查看: 1124|回复: 3
[求助]:[求助]:[求助]:求助,请专家救助!!
发表于 2006-8-4 11:23:43 | 显示全部楼层 |阅读模式
我的电脑不能装CAD2006,请问怎么解决?安装到“正在安装.NET Framework Runtime 1.1 Language Pack”时提示:已终止AUTOCAD2006-Simplified Chinese 安装。请检查安装日志。
我查看安装日志,提示:
[8/4/2006 11:16:56] === Installation started on SHANG-ZH by shang_zh ===
[8/4/2006 11:16:58] [Info] Windows Installer upgrade is not required
[8/4/2006 11:16:58]   System Version = 3.1.4000.2435
[8/4/2006 11:16:58] Installation skipped: MSI Runtime 3.0
[8/4/2006 11:16:58] [Info] .NET Framework Runtime upgrade is not required
[8/4/2006 11:16:58]   System Version = 2.0.50727.42
[8/4/2006 11:16:58] Installation skipped: .NET Framework Runtime 1.1
[8/4/2006 11:16:58] Installation started: .NET Framework Runtime 1.1 Language Pack
[8/4/2006 11:16:58]   Command = "\\Soft-server\资源大全\常用软件\CAD软件\cad2006\Bin\AcadFEUI\support\dotnetfx\chs\langpack.exe" /q:a /c:"inst /qb"
[8/4/2006 11:16:59] [Error: 1603] 安装时发生严重错误
[8/4/2006 11:16:59] Installation failed: .NET Framework Runtime 1.1 Language Pack
[8/4/2006 11:16:59] Installation aborted
[8/4/2006 11:22:35] === Installation ended ===
请各位高手指点!!
发表于 2006-8-4 11:29:51 | 显示全部楼层
把系统还原一下.
发表于 2006-8-4 11:59:09 | 显示全部楼层
内存够不够
发表于 2006-8-5 11:32:13 | 显示全部楼层
能不能发一个CAD2006的版本给我。我的还是2005版本
GMT+8, 2026-10-18 07:34 , Processed in 0.605470 second(s), 37 queries , Gzip On.
