查看: 2011|回复: 4
标注后面加公差的LSP
发表于 2006-12-24 09:43:46 | 显示全部楼层 |阅读模式
在同一图纸公差不同,如(+0.15,+0.06)  (+0.15 ,--0.1)等等,求高手在标注后加公差的程序,运行后选择标注,直接输入上下偏差内容就好了,
有位高手编了个标注后加直径和半径的程序,共高人参考,我在线等待.
//加直径符号
(DEFUN C:PHI (/ PRE SS I ENT RR)
(SETQ PRE (IF (= (STRCASE (GETSTRING "\n加直径符号吗?") nil) "N") "R" "%%C"))
(PRINC "\n选择尺寸 : ")
(IF (SETQ SS (SSGET '((0 . "DIMENSION")))) (PROGN
  (SETQ I 0)
  (REPEAT (SSLENGTH SS)
   (SETQ ENT (ENTGET (SSNAME SS I)) I (1+ I))
   (SETQ RR (STRCAT PRE (CDR (ASSOC 1 ENT))))
   (SETQ ENT (SUBST (CONS 1 RR) (ASSOC 1 ENT) ENT))
   (ENTMOD ENT)
(PRINC)
发表于 2006-12-26 06:50:08 | 显示全部楼层
[php]
(defun c:test ()
  (setq up 0.15 lower 0.06);也可通过对话框或命令行随机输入
  (setq dd (ssget '((0 . "dimension"))))
  (setq n 0)
  (while (< n (sslength dd))
    (setq obj (vlax-ename->vla-object (ssname dd n)))
    (vla-put-toleranceupperlimit obj up)
    (vla-put-tolerancelowerlimit obj lower)
    (vla-put-tolerancedisplay obj 2)
    (vla-update obj)
    (setq n (1+ n))
[/php]
已领礼包: 12483个
发表于 2006-12-26 17:53:00 | 显示全部楼层
  1. (DEFUN C:TOLE ()
  2. (DEFUN RDATA () (SETQ PU (GET_TILE "pu") PD (GET_TILE "pd")))
  3. (SETQ FF (OPEN "INPUT.DCL" "w"))
  4. (WRITE-LINE "input : dialog {" FF)
  5. (WRITE-LINE " label="公差输入";" FF)
  6. (WRITE-LINE " : edit_box { key="pu"; label="上公差";value="+0.01";}" FF)
  7. (WRITE-LINE " : edit_box { key="pd"; label="下公差";value="-0.01";}" FF)
  8. (WRITE-LINE " ok_cancel;" FF)
  9. (WRITE-LINE "}" FF)
  10. (CLOSE FF)
  11. (IF (> (SETQ DCL_ID (LOAD_DIALOG "INPUT")) 0) (PROGN
  12.   (IF (NEW_DIALOG "input" DCL_ID) (PROGN
  13.    (action_tile "accept"  "(RDATA) (DONE_DIALOG 1)")
  14.    (action_tile "cancel" "(DONE_DIALOG 0)")
  15.    (SETQ RE (START_DIALOG))
  16.   ) (ALERT "Unable to display dialog box!"))
  17.   (UNLOAD_DIALOG DCL_ID)
  18. ) (ALERT "Unable to load dialog box!"))
  19. (IF (= RE 1) (PROGN
  20.   (PRINC "\n选择尺寸 : ")
  21.   (IF (SETQ SS (SSGET '((0 . "DIMENSION")))) (PROGN
  22.    (SETQ I 0)
  23.    (IF (AND (= (SUBSTR PU 1 1) "+") (= (SUBSTR PD 1 1) "-"))
  24.     (SETQ PRE (STRCAT "%%p" (SUBSTR PU 2)))
  25.     (SETQ PRE (STRCAT "\\S" PU "^" PD ";"))
  26.    )
  27.    (REPEAT (SSLENGTH SS)
  28.     (SETQ ENT (ENTGET (SSNAME SS I)) I (1+ I))
  29.     (SETQ RR (CDR (ASSOC 1 ENT)))
  30.     (SETQ RR (STRCAT (IF (= RR "") "<>" RR) PRE))
  31.     (SETQ ENT (SUBST (CONS 1 RR) (ASSOC 1 ENT) ENT))
  32.     (ENTMOD ENT)
  33.    )
  34.   ))
  35. ))
  36. (PRINC)
  37. )
已领礼包: 2个
发表于 2006-12-26 20:25:12 | 显示全部楼层
;;;大写看了眼睛疼,格式化一下
  1.   [FONT=courier new]
  2. (defun c:tole ()
  3.   (defun rdata ()
  4.     (setq pu (get_tile "pu")
  5.           pd (get_tile "pd")
  6.     )
  7.   )
  8.   (setq ff (open "INPUT.DCL" "w"))
  9.   (write-line "input : dialog {" ff)
  10.   (write-line " label="公差输入";" ff)
  11.   (write-line " : edit_box { key="pu"; label="上公差";value="+0.01";}"
  12.               ff
  13.   )
  14.   (write-line " : edit_box { key="pd"; label="下公差";value="-0.01";}"
  15.               ff
  16.   )
  17.   (write-line " ok_cancel;" ff)
  18.   (write-line "}" ff)
  19.   (close ff)
  20.   (if (> (setq dcl_id (load_dialog "INPUT"))
  21.          0
  22.       )
  23.     (progn
  24.       (if (new_dialog "input" dcl_id)
  25.         (progn
  26.           (action_tile "accept" "(RDATA) (DONE_DIALOG 1)")
  27.           (action_tile "cancel" "(DONE_DIALOG 0)")
  28.           (setq re (start_dialog))
  29.         )
  30.         (alert "Unable to display dialog box!")
  31.       )
  32.       (unload_dialog dcl_id)
  33.     )
  34.     (alert "Unable to load dialog box!")
  35.   )
  36.   (if (= re 1)
  37.     (progn
  38.       (princ "\n选择尺寸 : ")
  39.       (if (setq ss (ssget '((0 . "DIMENSION"))))
  40.         (progn
  41.           (setq i 0)
  42.           (if (and
  43.                 (= (substr pu 1 1) "+")
  44.                 (= (substr pd 1 1) "-")
  45.               )
  46.             (setq pre (strcat "%%p" (substr pu 2)))
  47.             (setq pre (strcat "\\S" pu "^" pd ";"))
  48.           )
  49.           (repeat (sslength ss)
  50.             (setq ent (entget (ssname ss i))
  51.                   i (1+ i)
  52.             )
  53.             (setq rr (cdr (assoc 1 ent)))
  54.             (setq rr (strcat (if (= rr "")
  55.                                "<>"
  56.                                rr
  57.                              ) pre
  58.                      )
  59.             )
  60.             (setq ent (subst
  61.                         (cons 1 rr)
  62.                         (assoc 1 ent)
  63.                         ent
  64.                       )
  65.             )
  66.             (entmod ent)
  67.           )
  68.         )
  69.       )
  70.     )
  71.   )
  72.   (princ)
  73. )
  74.   [/FONT]
 楼主| 发表于 2006-12-31 09:24:09 | 显示全部楼层
很感谢以上三位相助的kohi 会员/ zxq0220 会员 /taner会员,我下载了,回家试试看,                    2006年底
之后我试了,用把一个程序我改为用命令随机输入,缺点是:比如正负0.2,,结果是上面是+0.2下面是_0.2,不合标注要求,正确是正负号共用一个0.2就好,如果能提示(公差值一样请输C),输C后直接输入0.2更好
希望能修改一下
第二个可运行,但很错误,            2007年留言
GMT+8, 2026-11-3 11:32 , Processed in 0.459129 second(s), 40 queries , Gzip On.
