查看: 815|回复: 0
[求助]:请帮帮看看我的代码问题出在那!
发表于 2006-11-21 08:15:40 | 显示全部楼层 |阅读模式
下面是一个根据数据库里主键值添加扩展数据的代码,它的运行结果总是满足不了要求.
请教高手们.
Private Sub kzsj(obj As AcadEntity, cn, dwname) '加扩展数据
Dim sjk As New ADODB.Recordset
Dim id As Long
id = 0
sjk.Open "select * from tysx order by cadid asc ", cn, adOpenDynamic, adLockReadOnly
Do While Not sjk.EOF
  id = sjk.Fields("cadid")
  sjk.MoveNext
Loop
sjk.Close
For Each obj In ThisDrawing.ModelSpace
Dim xtype As Variant
Dim xdata As Variant
obj.GetXData "", xtpye, xdata
If IsEmpty(xtype) Then '判断是否有扩展数据。(不知道我这里是不是运用的不对)
Dim datatype(0 To 7) As Integer
Dim data(0 To 7) As Variant
datatype(0) = 1001: data(0) = "tete"
datatype(1) = 1000: data(1) = dwname
datatype(2) = 1003: data(2) = "0"
datatype(3) = 1040: data(3) = 1.232
datatype(4) = 1041: data(4) = id + 1
datatype(5) = 1070: data(5) = 5656
datatype(6) = 1071: data(6) = 32332
datatype(7) = 1042: data(7) = 10
obj.SetXData datatype, data
id = id + 1
End If
Next obj
End Sub
GMT+8, 2026-11-22 10:16 , Processed in 0.334541 second(s), 12 queries , Gzip On, File On.
