查看: 1954|回复: 3
[ARX程序]:拖动的问提
发表于 2002-5-18 03:41:16 | 显示全部楼层 |阅读模式
本想通过选二直线的交点,来拖动此二直线的位置
结果,屏幕上出了一堆射线一样的怪东西
程序如下:
// LineJig.h: interface for the LineJig class.
#include "dbpl.h"
class LineJig : public AcEdJig
public:
        LineJig(const AcGePoint3d point1,const AcGePoint3d point2,const AcGePoint3d point3);
        void doIt();
        virtual DragStatus sampler();
        virtual Adesk::Boolean update();
        virtual ~LineJig();
        virtual AcDbEntity* entity()const;
private:
        AcGePoint3d mPoint;
        AcGePoint3d sPoint;
        AcGePoint3d ePoint;
    AcDbPolyline* pPolyLine;
// LineJig.cpp: implementation of the LineJig class.
#include "stdafx.h"
#include "resource.h"
#include "LineJig.h"
#include "dbjig.h"
#include "stdarx.h"
#include "geassign.h"
#include "geent3d.h"
#include "acdb.h"
#include "dbents.h" // 'old' 2D polyline
#include "dbcurve.h" // Curve base class
#include "dbmain.h" // Entity base class
#include "acgi.h"
#include "acedads.h"
#include "dbapserv.h"
#ifdef _DEBUG
#undef THIS_FILE
static char THIS_FILE[]=__FILE__;
#define new DEBUG_NEW
#endif
static AcGePoint3d midPoint;
// Construction/Destruction
LineJig::LineJig(const AcGePoint3d point1,const AcGePoint3d point2,const AcGePoint3d point3)
        sPoint=point1;
        mPoint=point2;
        ePoint=point3;
        pPolyLine=new AcDbPolyline();
        AcGePoint2d sPoint1,mPoint1,ePoint1;
        sPoint1.x=sPoint.x;
        sPoint1.y=sPoint.y;
        mPoint1.x=mPoint.x;
        mPoint1.y=mPoint.y;
        ePoint1.x=ePoint.x;
        ePoint1.y=ePoint.y;
        pPolyLine->addVertexAt(0,sPoint1);
    pPolyLine->addVertexAt(1,mPoint1);
        pPolyLine->addVertexAt(2,ePoint1);
LineJig::~LineJig()
void LineJig::doIt()
//        AcDbLine* line1=new AcDbLine(sPoint,mPoint);
//        AcDbLine* line2=new AcDbLine(mPoint,ePoint);
        AcEdJig::DragStatus stat;
        setDispPrompt("\n请重新选择交点:");
    stat=drag();
        if(stat=kNormal)
           append();
        else
           delete pPolyLine;
AcEdJig::DragStatus LineJig::sampler()
        DragStatus stat=kNormal;
        setUserInputControls((UserInputControls)
                (AcEdJig::kAccept3dCoordinates));
        stat=acquirePoint(midPoint,sPoint);
        if(midPoint!=mPoint)
                mPoint=midPoint;
        else if(stat==AcEdJig::kNormal)
                return AcEdJig::kNoChange;
        return stat;
Adesk::Boolean LineJig::update()
        sPoint1.x=sPoint.x;
        sPoint1.y=sPoint.y;
        mPoint1.x=mPoint.x;
        mPoint1.y=mPoint.y;
        ePoint1.x=ePoint.x;
        ePoint1.y=ePoint.y;
        return Adesk::kTrue;
AcDbEntity* LineJig::entity()const
        return pPolyLine;
// This is command 'CRTPLINE'
void chencrtpline()
        // TODO: Implement the command
   ads_point joinPt;
   if(acedGetPoint(NULL,"\n请选择一个交点:",joinPt)==RTNORM);
        ads_name ssname;
        char sbuf[10];
    strcpy(sbuf,"LINE");
    struct resbuf eb;
    eb.restype=0;
    eb.resval.rstring=sbuf;
    eb.rbnext=NULL;
    ads_point pt1, pt2;
    pt1[X] = joinPt[X] - 1;
    pt2[X] = joinPt[X] + 1;
    pt1[Y] = joinPt[Y] - 1;
    pt2[Y] = joinPt[Y] + 1;
        acedSSGet("C", pt1, pt2,&eb,ssname);
        ads_name m_line1,m_line2;
        AcGeLine3d line1,line2;
        acedSSName(ssname,0,m_line1);
        acedSSName(ssname,1,m_line2);
    AcDbObjectId eId1,eId2;
    acdbGetObjectId(eId1,m_line1);
        acdbGetObjectId(eId2,m_line2);
        acedSSFree(ssname);
    AcDbLine *pEnt1,*pEnt2;
    acdbOpenObject(pEnt1,eId1,AcDb::kForRead);
        acdbOpenObject(pEnt2,eId2,AcDb::kForRead);
        AcGePoint3d point1,point2,point3;
        point2.x=joinPt[X];
        point2.y=joinPt[Y];
//        point1=point2==pEnt1->startPoint()?pEnt1->endPoint():pEnt1->startPoint();
//        point3=point2==pEnt1->startPoint()?pEnt2->endPoint():pEnt2->startPoint();
        if(point2==pEnt1->startPoint())
            point1=pEnt1->endPoint();
        else
                point1=pEnt1->startPoint();
        if(point2==pEnt2->startPoint())
            point1=pEnt2->endPoint();
        else
                point1=pEnt2->startPoint();
        pEnt1->close();
        pEnt2->close();
        LineJig* pJig=new LineJig(point1,point2,point3);
        pJig->doIt();
        delete pJig;
能帮帮我吗?
发表于 2002-5-21 03:35:42 | 显示全部楼层
应该是你sampler中的中的状态返回不对,你仔细看看。
 楼主| 发表于 2002-5-21 04:05:34 | 显示全部楼层
sampler函数是照书抄的,其实我不是很明白。
你觉得状态返回该怎样写呢?
发表于 2002-6-8 20:30:42 | 显示全部楼层
函数错在你addVertexAt,而没有删除.你可检查一下pline的定点数,答案就出来了^_^
GMT+8, 2026-11-22 11:00 , Processed in 0.417099 second(s), 14 queries , Gzip On, File On.
