查看: 1334|回复: 4
[求助] [求助]:请大家帮帮我
发表于 2006-7-31 13:30:28 | 显示全部楼层 |阅读模式
请问各位高手怎样根据坐标文件画pl线.想料好长时间都没想起!谢谢
已领礼包: 12484个
发表于 2006-7-31 21:20:09 | 显示全部楼层
坐标文件的格式是什么样的?
 楼主| 发表于 2006-8-1 07:45:39 | 显示全部楼层
点号,x,y麻烦了
发表于 2006-8-1 08:14:20 | 显示全部楼层
  1. [FONT=courier new];;;20060312
  2. ;;;数据格式:17,12.003,50.401,4.875
  3. (defun c:test105a ()
  4.   (vl-load-com)
  5.   (alert
  6.     "数据格式:
  7.     \n编号,x坐标,y坐标,z坐标,
  8.     编号,x坐标,y坐标,z坐标,
  9.     编号,x坐标,y坐标,z坐标,
  10.     ..."
  11.   )
  12.   (if (not
  13.         (setq
  14.           fle (findfile
  15.                 (getfiled "坐标数据文件(txt;dat;*)" "" "txt;dat;*" 2)
  16.               )
  17.         )
  18.       )
  19.     (setq fle (getfiled "请选择数据文件" "txt1" "txt;dat;*" 8))
  20.   )
  21.   (if fle
  22.     (progn
  23.       (setq fn (open fle "r"))
  24.       (prompt "\n稍候 ")
  25.       (command "3dpoly")
  26.       (while (setq pt (read-line fn))
  27.         (while (vl-string-search "," pt)
  28.           (setq pt (vl-string-subst " " "," pt))
  29.         )
  30.         (princ ".")
  31.         (setq pt (cdr (read (strcat "(" pt ")"))))
  32.         (command pt)
  33.       )
  34.       (command "")
  35.       (close fn)
  36.     )
  37.     (princ "\n未选择数据文件,退出")
  38.   )
  39.   (prompt " 完毕!")
  40.   (princ)
  41. )[/FONT]
 楼主| 发表于 2006-8-3 08:13:43 | 显示全部楼层
谢谢!我也作好一个了.
GMT+8, 2026-11-3 13:53 , Processed in 0.444955 second(s), 40 queries , Gzip On.
