查看: 1144|回复: 0
[求助]:发生致命错误,请大家帮忙看下!
发表于 2006-8-31 09:12:43 | 显示全部楼层 |阅读模式
我自定义了一个矩形类,就是可以拖放的那种.但是不知道为什么当我拖放完成时候会出现致命错误.无法完成矩形的最终绘制.
哪位大哥可以帮小弟看看是什么原因.
拖放结束后出现: Unhandled Expception C0000005(Access Violation Reading Ox0054)at address 65462AC9h
关掉AUTCAD后 出现 :INTERNAL ERROR!XCOMMAND.cpp@3337:Was Open For Write
代码如下:
class  CMARectWindow : public AcDbEntity
public:
        ACRX_DECLARE_MEMBERS(CMARectWindow);
        CMARectWindow();
        virtual ~CMARectWindow();
        virtual Acad::ErrorStatus dwgOutFields(AcDbDwgFiler* pFiler) const;
        virtual Acad::ErrorStatus dwgInFields(AcDbDwgFiler* pFiler);
        virtual Acad::ErrorStatus dxfInFields(AcDbDxfFiler* pFiler);
        virtual Acad::ErrorStatus dxfOutFields(AcDbDxfFiler* pFiler)const;
        virtual Acad::ErrorStatus getGripPoints(AcGePoint3dArray& gripPoints, AcDbIntArray& osnapMasks, AcDbIntArray& geomIds) const;
        virtual Acad::ErrorStatus moveGripPointsAt(const AcDbIntArray& indices, const AcGeVector3d& offset);
        virtual Adesk::Boolean worldDraw(AcGiWorldDraw* mode);
        AcGePoint3d m_UpLeftPt;
        AcGePoint3d m_DownRightPt;
        AcGePoint3d m_DownLeftPt;
        AcGePoint3d m_UpRightPt;
private:
ACRX_DXF_DEFINE_MEMBERS(CMARectWindow, AcDbEntity,
                        AcDb::kDHL_CURRENT, AcDb::kMReleaseCurrent,
                        0,
                        CUSTOMENTITY, /*MSG0*/AUTOCAD);
CMARectWindow::CMARectWindow()
CMARectWindow::~CMARectWindow()
Acad::ErrorStatus CMARectWindow::getGripPoints(AcGePoint3dArray& gripPoints, AcDbIntArray& osnapMasks, AcDbIntArray& geomIds)const
        assertReadEnabled();
        AcGePoint3d um,lm,rm,bm;
        um=m_UpLeftPt+0.5*(m_UpRightPt-m_UpLeftPt);
        lm=m_DownLeftPt+0.5*(m_UpLeftPt-m_DownLeftPt);
        rm=m_DownRightPt+0.5*(m_UpRightPt-m_DownRightPt);
        bm=m_DownLeftPt+0.5*(m_DownRightPt-m_DownLeftPt);
        gripPoints.append(um);
        gripPoints.append(rm);
        gripPoints.append(bm);
        gripPoints.append(lm);
        return Acad::eOk;
Acad::ErrorStatus CMARectWindow::moveGripPointsAt(const AcDbIntArray& indices, const AcGeVector3d& offset)
        assertWriteEnabled();
        switch(indices[0]) {
        case 0:
                m_UpLeftPt[Y]+=offset.y;
                m_UpRightPt[Y]+=offset.y;
                break;
        case 1:
                m_UpRightPt[X]+=offset.x;
                m_DownRightPt[X]+=offset.y;
                break;
        case 2:
                m_DownLeftPt[Y]-=offset.y;
                m_DownRightPt[Y]-=offset.y;
                break;
        case 3:
                m_DownLeftPt[X]-=offset.x;
                m_UpLeftPt[X]-=offset.x;
                break;
        default:
                break;
        return Acad::eOk;
Adesk::Boolean CMARectWindow::worldDraw(AcGiWorldDraw* mode)
        m_DownLeftPt[0]=m_UpLeftPt[0];
        m_DownLeftPt[1]=m_DownRightPt[1];
        m_DownLeftPt[2]=0;
        m_UpRightPt[0]=m_DownRightPt[0];
        m_UpRightPt[1]=m_UpLeftPt[1];
        m_UpRightPt[2]=0;
        AcGePoint3d pLineArray[5];
        pLineArray[0] =m_UpLeftPt;
        pLineArray[1] =m_UpRightPt;
        pLineArray[2] =m_DownRightPt;
        pLineArray[3] =m_DownLeftPt;
        pLineArray[4] =m_UpLeftPt;
        mode->geometry().polyline(5, pLineArray);
        return Adesk::kTrue;
Acad::ErrorStatus CMARectWindow::dwgInFields(AcDbDwgFiler* pFiler)
        Acad::ErrorStatus es;
        if ((es = AcDbEntity::dwgInFields(pFiler)) != Acad::eOk)
                return es;
        pFiler->readItem(&m_UpLeftPt);
        pFiler->readItem(&m_DownRightPt);
        pFiler->readItem(&m_DownLeftPt);
        pFiler->readItem(&m_UpRightPt);
        return pFiler->filerStatus();
Acad::ErrorStatus CMARectWindow::dwgOutFields(AcDbDwgFiler* pFiler) const
        if ((es = AcDbEntity::dwgOutFields(pFiler)) != Acad::eOk)
                return es;
        pFiler->writeItem(m_UpLeftPt);
        pFiler->writeItem(m_DownRightPt);
        pFiler->writeItem(m_UpRightPt);
        pFiler->writeItem(m_DownLeftPt);
Acad::ErrorStatus CMARectWindow::dxfInFields(AcDbDxfFiler* pFiler)
        Acad::ErrorStatus es=Acad::eOk;
        resbuf rb;
        if ((AcDbEntity::dxfInFields(pFiler)!=Acad::eOk)||!pFiler->atSubclassData("CMARectWindow"))
        AcGePoint3d ulPt,urPt,dlPt,drPt;
        while ((es==Acad::eOk)&&(es=pFiler->readResBuf(&rb))==Acad::eOk)
                switch(rb.restype) {
                case kDxfXCoord:
                        ulPt=asPnt3d(rb.resval.rpoint);
                        break;
                case kDxfXCoord+1:
                        urPt=asPnt3d(rb.resval.rpoint);
                        break;
                case kDxfXCoord+2:
                        dlPt=asPnt3d(rb.resval.rpoint);
                        break;
                case kDxfXCoord+3:
                        drPt=asPnt3d(rb.resval.rpoint);
                        break;
                default:
                        pFiler->pushBackItem();
                        es=Acad::eEndOfFile;
                        break;
        if (es!=Acad::eEndOfFile)
                        return Acad::eInvalidResBuf;
        return es;
Acad::ErrorStatus CMARectWindow::dxfOutFields(AcDbDxfFiler* pFiler) const
        if ((es=AcDbEntity::dxfOutFields(pFiler))!=Acad::eOk)
                return es;
        pFiler->writeItem(AcDb::kDxfSubclass,"CMARectWindow");
        pFiler->writeItem(AcDb::kDxfXCoord,m_UpLeftPt);
        pFiler->writeItem(AcDb::kDxfXCoord+1,m_UpRightPt);
        pFiler->writeItem(AcDb::kDxfXCoord+2,m_DownRightPt);
        pFiler->writeItem(AcDb::kDxfXCoord+3,m_DownLeftPt);
        return es;
class AsdkRectJig:public AcEdJig
public:
        AsdkRectJig(AcGePoint3d &);
        void doIt();
        virtual DragStatus sampler();
        virtual Adesk::Boolean update();
        virtual AcDbEntity* entity() const;
protected:
private:
        CMARectWindow *mpRect;
        AcGePoint3d mUpLeftPt,mDownRightPt;
        double m_length,m_height;
        AcGeVector3d mNormal;
AsdkRectJig::AsdkRectJig(AcGePoint3d &Pt)
        mpRect=new CMARectWindow();
        mpRect->m_UpLeftPt=Pt;
void AsdkRectJig::doIt()
        setDispPrompt("\nRect choose the second point:");
        AcEdJig::DragStatus stat=drag();
        append();
AcEdJig::DragStatus
AsdkRectJig::sampler()
        DragStatus stat;
        setUserInputControls((UserInputControls)
                (AcEdJig::kGovernedByOrthoMode
                |AcEdJig::kAccept3dCoordinates
                |AcEdJig::kNoNegativeResponseAccepted
                |AcEdJig::kNoZeroResponseAccepted));
        static AcGePoint3d axispointTemp;
        stat=acquirePoint(mDownRightPt);
        if (axispointTemp!=mDownRightPt)
                axispointTemp=mDownRightPt;
        else if(stat==AcEdJig::kNormal)
                return AcEdJig::kNoChange;
        return stat;
Adesk::Boolean
AsdkRectJig::update()
        mpRect->m_DownRightPt=mDownRightPt;
AcDbEntity *
AsdkRectJig::entity() const
        return mpRect;
// This is command 'REC'
void studyrectrec()
        // TODO: Implement the command
        AcGePoint3d tempPt;
        struct resbuf rbFrom,rbTo;
        ads_getpoint(NULL,"\nRect choose the first point:",asDblArray(tempPt));
        rbFrom.restype=RTSHORT;
        rbFrom.resval.rint=1;
        rbTo.restype=RTSHORT;
        rbTo.resval.rint=0;
        ads_trans(asDblArray(tempPt),&rbFrom,&rbTo,Adesk::kFalse,asDblArray(tempPt));
        AsdkRectJig *pJig=new AsdkRectJig(tempPt);
        pJig->doIt();
        delete pJig;
GMT+8, 2026-11-22 08:29 , Processed in 0.460358 second(s), 10 queries , Gzip On, File On.
