24.       (setq p4 (list p2x (- p2y (+ l 4)))
  25.             p5 (list (+ p2x a) (- p2y (+ l 4)))
  26.       )
  27.       (command "layer" "s" "dim" "" "dim" "hor" p2 p3 d4 "%%c<>" "e" "layer"
  28.                "s" "p8" "" "line" "none" p2 "none" p4 "" "line" "none" p3
  29.                "none" p5 ""
  30.       )
  31.     )
  32.   )
  33.   (setvar "osmode" 0)
  34.   (command "layer" "s" "center" "" "line" p0 p1 "" "layer" "s" "0" "")
  35.   (setvar "osmode" 550)
  36.   (setq pc (list (- p0x (/ d 2)) (- p0y 5))
  37.         pd (list (+ p0x (/ d 2)) (- p0y 5))
  38.         pcy (cadr pc)
  39.         pcx (car pc)
  40.         pdx (car pd)
  41.   )
  42.   (setq pe (list pcx (- pcy l))
  43.         pf (list pdx (- pcy l))
  44.         pey (cadr pe)
  45.   )
  46.   (setq pg (list (- pcx 1) pey)
  47.         ph (list (+ pdx 1) pey)
  48.         pgx (car pg)
  49.         phx (car ph)
  50.   )
  51.   (setq pi (list pgx (- pey 4))
  52.         pj (list phx (- pey 4))
  53.         pjx (car pj)
  54.         pjy (cadr pj)
  55.   )
  56.   (command "line" "none" pe "none" pc "none" pd "none" pf "" "line" "none"
  57.            pg "none" ph "none" pj "none" pi "c"
  58.   )
  59.   (setq d1 (list (- pcx 20) pcy)
  60.         d2 (list (- pcx 10) pcy)
  61.         d3 (list pcx (+ pcy 8))
  62.         d5 (list pjx (- pjy 8))
  63.   )
  64.   (command "layer" "s" "dim" "" "dim" "ver" pi pc d1 "" "ver" pg pc d2 ""
  65.            "hor" pc pd d3 "%%c<>" "hor" pi pj d5 "%%c<>" "e" "layer" "s" "0"
  66.            ""
  67.   )
  68.   (setvar "clayer" "0")
  69.   (setvar "osmode" 1)
  70.   (setvar "cmdecho" 1)
  71.   (princ)
  72. )
已领礼包: 6个
发表于 2006-6-19 09:36:01 | 显示全部楼层
CAD提示:
用户警告: 给保护符号赋值: PI
  3.         pjx (car pj)
  4.         pjy (cadr pj)
  5.   )
GMT+8, 2026-11-7 04:50 , Processed in 0.653039 second(s), 36 queries , Gzip On.
