查看: 991|回复: 2
[求助]:请问如何将图块中的不同图层统一?
发表于 2006-10-23 23:25:34 | 显示全部楼层 |阅读模式
想请教您一个问题
arx
如何将图中全部图块包含的所有的图层(一个图块有多个图层)
都改成某一个图层例如"0"层
(请给出实现这部分的具体代码)
谢谢!
发表于 2006-11-1 08:27:43 | 显示全部楼层
我也想知道,高手快来帮帮解决一下啊
发表于 2006-11-1 09:33:07 | 显示全部楼层
现成的代码
void test()
        // 得到层ID
        AcDbObjectId layerId;
        AcDbLayerTable *pLayerTbl = NULL;
        if (acdbHostApplicationServices()->workingDatabase()
                ->getLayerTable(pLayerTbl, AcDb::kForRead) != Acad::eOk)
                return;
        if (pLayerTbl->getAt("0", layerId) != Acad::eOk)
                pLayerTbl->close();
                return;
        pLayerTbl->close();
        // 打开块表进行操作
        Acad::ErrorStatus es;
        AcDbBlockTable *pBlockTable = NULL;
    es = acdbHostApplicationServices()->workingDatabase()
        ->getSymbolTable(pBlockTable, AcDb::kForRead);
        if (es != Acad::eOk) return;
        AcDbBlockTableIterator *pBlkIter = NULL;
        if (pBlockTable->newIterator(pBlkIter) != Acad::eOk)
                pBlockTable->close();
                return;
        // 遍历所有块表记录,找出插入快,设置新层
        AcDbBlockTableRecord *pRecord = NULL;
        AcDbBlockTableRecordIterator *pRcdIter = NULL;
        AcDbEntity *pEnt = NULL;
        AcDbObjectIdArray Ids;
        for (; !pBlkIter->done(); pBlkIter->step())
                if (pBlkIter->getRecord(pRecord, AcDb::kForWrite) != Acad::eOk)
                        continue;
                // 判断是否是插入块
                if (pRecord->getBlockReferenceIds(Ids) != Acad::eOk || Ids.length() == 0)
                        pRecord->close();
                        continue;
                if (pRecord->newIterator(pRcdIter) != Acad::eOk)
                        pRecord->close();
                        continue;
                // 遍历该块表记录,设置新层
                for (; !pRcdIter->done(); pRcdIter->step())
                        if (pRcdIter->getEntity(pEnt, AcDb::kForWrite) != Acad::eOk)
                                continue;
                        pEnt->setLayer(layerId);
                        pEnt->close();
                delete pRcdIter;
                pRcdIter = NULL;
                pRecord->close();
        delete pBlkIter;
        pBlkIter = NULL;
        acDocManager->sendStringToExecute(acDocManager->curDocument(), "regen ");
GMT+8, 2026-11-5 01:18 , Processed in 0.490727 second(s), 36 queries , Gzip On.
