查看: 2502|回复: 11
[求助] [求助]:万分火急,各位帮忙修复一下dwg文件
发表于 2006-8-30 08:38:12 | 显示全部楼层 |阅读模式
万分火急,各位帮忙修复一下dwg文件,这是同事的一个dwg文件
 楼主| 发表于 2006-8-30 09:07:35 | 显示全部楼层
第二部分
发表于 2006-8-30 09:21:12 | 显示全部楼层
下载不了,提示找不到服务器!
 楼主| 发表于 2006-8-30 09:52:16 | 显示全部楼层
重新上传了,拜托各位了
发表于 2006-8-30 10:46:17 | 显示全部楼层
还是提示找不到服务器
发表于 2006-8-30 11:16:11 | 显示全部楼层
下载不了啊,想帮忙都使不上劲啊
 楼主| 发表于 2006-8-30 11:37:39 | 显示全部楼层
是不是今天论坛服务器出现问题了?急。。。。。。。
谢谢各位的关注
发表于 2006-8-30 12:39:39 | 显示全部楼层
现在还是下不了。帮不了你。
Error!
File not found
You tried to access the address ftp://p4.xdcad.net/550775_88.part1.rar, which is currently unavailable. Please make sure that the Web address (URL) is correctly spelled and punctuated, then try reloading the page.
550 /550775_88.part1.rar: No such file or directory.
Make sure your Internet connection is active and check whether other applications that rely on the same connection are working.
Check that the setup of any Internet security software is correct and does not interfere with ordinary Web browsing.
If you are behind a firewall on a Local Area Network and think this may be causing problems, talk to your systems administrator.
Try pressing the F12 key on your keyboard and disabling proxy servers, unless you know that you are required to use a proxy to connect to the Internet. Reload the page.
发表于 2006-8-30 14:00:51 | 显示全部楼层
免费上存空间 - upload site 04/2006 update
所有免费空间申请大全集
好多的空间申请,大家各取所需吧
FileHD.com
http://dl2.filehd.com/index.php
(Limit: 60 Files 60 MB each)or 4 file of 500mb each
StoreandServe.com
http://storeandserve.com/download/215373/SuperFinder.rar.html
Account Status: Free (Up to 75 KB/s)
Photogiga.com
http://www.photogiga.com/
File Allowed jpg,tif,bmp,jpeg,gif,png,tiff,txt
Max - 3M
Turboupload.com
http://www.turboupload.com/
(maximum 70 MB)
第一部分screen.width-300)this.width=screen.width-300'>HP或者PHP+MYSQL空间
multimania空间(100M PHP+MYSQL)
申请地址: http://www.multimania.fr/abon/ ;
或者: http://www.multimania.lycos.fr/abon/ ;
100M的PHP/FTP空间 http://serv.chez.com /;
申请地址: http://serv.chez.com /; /bin/join
20M的FTP/PHP/Mysql空间
申请地址: http://www.polarhome.com/ ;
><空间(php3+mysql)申请全攻略[e小天撰写,2001/11/03验证通过]
申请地址 http://ins/ cription.></formuser.html
程序演示 http://lxiang.></vb/ ;
境外20M的PHP空间
申请地址: http://wazzza.org/fr/web.php ;
演示: http://www.wazzza.org/im286/wdb/ ;
lingshidao发现撰写的西班牙无限空间php+mysql
空间环境 http://www.iespana.es/cnfish/env.php ;
30M PHP/Mysql/FTP空间 http://www.coolfreepages.com/ ;
申请地址: http://www.coolfreepages.com /;
安装VBB1.16成功演示: http://im286.iwebland.com/ ;
10M的FTP, PHP, MySQL http://www.bitmand.dk/ ;
申请地址: http://www.bitmand.dk/ ;signup.php
10M的PHP、JSP国内空间
http://www.singnet.com.cn/homepage ;
申请地址: http://www.singnet.com.cn/homepage ;
/agree.jsp
PHP/FTP空间 http://www.>< /;
申请地址: http://www.><
/;/registracia/register.php
第二部分:CGI(可能带PHP甚至MYSQL)空间
国内20M CGI/FTP个人主页空间 http://home.yctc.edu.cn/ ;
申请地址http://home.yctc.edu.cn/ ; new.cgi
15M cgi/php/ssi/mysql 无限流量,无限信箱空间
http://www.itsfuntowin.com /;
申请地址http://www.itsfuntowin.com /; /hosting.html
5M的CGI, PHP, SSH, SSL, Mysql
空http://www.gloverworld.co.uk /;
申请地址: http://www.gloverworld.co.uk /;
/host/cgi-bin/signup.cgi
10M的PHP, CGI, Perl,FTP空间
申请地址: http://www.4gigs.com/ ;
20M的cgi空间 http://www.demented.org/ ;
申请地址: http://www.demented.org/ ; ?free
50M的SSI + PHP+CGI+FTP 空间 http://www.php50.com /;
申请地址: http://www.php50.com /; /
25 MB cgi/ftp空http://www.netfirms.com/ ;
申请地址: http://www.netfirms.com/ ;signup
30M的web上传/cgi空http://www.project-linux.org /;
申请地址: http://www.project-linux.org /;
/cgi/index.pl?Action=AnonCreate
250MCGI/PHP空间 http://aawebhosts.com /;
申请地址: http://aawebhosts.com /;/signup1/signup1.htm
100M CGI空间 http://www.mysitespace.com/ ;
申请地址: http://www.mysitespace.com/
;cgi-bin/freesite/new.cgi
20M cgi/php/ftp空间 https://www.covers.de/
申请地址:
http://www.covers.de/meincovers/register3.asp ;
50M,cgi/ftp/免费/无限频宽 http://www.freetaboohost.com
申请地址: http://www.freetaboohost.com
/;/cgi-bin/reg.cgi
20MB CGI/php空间 http://ghs20.com/ ;
申请地址: http://ghs20.com/ ;signup.htm
2M无广告的cgi 空http://www.graffitirose.net /;
申请地址: http://www.graffitirose.net /;
/cgi-bin/create_user.cgi
50MCGI空间 http://freeorder.prohosting.com /;
申请地址: http://freeorder.prohosting.com /; /
15M的cgi/php/mysql/ssi/ftp空间
http://www.united.net.kg/ ;
申请地址: http://www.itsfuntowin.com /; /hosting.html
15M的cgi/php空间 http://www.1freehost24.de/ ;
申请地址: http://www.1freehost24.de/ ;
freehost/5ww/register.php
20M的cgi/ftp空间 http://www.graffiti.net/ ;
申请地址: http://www.graffiti.net/ ;
100M的cgi/php/mysql空间 http://hwa.hwgn.net /;
申请地址: http://hwa.hwgn.net /; /join.shtml
无限空间cgi/php/mysql/ftp空间 http://www.subnixus.net/
申请地址: mailto:eric@subnixus.net
50M的cgi/php/mysql空间 http://www.l33t.ca /;
申请地址: http://accounts.l33t.ca/index.cgi ;
200M的WEB上传CGI空间 http://www.fpages.co.uk/ ;
申请地址: http://www.fpages.co.uk/
;cgi-bin/fpages/create_user.cgi
50M的cgi/php/ftp空间 http://www.sitespun.com /;
申请地址: http://www.sitespun.com /;/register.cgi
CGI/PHP/SSI的无限空间 http://www.long4net.com/ ;
申请地址: mailto:free@long4net.com
20M的cgi/php/mysql/ssi/ftp空间
http://tsunami.net.dhis.org/ ;
申请地址: http://tsunami.net.dhis.org/ ;register.php
cgi/php/mysql/ftp无限空间
http://yoursite-hosting.com:800/hosting/ ;
申请地址: http://www.mwgaming.com
/;/page.php?load=network/hosting
25M的cgi空间 http://home.spacetowns.com/ ;
申请地址http://www.spacetowns.com/cgi-bin/user/u...action=register
    无限cgi免费空间 http://www52.tok2.com /;
申请地址http://tok2.com/mousikomi52.html ;
第三部分:ASP空间
我心飞扬免费空间(ASP 100M较快)
申请地址: http://flying.swpi.edu.cn/space/ ;
放免费供求演示: http://free.swpi.edu.cn/~0575/ ;
10M的FTP/ASP空间 http://www.dingojunction.com/ ;
申请地址: http://www.dingojunction.com/
;index.asp?inc=freeaccount
30M的ASP/FTP空间 http://www1.><.com/ ;
申请地址: http://www1.><.com/ ;registration/
30M的ASP空间 http://www.cfm-resources.com /;
申请地址: http://www.cfm-resources.com
/;/apply.cfm?signup=free
85M的ASP空http://www.support.frontuk.com/ ;
申请地址: http://www.support.frontuk.com/
;sitemanager/personal_account_create.asp
30M ASP空间 http://www.><.com/ ;
申请地址: http://www.><.com/ ;Signup.asp
15~25M的ASP/FTP空间 http://www4.domaindlx.com /;
申请地址: http://login.domaindlx.com/registration.aspx
50Masp+access法国空间 http://www.labulle.net /;
申请地址:
http://www.labulle.net/masterbulle/bulle.asp?page=gratuit;
    快速50M ASP/FTP空间 http://www.nihonkai.com /;
申请地址: http://www.nihonkai.com /; /freehp/apply.cgi
20M的FTP/ASP空间 http://www.freeasphost.co.uk /;
申请地址: http://www.freeasphost.co.uk /; /signup/
50M的ASP/FTP空间 http://www.7host.com /;
申请地址: http://www.7host.com /;
/signup/signup_free_terms.asp
50M的ASP/FTP 空间 http://www.efrance-asp.com /;
申请地址: http://www.efrance-asp.com /;
/hebergementEmail.asp
无限空间ASP/FTP网站 http://www.salvos.com/ ;
申请地址: http://www.salvos.com/ ; apply.htm
20M的ASP空间 http://www.webhostme.com/ ;
申请地址: http://www.webhostme.com/ ; emailconfirm.asp
第四部分:JSP空间
10M的PHP、JSP国内空间
/agree.jsp
10M的JSP空间 http://java.isavvix.com/devspace.jsp ;
申请地址: http://java.isavvix.com/register.jsp ;
5M的JSP空间 http://www.mycgiserver.com /;
申请地址: http://www.mycgiserver.com
/;/exec/Yaxz0nxpULwyTzcC152zPnxp0f2y
第五部分:普通空间
无限空间无广告普通空间 http://www.hostultra.com /;
申请地址: http://www.hostultra.com
/;/cgi-bin/user/user.cgi/?action=register
无限空间普通FTP空间,适合游戏站 http://www.tf2hq.com/
申请地址: http://www.tf2hq.com/ ;hosting.asp
FTP/无限的巴西空http://www.hpg.ig.com.br /;
申请地址: http://www.hpg.ig.com.br /;
/cadastro/form.php3
100M的不限流量高速空间 http://www.groundz.vze.com/ ;
申请地址:
http://webmasters.dynu.com/grounds/cgi-bin/new.cgi ;
500M的FTP普通空间 http://www.9cy.com /;
申请地址: http://www.9cy.com /; /hosting.php
10M无广告普通空http://www.staticfree.net /;
申请地址: http://www.staticfree.net /; /new.html
20M普通WEB上传空http://www.clubalien.com/ ;
申请地址: http://www.clubalien.com/ ;
50MB不限流量的FTP普通空http://www.microworld.com/ ;
申请地址:
http://microworld.com/html/orde><domain.html ;
250M普通FTP空间 http://www.250free.com/ ;
申请地址: http://www.250free.com/ ; join.php?agree=yes
500M普通空http://www.gizba.com/ ;
申请地址: http://www.gizba.com/ ; tos_signup.htm
100M无广告空间 http://members.freewebz.com/ ;
申请地址: http://members.freewebz.com/ ;
40M的存储空http://www.kturn.com/ ;
申请地址: http://www.kturn.com/ ; site/newuser
50M高速空间 http://www.freehomepages.com/ ;
申请地址: http://www.freehomepages.com/ ;
modules.php?name=Your_Account
50M - 无限普通空间 http://www.gigitup.com /;
申请地址: http://www.gigitup.com /; /cgi-bin/new.cgi
50M普通空间 http://www.eroticountry.com /;
申请地址: http://www.eroticountry.com /;
/index2.cgi?stage=2
250/100 M普通FTP空间 http://www.0catch.com/ ;
申请地址:
http://signup.0catch.com/signup_domain_choice/0catch ;
50M普通空间 http://dreamwater.com /;
申请地址: http://www.dreamwater.com/signup99a.html ;
无限普通空间 http://www.crosswinds.net /;
申请地址: http://www.crosswinds.net /; /join/
5MB的普通空间 http://www.belizehome.com /;
申请地址: http://www.belizehome.com /;
/cgi-bin/hf/new.cgi
25M FTP(单个文件超过1.5M)普通空间
http://www.easyspace.com /;
申请地址: http://shop.easyspace.com/shop-c ...
=MEMBERS&tied_name= ;
15M普通空间 http://www.eccentrix.com /;
申请地址: http://www.eccentrix.com /;
/cgi-bin/user/user.cgi?action=register
60M FTP普通空间 http://www.fateback.com/ ;
申请地址: http://www.fateback.com/ ; signup/
10M的普通空间 http://freecoolpages.com/ ;
申请地址: http://freecoolpages.com/ ;
createacc/home.html
150 MB FTP普通空间 http://www.topcities.com /;
申请地址: http://www.topcities.com /;
/cgi-bin/home/signup?1u=22
50M的FTP普通空间 http://www.escalix.com /;
申请地址: http://www.escalix.com /;
20M FTP普通空间 http://www.esmartstart.com/ ;
申请地址: http://www.esmartstart.com/ ;
signup_form.esm
100M的FTP普通空间 http://www.bravenet.com /;
申请地址: http://www.bravenet.com /;
/members/signup.php
一个无限普通空间 http://www2.maxismut.com /;
申请地址: http://www2.maxismut.com /;:81/order.php
100M的FTP普通空间 http://www.>< /;
申请地址: http://ins/ cription.></formuser.html
50M的普通空间 http://www.ssihost.com /;
申请地址: http://www.ssihost.com /;/signup.html
40M 普通空间 http://home.justfree.com /;
申请地址: http://www.justfree.com/manage/signup.cgi ;
100M普通空间 http://www.internations.net/ ;
申请地址http://usa.internations.net/cgi-bin/new.cgi/english
第六部分:全能空间
50M的cgi/php/mysql/ssi/asp/全能空间
friserverplads.dk/\" target=\"_blank\">http://www.friserverplads.dk/ ;
申请地址: friserverplads.dk/manager.php?mode=opret\"
target=\"_blank\">http://system.friserverplads.dk/manager.php?mode=opret
5M的FTP全能空间ASP/CGI/PHP http://www.digitalrice.com
申请地址: http://www.digitalrice.com
/;/modules.php?op=modload&name=NS-Sign_Up&file=index
25M,ASP+CGI免费空间申请攻略
http://projects.fangames.net /;
申请地址: http://projects.fangames.net /;
/manage.pl?action=Add%20User
100m的ASP/PHP/FTP空间(支持FSOhttp://www.aspfreeserver.com/
申请地址: http://www.aspfreeserver.com/ ;
20M的ASP/PHP/MYSQL空间 http://www.amzweb.com/ ;
申请地址:
mailtoscreen.width-300)this.width=screen.width-300'>ales@amzweb.com
    无限全能空间 http://mail.tokutoku.or.jp /;
申请地址: http://mail.tokutoku.or.jp
/;/templates/common/jp/tos.htm
\"我不需要很多的空间, 我只要是没有广告的一个空间。
有足够大的流量当然更好。\"
http://www.liquid2k.com/ ( 推荐)
http://www.><.com/ ( 推荐)
http://www.cfm-resources.com/
http://www.digitalrice.com/
\"我需要 PHP 和足够的空间。 ( 也许 15-25 M)
我可以接受一些广告的 (旗帜或跳出/底部,
但是不能两者都有!),空间如果没广告 , 我会更喜欢。 我需要尽可能多的流量。MySQL
是可选择的。\"
http://www.></ ( 无广告)
http://www.php50.com/ (页顶广告)
http://www.fateback.com/ ( 旗帜)
http://www.xx.com/ (页顶广告)
http://www.clawz.com/ ( 旗帜)
http://www.tripod.co.uk/ (页顶广告,MySQL 包括)
\"我需要一个可以接受大文件而且提供很多流量的空间。
我需要FTP。\"
http://www.><ites.com/
http://www.webavenue.org/
http://www.hut.ru/
http://www.web1000.com/
\"我不关心空间或广告或流量。 5-10 M空间,
跳出或旗帜,300 M月流量就够了。 我只要求稳定,不会很快关闭的空间?\"
http://www.geocities.com/
http://www.><.com/
http://www.tripod.com/
http://www.topcities.com/
\"我想做的论坛的 Ikonboard 或 YaBB 需要 CGI支持 。
我不介意广告,只要他们不是太令人讨厌。 我仅仅需要 10
M的空间,而且空间一定有FTP。 请推荐一些空间!\"
http://www.spaceports.com/
http://free.prohosting.com/
http://www.amzweb.net/signup.php
http://www.hut.ru/
\"我真的需要空间,合适的流量和 20-30 M空间。 最好有
FTP,没有也可以。\"
http://www.><.com/ ( FTP, 没有广告)
http://www.raketnet.nl/
http://www.><.com/
\"我正在找寻一个至少提供 15 M空间和 1G流量 , PHP/
MySQL 和 CGI 的空间。 你知道任何的空间吗?\"
http://www.digitalrice.com/ ( 只有 5 M空间)
http://www.portland.co.uk/ ( 只有 100 M流量)
挑个合用的呗
发表于 2006-8-31 14:27:21 | 显示全部楼层
如果修复等都无效,文件用看图软件打得开,转存为低版本格式,如r14甚至r12等,可能可以修复一部分。但该版本之后的新实体会丢失。
发表于 2006-9-11 19:51:49 | 显示全部楼层
提供楼主一个土办法:如果autocad不能修复,可以试用一下DwgExpress6之类的第三方软件转换一下看看能不能打开。
发表于 2006-9-13 23:57:48 | 显示全部楼层
修复不了的时候,千万不要用转图软件,一用就没得救了。一般用高版本的来修复,成功的机率比较大。
GMT+8, 2026-11-23 17:01 , Processed in 0.403885 second(s), 32 queries , Gzip On, File On.
