查看: 1460|回复: 4
[求助] [求助]:怎样用VLISP 获得计算机的主板或CPU的序列号
发表于 2006-7-1 23:14:04 | 显示全部楼层 |阅读模式
发表于 2006-7-2 09:23:55 | 显示全部楼层
呵呵,有什么好程序?
先拿上来大家试用试用?
等大家对你的程序已经认可,那你就可以加密了。
仅仅是建议。。。。。。。
要加密,看wkai  的AUT工具:
http://p4.xdcad.net/forum/showth ... 1122630#post1122630
或直接与wkai 联系吧。
 楼主| 发表于 2006-7-4 22:21:30 | 显示全部楼层
各位大侠,帮帮忙我是想学习怎么加密
已领礼包: 593个
发表于 2006-7-5 02:11:54 | 显示全部楼层
独立的 Lisp 获取这些是有限制的(要管理权限等,具体可查MS的MSDN中关于WMI部分),在函数库论坛有获取 硬盘、网卡 ID 的函数,至于获取主板和CPU的你可以参照那两个函数自己写出来,下面是利用 VbsEdit 自动生成的一个关于 Processor 的脚本,ProcessorID 就是 CPU ID
[php]
On Error Resume Next
strComputer = "."
Set objWMIService = GetObject("winmgmts:\\" & strComputer & "\root\cimv2")
Set colItems = objWMIService.ExecQuery("Select * from Win32_Processor",,48)
For Each objItem in colItems
        WScript.Echo "AddressWidth: " & objItem.AddressWidth
        WScript.Echo "Architecture: " & objItem.Architecture
        WScript.Echo "Availability: " & objItem.Availability
        WScript.Echo "Caption: " & objItem.Caption
        WScript.Echo "ConfigManagerErrorCode: " & objItem.ConfigManagerErrorCode
        WScript.Echo "ConfigManagerUserConfig: " & objItem.ConfigManagerUserConfig
        WScript.Echo "CpuStatus: " & objItem.CpuStatus
        WScript.Echo "CreationClassName: " & objItem.CreationClassName
        WScript.Echo "CurrentClockSpeed: " & objItem.CurrentClockSpeed
        WScript.Echo "CurrentVoltage: " & objItem.CurrentVoltage
        WScript.Echo "DataWidth: " & objItem.DataWidth
        WScript.Echo "Description: " & objItem.Description
        WScript.Echo "DeviceID: " & objItem.DeviceID
        WScript.Echo "ErrorCleared: " & objItem.ErrorCleared
        WScript.Echo "ErrorDescription: " & objItem.ErrorDescription
        WScript.Echo "ExtClock: " & objItem.ExtClock
        WScript.Echo "Family: " & objItem.Family
        WScript.Echo "InstallDate: " & objItem.InstallDate
        WScript.Echo "L2CacheSize: " & objItem.L2CacheSize
        WScript.Echo "L2CacheSpeed: " & objItem.L2CacheSpeed
        WScript.Echo "LastErrorCode: " & objItem.LastErrorCode
        WScript.Echo "Level: " & objItem.Level
        WScript.Echo "LoadPercentage: " & objItem.LoadPercentage
        WScript.Echo "Manufacturer: " & objItem.Manufacturer
        WScript.Echo "MaxClockSpeed: " & objItem.MaxClockSpeed
        WScript.Echo "Name: " & objItem.Name
        WScript.Echo "OtherFamilyDescription: " & objItem.OtherFamilyDescription
        WScript.Echo "PNPDeviceID: " & objItem.PNPDeviceID
        WScript.Echo "PowerManagementCapabilities: " & objItem.PowerManagementCapabilities
        WScript.Echo "PowerManagementSupported: " & objItem.PowerManagementSupported
        WScript.Echo "ProcessorId: " & objItem.ProcessorId
        WScript.Echo "ProcessorType: " & objItem.ProcessorType
        WScript.Echo "Revision: " & objItem.Revision
        WScript.Echo "Role: " & objItem.Role
        WScript.Echo "SocketDesignation: " & objItem.SocketDesignation
        WScript.Echo "Status: " & objItem.Status
        WScript.Echo "StatusInfo: " & objItem.StatusInfo
        WScript.Echo "Stepping: " & objItem.Stepping
        WScript.Echo "SystemCreationClassName: " & objItem.SystemCreationClassName
        WScript.Echo "SystemName: " & objItem.SystemName
        WScript.Echo "UniqueId: " & objItem.UniqueId
        WScript.Echo "UpgradeMethod: " & objItem.UpgradeMethod
        WScript.Echo "Version: " & objItem.Version
        WScript.Echo "VoltageCaps: " & objItem.VoltageCaps
        WScript.Echo ""
Next
[/php]
关于主板的 VBS,不过这个获取成功的较少
[php]
strComputer = "."
Set colItems = objWMIService.ExecQuery("Select * from Win32_MotherboardDevice",,48)
        WScript.Echo "PrimaryBusType: " & objItem.PrimaryBusType
        WScript.Echo "RevisionNumber: " & objItem.RevisionNumber
        WScript.Echo "SecondaryBusType: " & objItem.SecondaryBusType
        WScript.Echo ""
Next[/php]
资料:
http://www.microsoft.com/china/t ... pmgmt/scrcm128.mspx
利用WMI获取硬盘物理ID
http://www.xdcad.net/forum/showthread.php?s=&threadid=461170
 楼主| 发表于 2006-7-11 18:18:23 | 显示全部楼层
各位大哥大姐,我是一个菜鸟,请您告诉我这些脚本怎么运行
GMT+8, 2026-11-7 05:29 , Processed in 0.518196 second(s), 39 queries , Gzip On.
