查看: 1596|回复: 3
[求助] [求助]:急用,选择一个图元,画一条线后,该图元层所有的线在相交点被打断。
发表于 2006-10-14 08:49:02 | 显示全部楼层 |阅读模式
发表于 2006-10-14 12:56:38 | 显示全部楼层
论坛有单独的交点打断程序,把内容合并到你的lsp就可以了
 楼主| 发表于 2006-10-15 00:48:46 | 显示全部楼层
谢谢楼上指点,程序编出来了
  1. (VL-LOAD-COM)
  2. (setq AcadObject (vlax-get-acad-object))
  3. (setq AcadDocument (vla-get-ActiveDocument Acadobject))
  4. (setq mSpace (vla-get-ModelSpace Acaddocument)) ;_获得模型空间指针
  5. (defun c:brk_Line (/             lineObjNames           lay-name
  6.                   lyspt1     i                p1           p2
  7.                   linePointCol                P3           p4
  8.                   p             tmpEnt        lineObjNames
  9.                  ) ;_主函数
  10.   (while (null lay-name)
  11.     (setq lay-name (entsel "\n选择打断图层:"))
  12.   )
  13.   (setq lay-name (entget (car lay-name)))
  14.   (setq lay-name (cdr (assoc 8 lay-name)))
  15.   (setq lyspt1 (getpoint "\n起点:"))
  16.   (if lyspt1
  17.     (setq lyspt2 (getpoint lyspt1 "\n第终点: "))
  18.   )
  19.   (if lyspt1
  20.     (command "line" lyspt1 lyspt2 "")
  21.   )
  22.   (setq        lyspt1 (list lyspt1
  23.                      lyspt2
  24.                      (list (nth 0 lyspt2) (1+ (nth 0 lyspt2)) 0)
  25.                )
  26.   )
  27.   (setq        lineObjNames
  28.          (ssget        "CP"
  29.                 lyspt1
  30.                 (list '(0 . "LINE") (cons 8 lay-name))
  31.          )
  32.   )
  33.   (setq n (sslength lineObjNames))
  34.   (setq p1 (nth 0 lyspt1))
  35.   (setq p2 (nth 1 lyspt1))
  36.   (setq i 0)
  37.   (repeat n
  38.     (setq next (ssname lineObjNames i))
  39.     (setq p3 (vlax-curve-getStartPoint next))
  40.     (setq p4 (vlax-curve-getEndPoint next)) ;_求开始点和结束点
  41.     (setq p (inters p1 p2 p3 p4))
  42.     (vl-cmdf "_.break" (ssadd next) P "@")
  43.     (setq i (1+ i))
  44.   )
  45.   (princ)
  46. )
发表于 2023-6-9 20:37:47 | 显示全部楼层
效率太低,浪费时间
GMT+8, 2026-11-3 00:39 , Processed in 0.503280 second(s), 36 queries , Gzip On.
