查看: 1336|回复: 4
[求助]:我连接sql怎么总是出错?
发表于 2006-8-19 09:03:39 | 显示全部楼层 |阅读模式
这是我的一个读取sql里数据的vb,库里有很多条记录的,我怎么只能读出其中的第一条记录呀?高手们帮我看看吧!
Private Sub hb_Click()
Dim ysjlj As New ADODB.Connection
Dim ygg01 As New ADODB.Recordset
Dim xsjlj As New ADODB.Connection
Dim xgg01 As New ADODB.Recordset
Dim ygg1, xgg1 As String
Dim yljzfc, xljzfc, ysj, xsj As String '源新数据库连接字符串
yljzfc = "provider=sqloledb.1;password=" & yyhmm.Text & ";persist security info=true;user id=" & yyhm.Text & ";initial catalog=" & ysjk.Text & " ;data source=" & yfwq.Text & ""
ysjlj.Open yljzfc '连接源数据库
xljzfc = "provider=sqloledb.1;password=" & xyhmm.Text & ";persist security info=true;user id=" & xyhm.Text & ";initial catalog=" & xsjk.Text & " ;data source=" & xfwq.Text & ""
xsjlj.Open xljzfc '连接源数据库
'xsj = " select * into gg1 from gg01 where ga01='1'"
'xgg01.Open xsj, xsjlj, adOpenKeyset, adLockPessimistic '在新数据库中新建gg1表
'xgg01.Close
'下面将源数据库中gg01表的内容导入到gg1表中。
ysj = "select *from gg01 where ga033='114'"
ygg01.Open ysj, ysjlj, adOpenKeyset, adLockPessimistic
xsj = "select * from gg1"
i = 0
If Not ygg01.EOF Then
i = i + 1
xgg01.AddNew
xgg01.Fields("ga01") = ygg01.Fields("ga01")
xgg01.Fields("ga18") = ygg01.Fields("ga18")
xgg01.Fields("ga03") = ygg01.Fields("ga03")
xgg01.Fields("ga04") = ygg01.Fields("ga04")
'xgg01.Update
'Print ygg01.Fields("ga18")
ygg01.MoveNext
xgg01.MoveNext
Else
'ygg01.Close
'xgg01.Close
'Exit Sub
End If
Print i
;我的i值怎么都是1,可是我的库里有很多行的.
发表于 2006-8-19 13:24:05 | 显示全部楼层
用while循环,而不是if
 楼主| 发表于 2006-8-19 15:33:23 | 显示全部楼层
谢谢朋友!为什么用不行呢?
发表于 2006-9-4 10:54:30 | 显示全部楼层
Recordset记录集默认指针为第一行记录
应为:
do while  not ygg01.eof
   xgg01.AddNew
      ygg01.MoveNext
loop
xgg01.Update
 楼主| 发表于 2006-9-9 09:34:42 | 显示全部楼层
谢谢各位朋友们
GMT+8, 2026-11-22 10:38 , Processed in 0.425511 second(s), 16 queries , Gzip On, File On.
