查看: 1113|回复: 3
[VBA函数]:请问如何在屏幕中获取点?
发表于 2002-5-15 03:16:53 | 显示全部楼层 |阅读模式
在Lisp中可用Getpoint来获取屏幕中的点,在VBA中用什么方法来获取?
请高手指教!!
发表于 2002-5-15 03:42:54 | 显示全部楼层
例子:来自帮助
Sub Example_GetPoint()
    ' This example returns a point entered by the user.
    Dim returnPnt As Variant
    ' Return a point using a prompt
    returnPnt = ThisDrawing.Utility.GetPoint(, "Enter a point: ")
    MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2) & vbCrLf & _
            "(Enter the next value without prompting.)", , "GetPoint Example"
    ' Return a point, no prompt
    MsgBox "The WCS of the point is: " & returnPnt(0) & ", " & returnPnt(1) & ", " & returnPnt(2), , "GetPoint Example"
    ' Return a point using a base point and a prompt
    Dim basePnt(0 To 2) As Double
    basePnt(0) = 2#: basePnt(1) = 2#: basePnt(2) = 0#
    returnPnt = ThisDrawing.Utility.GetPoint(basePnt, "Enter a point: ")
    ' Create a line from the base point and the last point entered
    Dim lineObj As AcadLine
    Set lineObj = ThisDrawing.ModelSpace.AddLine(basePnt, returnPnt)
    ZoomAll
End Sub
已领礼包: 181个
发表于 2002-5-18 07:47:30 | 显示全部楼层
在VBA中,如果选择的不是有效的将产生错误,可以用on error resume next屏蔽错误,或用on error goto XXX捕捉错误。
发表于 2002-7-24 16:58:56 | 显示全部楼层
难道vba要比Lisp麻烦这么多吗?
一个是一大堆,另一个只有一个词?
GMT+8, 2026-11-2 16:41 , Processed in 1.104923 second(s), 38 queries , Gzip On.
