查看: 809|回复: 3
[ARX函数]:如何加载图块>?>?
发表于 2006-6-27 20:25:35 | 显示全部楼层 |阅读模式
我想在 当前图形中加载 B 图中的一个块,假设B图是在 d:\B.dwg在磁盘上
请问如何操作?????
谢谢
发表于 2006-6-27 22:16:29 | 显示全部楼层
insert wblock
发表于 2006-7-1 12:46:07 | 显示全部楼层
别人的程序:
AcDbDatabase *pNewDb =new AcDbDatabase(Adesk::kFalse);
                        int        es=pNewDb->readDwgFile(dwgpath , _SH_DENYNO, false);
                        if (es!=Acad::eOk)
                        acutPrintf("\nThe file %s cannot be opend",dwgpath);
                        return;
                AcDbDatabase *pDb;
                pDb =acdbHostApplicationServices ()->workingDatabase () ;*/
        //        pDb->insert( AcGeMatrix3d::kIdentity, pNewDb );
                  CString pBlockName="TestBlock";
                                             AcDbObjectId blockId;
                                             if((es=pDb->insert(blockId, pBlockName,pNewDb, true))==Acad::eOk)
                                             acutPrintf("\ninsert ok\n");
                                             else
                                             AfxMessageBox("Insert failed");
                                             delete pNewDb;
                                             return;
                    const AcGePoint3d& Pt=AcGePoint3d(0,0,0);
                          double Angle=0;
                          double XrefScale=0;
                          AcDbBlockReference *pBlkRef = new AcDbBlockReference;
                          pBlkRef->setBlockTableRecord(blockId);//指向blockId;
                          pBlkRef->setPosition(Pt);//设定位置
                          pBlkRef->setRotation(Angle);//设定转角
                          pBlkRef->setScaleFactors( XrefScale);//设定放大比例
                                    AcDbBlockTable *pBlockTable;
                                    pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
                                          AcDbBlockTableRecord *pBlockTableRecord;
                                          pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForWrite);
                                          pBlockTable->close();
                                          AcDbObjectId newEntId;
                                          pBlockTableRecord->appendAcDbEntity(newEntId, pBlkRef);
                                          pBlockTableRecord->close();
                                            AcDbBlockTableRecord *pBlockDef;
                                            acdbOpenObject(pBlockDef, blockId, AcDb::kForRead);
                                                  AcDbBlockTableRecordIterator *pIterator;
                                                  pBlockDef->newIterator(pIterator);
                                                  AcGePoint3d basePoint;
                                                  AcDbEntity *pEnt;
                                                  AcDbAttributeDefinition *pAttdef;
                                                  for (pIterator->start(); !pIterator->done();
                                                  pIterator->step())//将source.dwg中所有的Attibute进行遍历
                                                  pIterator->getEntity(pEnt, AcDb::kForRead);
                                                  pAttdef = AcDbAttributeDefinition::cast(pEnt);
                                                  if (pAttdef != NULL && !pAttdef->isConstant()) {
                                                  AcDbAttribute *pAtt = new AcDbAttribute();
                                                  pAtt->setPropertiesFrom(pAttdef);
                                                  pAtt->setInvisible(pAttdef->isInvisible());
                                                  basePoint = pAttdef->position();
                                                  basePoint += pBlkRef->position().asVector();
                                                  pAtt->setPosition(basePoint);
                                                  pAtt->setHeight(pAttdef->height());
                                                  pAtt->setRotation(pAttdef->rotation());
                                                  pAtt->setTag("Tag");
                                                  pAtt->setFieldLength(25);
                                                  char *pStr = pAttdef->tag();
                                                  pAtt->setTag(pStr);
                                                  //                        acutDelString(pStr);
                                                  pAtt->setFieldLength(pAttdef->fieldLength());
                                                  pAtt->setTextString("-");
                                                    AcDbObjectId attId;
                                                          pBlkRef->appendAttribute(attId, pAtt);
                                                          pAtt->close();
                                                          pEnt->close(); // use pEnt... pAttdef might be NULL
                                                          delete pIterator;
发表于 2006-7-3 12:43:44 | 显示全部楼层
厉害
GMT+8, 2026-11-4 23:08 , Processed in 0.420454 second(s), 38 queries , Gzip On.
