楼主: szx025
[求助] [求助]:在指定位置写出要求的文字
发表于 2007-3-12 21:39:02 | 显示全部楼层
28楼代码不错,辛苦了,只是还有两个小问题,直线可否像PLINE线一样连续绘出,箭头只有半边?
已领礼包: 2个
发表于 2007-3-13 14:27:14 | 显示全部楼层
根据31楼的要求,将28楼的代码修改后如下:
[PHP]
;;; zml84 于 2007-03-13  14:28
(defun C:test ()
    (if        (setq str (getstring "\n请输入文字<35>:"))
        (progn
            ;;从直线上偏移的距离
            (setq p 0.1)
            ;;箭头角度(弧度)
            (setq jt-jd 0.174532925199432957692369076848860)
            ;;箭头大小
            (setq jt-dx 0.5)
            (if        (= str "")
                (setq str (strcat "TB04-" "35"))
                (setq str (strcat "TB04-" str))
            (if        (setq pt1 (getpoint "\n指定起点:"))
                (while (setq pt2 (getpoint pt1 "\n指定下一点:"))
                    (setq ang (angle Pt1 Pt2)
                          pt3 (polar pt2 (+ (+ ang pi) jt-jd) jt-dx)
                          pt6 (polar pt2 (- (+ ang pi) jt-jd) jt-dx)
                    (if        (and (> ang (* 0.5 pi))
                             (< ang (* 1.5 pi))
                        (setq ang (- ang pi))
                    (setq pt4 (list (* 0.5 (+ (car pt1) (car pt2)))
                                    (* 0.5 (+ (cadr pt1) (cadr pt2)))
                          pt5 (polar pt4 (+ ang (* 0.5 pi)) p)
                    (setq ang (* (/ ang pi) 180.))
                    (command "_pline" pt1 pt2 pt3 pt2 pt6 "")
                    (command "text" "j" "c" pt5 "" ang str)
                    (setq pt1 pt2)
    (princ)
[/PHP]
发表于 2007-3-18 19:31:51 | 显示全部楼层
楼上的,太棒了!
zml84 可否跟进一下,箭头可否放在直线中间,且角的两边长度为0.6M,角度为60度?直线线宽为0.15。
已领礼包: 2个
发表于 2007-4-4 14:26:05 | 显示全部楼层
不能老是吃鱼
  1. ;;; zml84 于 2007-04-04  14:30
  2. (defun C:test ()
  3.   (if (setq str (getstring "\n请输入文字<35>:"))
  4.     (progn
  5.       ;;文字高度
  6.       (setq str-size 2.5)
  7.       ;;文字从直线上偏移的距离
  8.       (setq str-p 0.1)
  9.       ;;直线宽度
  10.       (setq line-k 0.15)
  11.       ;;箭头角度(弧度)
  12.       (setq jt-jd 60
  13.             jt-jd (* (/ jt-jd 360.) pi)
  14.       )
  15.       ;;箭头大小
  16.       (setq jt-size 0.6)
  17.       (if (= str "")
  18.         (setq str (strcat "TB04-" "35"))
  19.         (setq str (strcat "TB04-" str))
  20.       )
  21.       (if (setq pt1 (getpoint "\n指定起点:"))
  22.         (while (setq pt2 (getpoint pt1 "\n指定下一点:"))
  23.           (setq ang (angle Pt1 Pt2))
  24.           (if (and (> ang (* 0.5 pi))
  25.                    (< ang (* 1.5 pi))
  26.               )
  27.             (setq ang (- ang pi))
  28.           )
  29.           (setq        pt4 (list (* 0.5 (+ (car pt1) (car pt2)))
  30.                           (* 0.5 (+ (cadr pt1) (cadr pt2)))
  31.                     )
  32.                 pt5 (polar pt4 (+ ang (* 0.5 pi)) str-p)
  33.           )
  34.           (setq
  35.             pt6        (polar pt4 (+ (+ ang pi) jt-jd) jt-size)
  36.             pt7        (polar pt4 (- (+ ang pi) jt-jd) jt-size)
  37.           )
  38.           (setq ang (* (/ ang pi) 180.))
  39.           (command "_pline"         pt1        "w"    line-k ""     pt4
  40.                    "w"          0         ""        pt6    pt4    pt7    pt4
  41.                    "w"          line-k ""        pt2    ""
  42.                   )
  43.           (command "text" "j" "c" pt5 "" ang str)
  44.           (setq pt1 pt2)
  45.         )
  46.       )
  47.     )
  48.   )
  49.   (princ)
  50. )
发表于 2007-4-4 22:08:31 | 显示全部楼层
呵呵,就这一次啦,我已经在抽空学lisp 了,前段时间太忙,又需要这个,又没空研究这个,急,才找到这里的.想自己改又搞不定.总之非常感谢你啦,我一定认真学,争取有一天能帮别人解决问题.
GMT+8, 2026-11-7 13:06 , Processed in 0.369834 second(s), 34 queries , Gzip On.
