查看: 5338|回复: 20
[求助] [求助]:如何让图上所有的圆圈按比例缩小?
发表于 2006-10-16 13:38:59 | 显示全部楼层 |阅读模式
如何让图上所有的远去圆圈按比例缩小?
如图,要让所有的轴线圈,以端点为基点,缩小0.5倍
有没有程序可以做到呢???
发表于 2006-10-16 17:02:29 | 显示全部楼层
[php]
(DEFUN C:SCCIRCLE ()
(SETVAR "CMDECHO" 0)
(SETQ OLDOS (GETVAR "OSMODE"))
(SETVAR "OSMODE" 0)
(COMMAND ".UNDO" "BE")
(SETQ SC (GETDIST "\nEnter The Scale :"))
(IF (SETQ SS (SSGET '((0 . "CIRCLE")))) (PROGN
  (SETQ N -1)
  (REPEAT (SSLENGTH SS)
   (SETQ EN (ENTNAME SS (SETQ N (1+ N))
         ENT (ENTGET EN)
         PC (CDR (ASSOC 10 ENT))
         R (CDR (ASSOC 40 ENT))
         P1 (POLAR PC 0 R)
         P2 (POLAR PC (/ PI 2) R)
         P3 (POLAR PC PI R)
         P4 (POLAR PC (/ PI -2) R) P nil)
   (IF (> (SSLENGTH (SSGET "C" P1 P1)) 1) (SETQ P P1))
   (IF (> (SSLENGTH (SSGET "C" P2 P2)) 1) (SETQ P P2))
   (IF (> (SSLENGTH (SSGET "C" P3 P3)) 1) (SETQ P P3))
   (IF (> (SSLENGTH (SSGET "C" P4 P4)) 1) (SETQ P P4))
   (IF P (COMMAND "SCALE" EN "" P SC))
(COMMAND ".UNCO" "E")
(SETVAR "OSMODE" OLDOS)
(SETVAR "CMDECHO" 1)
(PRINC)
[/php]
发表于 2006-10-16 18:14:49 | 显示全部楼层
(SETQ EN (ENTNAME -->(SETQ EN (SSNAME
(COMMAND ".UNCO" "E") -->(COMMAND ".UNDO" "E")
另对带属性的轴线号无效。
 楼主| 发表于 2006-10-17 09:52:06 | 显示全部楼层
谢谢楼上两位,但程序好像有错,
少一个闭括号,我在最后加了一个括号后,提示:
错误: 参数太多: (IF (SETQ SS ( ... )) (PROGN ( ... ) ( ... )) (COMMAND ".UNCO" "E") ... )
麻烦再帮忙看一下
发表于 2006-10-17 10:45:42 | 显示全部楼层
三楼楼主说得全对。程序是对带属性的轴线号无效。
程序是少了个右括弧。因为是在机场的本机上敲入的,未进行调试。
下面是改过的程序:
  1. (DEFUN C:SCCIRCLE ()
  2. (SETVAR "CMDECHO" 0)
  3. (SETQ OLDOS (GETVAR "OSMODE"))
  4. (SETVAR "OSMODE" 0)
  5. (COMMAND ".UNDO" "BE")
  6. (SETQ SC (GETDIST "\nEnter The Scale :"))
  7. (IF (SETQ SS (SSGET '((0 . "CIRCLE")))) (PROGN
  8.   (SETQ N -1)
  9.   (REPEAT (SSLENGTH SS)
  10.    (SETQ EN (SSNAME SS (SETQ N (1+ N)))
  11.      ENT (ENTGET EN)
  12.      PC (CDR (ASSOC 10 ENT))
  13.      R (CDR (ASSOC 40 ENT))
  14.      P1 (POLAR PC 0 R)
  15.      P2 (POLAR PC (/ PI 2) R)
  16.      P3 (POLAR PC PI R)
  17.      P4 (POLAR PC (/ PI -2) R) P nil)
  18.    (IF (> (SSLENGTH (SSGET "C" P1 P1)) 1) (SETQ P P1))
  19.    (IF (> (SSLENGTH (SSGET "C" P2 P2)) 1) (SETQ P P2))
  20.    (IF (> (SSLENGTH (SSGET "C" P3 P3)) 1) (SETQ P P3))
  21.    (IF (> (SSLENGTH (SSGET "C" P4 P4)) 1) (SETQ P P4))
  22.    (IF P (COMMAND "SCALE" EN "" P SC))
  23.   )
  24. ))
  25. (COMMAND ".UNDO" "E")
  26. (SETVAR "OSMODE" OLDOS)
  27. (SETVAR "CMDECHO" 1)
  28. (PRINC)
  29. )
 楼主| 发表于 2006-10-17 13:35:08 | 显示全部楼层
非常感谢!
已经搞定了,对于这样乐于助人的同志,本版的斑竹应该加分啊!!
延伸一下,如果我想把圆圈里的文字一起缩小,应该把程序怎样改一下??
发表于 2006-10-18 09:55:59 | 显示全部楼层
不用改,只要将放大的比例输成小于一的数就行了。
 楼主| 发表于 2006-10-18 12:38:29 | 显示全部楼层
zxq0220 兄 可能没有明白我的意思,
我的文字和圆圈不是一起的,我想把他们同时缩小,基点就是圆圈的基点
看我的演示。
发表于 2006-10-18 14:09:02 | 显示全部楼层
照斑竹的意思又改了一下。
  8.   (SETQ N -1)
  11.          ENT (ENTGET EN)
  18.          P nil
  19.          P5 (POLAR P3 (/ PI -2) R)
  20.          P6 (POLAR P1 (/ PI 2) R))
  21.    (IF (> (SSLENGTH (SSGET "C" P1 P1)) 1) (SETQ P P1))
  22.    (IF (> (SSLENGTH (SSGET "C" P2 P2)) 1) (SETQ P P2))
  23.    (IF (> (SSLENGTH (SSGET "C" P3 P3)) 1) (SETQ P P3))
  24.    (IF (> (SSLENGTH (SSGET "C" P4 P4)) 1) (SETQ P P4))
  25.    (IF P (COMMAND "SCALE" EN "W" P5 P6 "" P SC))
  26.   )
  27. ))
  28. (COMMAND ".UNDO" "E")
  29. (SETVAR "OSMODE" OLDOS)
  30. (SETVAR "CMDECHO" 1)
  31. (PRINC)
  32. )
 楼主| 发表于 2006-10-23 17:57:10 | 显示全部楼层
谢谢,基本可以了,就是如果文字比较多,超出圆圈范围,就不能一起缩小了,
感谢。
发表于 2006-10-23 20:11:04 | 显示全部楼层
试试这样改的效果
   (setq ss (ssget "f" (list p1 p3) '((0 . "*TEXT"))))
   (IF P (COMMAND "SCALE" EN SS "" P SC))
 楼主| 发表于 2006-10-24 13:24:04 | 显示全部楼层
楼上,不知道怎么的,按照你的改法,每次只能缩小一个了,郁闷……
发表于 2006-10-24 14:48:47 | 显示全部楼层
Sorry!
(setq ss2 (ssget "f" (list p1 p3) '((0 . "*TEXT"))))
(IF P (COMMAND "SCALE" EN SS2 "" P SC))
发表于 2006-10-24 18:10:28 | 显示全部楼层
使用者選取所有的軸線
程式去找出軸線中的圓圈
再對找出的圓圈去找出其中的文字
(defun c:test (/)
        (setq
                ss-filter         (list (cons 0 "LINE"))
                ss                         (ssget ss-filter)
        (if (zerop (if ss (sslength ss) 0)) (exit))
        (command "_UNDO" "_BEGIN")
        ;;; start loop
        (setq inx (~ 0))
        (while (setq e (ssname ss (setq inx (1+ inx))))
                (setq
                        ex                (entget e)
                        ep1                (cdr (assoc 10 ex))
                        ep2                (cdr (assoc 11 ex))
                        dst                (distance ep1 ep2)
                        ang                (angle ep2 ep1)
                        sscir        (ssget "F" (list (polar ep1 ang dst) (polar ep2 (+ ang pi) dst)) (list (cons 0 "CIRCLE")))
                        ssx                (ssadd)
                ) ; end setq
                (if (not (zerop (if sscir (sslength sscir) 0)))
                        (progn
                                (setq
                                        target        (ssname sscir 0)
                                        ex                (entget target)
                                        cp                (cdr (assoc 10 ex))
                                        rad                (cdr (assoc 40 ex))
                                        sstxt        (ssget "F" (list (polar cp ang rad) (polar cp (+ ang pi) rad)) (list (cons 0 "TEXT")))
                                        dst1        (distance ep1 cp)
                                        dst2        (distance ep2 cp)
                                        bp                (if (< dst1 dst2) ep1 ep2)
                                ) ; end setq
                                (ssadd target ssx)
                                (if (not (zerop (if sstxt (sslength sstxt) 0)))
                                        (progn
                                        (ssadd (ssname sstxt 0) ssx)
                                        (command "_SCALE" ssx "" bp "0.5")
                                        ) ; end progn
                                ) ; end if
                        ) ; end progn
                ) ; end if
        ) ; end while
        ;;; end loop
        (command "_UNDO" "_END")
        (princ)
) ; end defun
发表于 2006-10-24 18:19:15 | 显示全部楼层
根本不需要程序,全选,然后CTRL+1,然后在左上下拉栏里选择圆,然后就可以统一改你要的直径或半径.
GMT+8, 2026-11-22 10:17 , Processed in 0.330667 second(s), 38 queries , Gzip On, File On.
