查看: 1269|回复: 1
[求助]:[求助]:[求助]:[求助]:我的2007为什么装不上?
发表于 2006-10-10 10:19:41 | 显示全部楼层 |阅读模式
我安装CAD2007时出现下图所示错误,不知是什么原因,请高手指教
错误文件中的内容是:
2006/10/10:10:13:03        ff        XYZ        === Installation started on XYZ by ff ===
2006/10/10:10:13:04        ff        XYZ        Install        MSI Runtime 3.1        Skipped        Windows Installer upgrade is not required. System Version = 3.1.4000.2435
2006/10/10:10:13:14        ff        XYZ        Install        .NET Framework Runtime 2.0        Failed        Installation aborted, Result=1603
2006/10/10:10:13:14        ff        XYZ        === Installation ended ===
发表于 2006-12-10 19:08:15 | 显示全部楼层
我也是装不上,已经装了net framework2.0了
GMT+8, 2026-11-22 09:25 , Processed in 0.282428 second(s), 12 queries , Gzip On, File On.
