查看: 1596|回复: 8
[求助]:请问怎样刷新一个层?
发表于 2006-11-23 16:47:10 | 显示全部楼层 |阅读模式
请问怎样刷新一个层?
发表于 2006-11-29 09:36:55 | 显示全部楼层
能具体些吗?你的刷新是什么意思?
 楼主| 发表于 2006-11-30 17:40:26 | 显示全部楼层
比如程序里修改了MText,我想mtext显示出最新值,但鼠标如果不点击modelspace,就显示不出来,该怎么做?
发表于 2006-12-3 12:34:47 | 显示全部楼层
这好像和刷新层没关系吧,楼主如果把代码贴出来可能会有人解释
发表于 2006-12-9 13:06:32 | 显示全部楼层
应该是刷新层中的实体
regen
参数:
layerId : 要重画的图层Id,默认为kNull,即重画全图
void Regen(AcDbObjectId layerId/* = AcDbObjectId::kNull*/)
        AcDbBlockTable *pBlockTable;
        AcDbEntity *pEntity;
        // Walk modelspace and tell all Entites to redraw themselves
        if (acdbCurDwg()->getBlockTable(pBlockTable, AcDb::kForRead) == Acad::eOk)
                AcDbBlockTableRecord* pBlockTableRecord;
                if (pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord, AcDb::kForRead) == Acad::eOk )
                        AcDbBlockTableRecordIterator *pBTRecordIterator;
                        if ( pBlockTableRecord->newIterator (pBTRecordIterator) == Acad::eOk )
                                for (pBTRecordIterator->start(); !pBTRecordIterator->done(); pBTRecordIterator->step ())
                                        if (pBTRecordIterator->getEntity(pEntity, AcDb::kForWrite) == Acad::eOk)
                                                if (layerId!= AcDbObjectId::kNull)
                                                        if (pEntity->layerId() == layerId)
        pEntity->recordGraphicsModified();
                                                else
                                                // close Entity
                                                pEntity->close();
                                if (pBTRecordIterator)
                                        delete (pBTRecordIterator);
                        pBlockTableRecord->close();
                pBlockTable->close();
        // worldDraw() called for all "dirty" entities
        actrTransactionManager->flushGraphics();
 楼主| 发表于 2006-12-12 10:34:45 | 显示全部楼层
xiexie!
发表于 2006-12-12 11:57:47 | 显示全部楼层
对单个实体进行刷新:
[PHP]void objRedraw(AcDbObjectId &objId)
        if(!objId.isValid())
                return;
        AcDbObject *pObj;
        AcDbEntity *pEnt;
        AcDbBlockTableRecord *pRec;
        AcDbObjectIdArray objs;
        BOOL bOk;
        if(acdbOpenAcDbObject(pObj,objId,AcDb::kForWrite)!=Acad::eOk)
                return;
        pEnt=AcDbEntity::cast(pObj);
        if(pEnt!=NULL)
                pEnt->recordGraphicsModified();
                pEnt->downgradeOpen();
                pEnt->draw();
                pEnt->close();
                return;
        pRec=AcDbBlockTableRecord::cast(pObj);
        if(pRec==NULL)
                pObj->close();
                return;
        bOk=(pRec->getBlockReferenceIds(objs)==Acad::eOk && objs.length()>0);
        pObj->close();
        if(!bOk)
                return;
        for(int i=0;i<objs.length();i++)
                objRedraw(objs);
}[/PHP]
刷新所有实体:
[PHP]void objRedraw()
        actrTransactionManager->queueForGraphicsFlush();
        acedUpdateDisplay();
}[/PHP]
发表于 2006-12-15 21:47:01 | 显示全部楼层
thx
发表于 2007-2-3 14:05:50 | 显示全部楼层
//刷屏操作(屏幕顯示更新)
GMT+8, 2026-11-3 01:32 , Processed in 0.747992 second(s), 48 queries , Gzip On.
