查看: 1148|回复: 3
[日积月累]:关于Dxf 的 group code 谁有详细说明!??
发表于 2006-7-25 14:33:33 | 显示全部楼层 |阅读模式
如题,谢谢,!daijunjie@sina.com
发表于 2006-7-25 17:28:44 | 显示全部楼层
Data Type    DXF Group Code Range         Group Code Description
Strings            1-4, 7, 9, 300 - 309 255        characters maximum; less for Unicode strings
. ;                  100                                       Must only be used for Subclass data markers (255 characters maximum; less for Unicode strings)
102               Control string (255 characters maximum; less for Unicode strings). A control sting is either "{ <arbitrary name>" or "}".
Points, Vectors, and Scale objects (2D & 3D double precision) 10 - 17 Double precision 2D & 3D point, vector, or scale
20 - 27, 30 - 37 Y & Z 3D point coordinates. These group codes are automatically generated or absorbed by the ObjectARX internal filers when filing to or from a DXF file
Double precision values 40 - 47, 49, 140 - 147 General purpose
50 - 59 For angles. Must be in radians when passed-to or read-from the filer. The filer converts to or from degrees when filing out-to or in-from DXF files
Integers 61, 63 - 66, 68 - 79, 170 - 175 16-bit integer value
90 - 99 32-bit integer value
280 - 289 8-bit integer value
Binary chunks 310 - 319 String representing hex value of binary chunk
ObjectIds 320 - 329 Arbitrary IDs. No translation during INSERT and XREF operations
330 - 339 Soft Pointer ID. Translated during INSERT and XREF operations
340 - 349 Hard Pointer ID. Translated during INSERT and XREF operations
350 - 359 Soft Ownership ID. Translated during INSERT and XREF operations
360 - 369 Hard Ownership ID. Translated during INSERT and XREF operations
发表于 2006-7-26 13:06:55 | 显示全部楼层
我有Dxf2000格式所有中文说明!
发表于 2006-7-28 11:52:53 | 显示全部楼层
怎么下不下来,麻烦能给我发一份吗?谢谢
ddpo@163.com
GMT+8, 2026-11-4 22:54 , Processed in 0.652399 second(s), 39 queries , Gzip On.
