查看: 1223|回复: 0
[讨论]:VLisp连接Excel的问题
发表于 2006-10-5 12:17:46 | 显示全部楼层 |阅读模式
网上大名鼎鼎的DSX-API-Excel.LSP 中的DSX-Excel-Put-ColumnList 为什么不能用?
具体代码为:
;;; MODULE: DSX-Excel-Put-ColumnList
;;; DESCRIPTION: Write each list member to a column (startcol) starting at row (startrow)
;;; ARGS: list, startrow, startcol
;;; EXAMPLE: (DSX-Excel-Put-ColumnList '("A" "B" "C") 1 2) puts members into cells (1,B) (2,B) (3,B) respectively
(defun dsx-excel-put-columnlist (lst startrow startcol)
  ;(dsx-princ "\n(DSX-Excel-Put-ColumnList)")
  (foreach itm lst
    (msxl-put-value (dsx-excel-get-cell range startrow startcol) itm)
    (setq startrow (1+ startrow))
  ); repeat
该lsp中range没有定义,但即便定义后msxl-put-value也会出错,不知道什么原因。。
难道没有msxl-put-value 方法?
GMT+8, 2026-11-7 07:31 , Processed in 0.520899 second(s), 31 queries , Gzip On.
