查看: 1606|回复: 1
[LISP程序]:字段(FIELD)的添加及取消
发表于 2007-2-8 11:11:49 | 显示全部楼层 |阅读模式
使用字段,直接附加文本1的内容到文本2,支持块内属性。
通过点取,直接将字段转换成普通文本,包括块内属性。
  1. (Defun c:AddCField (/ src tar)
  2.   (if (and (setq src (nentselp "\n Please pick the source annotation {Text or Attribute} [Exit]:"))
  3.            (setq src (vlax-ename->vla-object (car src)))
  4.            (vlax-property-available-p src "TextString")
  5.            (null (redraw (vlax-vla-object->ename src) 3))
  6.       )
  7.     (while (and        (setq tar (nentselp "\n Please pick the attached annotation {Text or Attribute} [Exit]:"))
  8.                 (setq tar (vlax-ename->vla-object (car tar)))
  9.                 (vlax-property-available-p tar "TextString")
  10.            )
  11.       (vla-put-textstring tar "AddCField")
  12.       (vla-put-textstring
  13.         tar
  14.         (strcat        "%<\\AcObjProp Object(%<\\_ObjId "
  15.                 (rtos (vla-get-objectid src) 2 0)
  16.                 ">%).TextString>%"
  17.         )
  18.       )
  19.       (command "_.Regen")
  20.     )
  21.   )
  22. )
  23. (Defun c:DelCField (/ tar txt)
  24.   (while
  25.     (and (setq tar (nentselp "\n Please pick the annotation to remove the field [Exit]:"))
  26.          (setq tar (vlax-ename->vla-object (car tar)))
  27.          (vlax-property-available-p tar "TextString")
  28.          (setq txt (vla-get-textstring tar))
  29.     )
  30.      (vla-put-textstring tar "DelCField")
  31.      (vla-put-textstring tar txt)
  32.   )
  33. )
因网络问题重复发的请斑竹删除:
http://www.xdcad.net/forum/showthread.php?s=&threadid=621814
已领礼包: 375个
发表于 2021-1-10 12:27:13 | 显示全部楼层
感谢楼主,为啥添加字段是###呢
GMT+8, 2026-11-3 15:15 , Processed in 0.492861 second(s), 34 queries , Gzip On.
