查看: 1614|回复: 1
[求助]:各位兄弟姐妹请进,3DSMAX8安装问题 ,急!!!!!
发表于 2006-10-18 01:34:08 | 显示全部楼层 |阅读模式
买了一张光盘安装时,出现如下提示,"已终止Autodesk 3DSMAX8安装,请检查"C:\Documents and Settings\llsheng\Local Settings\Temp\3dsMax8.log获取详细信息,
找开3dsMax8.log看到如下信息:
[10/18/2006 01:30:24] === Installation started on LLSHENG-MMPPL7V by llsheng ===
[10/18/2006 01:30:24] Installation started: MSI Runtime 3.1
[10/18/2006 01:30:24]   Command = "I:\MSI\WindowsInstaller-KB893803-v2-x86.exe" /quiet /norestart
[10/18/2006 01:30:24] [Error: 3] 系统找不到指定的路径。
[10/18/2006 01:30:24] Installation failed: MSI Runtime 3.1
[10/18/2006 01:30:24] Installation aborted
[10/18/2006 01:30:27] === Installation ended ===
我以为是光盘不行,就上网下了一个,但安装也不行
提示"已终止Autodesk 3DSMAX8安装,请检查"C:\Documents and Settings\llsheng\Local Settings\Temp\3dsMax8.log获取详细信息,
[10/18/2006 01:03:06] === Installation started on LLSHENG-MMPPL7V by llsheng ===
[10/18/2006 01:03:06] Installation started: MSI Runtime 3.1
[10/18/2006 01:03:06]   Command = "MSI\WindowsInstaller-KB893803-v2-x86.exe" /quiet /norestart
[10/18/2006 01:03:10] [Error: 1603] 安装时发生严重错误
[10/18/2006 01:03:10] Installation failed: MSI Runtime 3.1
[10/18/2006 01:03:10] Installation aborted
[10/18/2006 01:03:15] === Installation ended ===
请问各位MSI Runtime 3.1j是什么东东啊?这是怎么回事啊?是不是系统不行啊,刚重装的系统,急!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2006-10-29 16:52:34 | 显示全部楼层
我帮不了你,等高人吧
GMT+8, 2026-11-2 21:29 , Processed in 0.670878 second(s), 34 queries , Gzip On.
