楼主: sony123
[讨论]:怎样快速获得图中的点的坐标
发表于 2007-2-22 21:09:02 | 显示全部楼层
11楼的兄弟程序贴了一半
俺帮他补全了
只是得到了坐标值
当然可以继续完善
[php]
(defun c:test (/ data ent long num p1 p2 ty xxx yyy zzz)
  (setq p1 (getpoint "选择左下角: "))
  (setq p2 (getcorner p1 "\n选择右上角: "))
  (setq ent (ssget "c" p1 p2 '((0 . "point"))))
  (if ent
    (progn
      (setq long (sslength ent))        ;计算选择集个数
      (setq num 0)
      (repeat long
        (setq ty (ssname ent num))        ;ssname 选择集索引值
        ;;根据索引值取出选择集中的对象名称
        (setq data (entget ty))
        (setq zzz (cadddr (assoc 10 data)))
        (setq xxx (car (cdr (assoc 10 data))))
        (setq yyy (cadr (cdr (assoc 10 data))))
        (setq num (1+ num))
        (princ "\n")
        (princ (list xxx yyy zzz))
      ) ;_ 结束repeat
    ) ;_ 结束progn
  ) ;_ 结束if
  (princ)
[/php]
程序运行结果如下
  1. 命令: test
  2. 选择左下角:
  3. 选择右上角:
  4. (202.939 136.996 0.0)
  5. (220.304 136.996 0.0)
  6. (215.067 130.112 0.0)
  7. (197.703 130.112 0.0)
  8. 命令:
复制代码
发表于 2007-2-25 23:35:39 | 显示全部楼层
输入的列表有错误,,,值得推敲哦!!
已领礼包: 2个
发表于 2007-3-5 18:45:46 | 显示全部楼层
试一试这个:
  1. (defun c:test (/ p1 p2 s1 num pt)
  2.         (if        (setq p1 (getpoint "选择左下角: "))
  3.                 (if        (setq p2 (getcorner p1 "\n选择右上角: "))
  4.                         (if        (setq s1 (ssget "c" p1 p2 '((0 . "point"))))
  5.                                 (progn
  6.                                         (setq num 0)
  7.                                         (repeat (sslength s1)
  8.                                                 (setq        pt   (cdr(assoc 10(entget (ssname s1 num)))))
  9.                                                         num  (1+ num))
  10.                                                 )
  11.                                                 (princ "\n")
  12.                                                 (princ pt)
  13.                                         ) ;_ 结束repeat
  14.                                 ) ;_ 结束progn
  15.                         )
  16.                 )
  17.         ) ;_ 结束if
  18.         (princ)
  19. )
GMT+8, 2026-10-18 09:57 , Processed in 0.468631 second(s), 30 queries , Gzip On.
