查看: 1232|回复: 4
[求助]:图块插入的问题
发表于 2007-4-6 12:15:23 | 显示全部楼层 |阅读模式
在插入块时.
如果当前文挡没有指定的块名
怎样做到像CAD名命令INSERT那样
没找到就搜索CAD的所有支持路径.
发表于 2007-4-9 15:05:45 | 显示全部楼层
当然可以啊
当然可以啊
 楼主| 发表于 2007-4-10 16:40:36 | 显示全部楼层
没有指定的块名时
那段程序怎么写?
发表于 2007-4-26 11:30:41 | 显示全部楼层
如果插入失败,你可以将条件转向其它路径的搜索,不可以吗?或者在插入前遍历块定义
发表于 2007-5-25 09:17:14 | 显示全部楼层
aAcDbObjectId CAdsGraphics::InsertBlock(LPCTSTR BlockName, CAdsPoint &BasePoint,ds_real Scale,ads_real Angle) const
//插入块
        AcDbObjectId ObjectId = GetBlockId(BlockName);
        if (ObjectId==AcDbObjectId::kNull)
                return AcDbObjectId::kNull;
        AcDbBlockReference *pBlkRef = new AcDbBlockReference(BasePoint,ObjectId);
        pBlkRef->setScaleFactors(AcGeScale3d(Scale,Scale,1.0));
        pBlkRef->setRotation(Angle);
        ObjectId = AcDbObjectId::kNull;
        ObjectId = AddEntity(pBlkRef);
    pBlkRef->close();
        return ObjectId;
AcDbObjectId CAdsGraphics::GetBlockId(LPCTSTR BlockName) const
        AcDbBlockTable *pBlockTable = NULL;
        AcDbDatabase *pDb = CUR_DB;
        pDb->getSymbolTable(pBlockTable,AcDb::kForWrite);
        if (pBlockTable==NULL)
        AcDbObjectId ObjectId=AcDbObjectId::kNull;
        if (pBlockTable->has(BlockName))
                pBlockTable->getAt(BlockName,ObjectId);
                pBlockTable->close();
                return ObjectId;
        CString FileName;
        CString strBlockName=BlockName;
        if (strBlockName.Right(4)!=".dwg")
                strBlockName+=".dwg";
        acedFindFile(strBlockName,FileName.GetBuffer(MAX_PATH));
        FileName.ReleaseBuffer();
        if (FileName.IsEmpty())
        AcDbDatabase *pDwg =new AcDbDatabase (Adesk::kFalse) ;
        if(Acad::eOk!=pDwg->readDwgFile (FileName))
        AcDbBlockTableIterator *pIterator=NULL;
        AcDbBlockTable *pDwgBlockTable = NULL;
        AcDbBlockTableRecord * pBlockTableRecord = NULL;
        if (Acad::eOk!=pDwg->getBlockTable(pDwgBlockTable,AcDb::kForWrite))
                delete pDwg;
        //遍历所有发表块表记录,把所有相同的块删除
        pDwgBlockTable->newIterator(pIterator);
        for (pIterator->start();!pIterator->done();pIterator->step())
                if (Acad::eOk!=pIterator->getRecord(pBlockTableRecord,AcDb::kForWrite))
                        pDwgBlockTable->close();
                        delete pDwg;
                LPSTR pName = NULL;
                pBlockTableRecord->getName(pName);
        CString sName=pName;
                delete pName;
        AcDbObjectId BlockId=pBlockTableRecord->id();
                if (pBlockTable->has(sName))
                        if (sName[0]!='*')
                                pBlockTableRecord->erase();
                pBlockTableRecord->close();
        CString strName(BlockName);
        if (strName.Right(4)==".dwg")
                int index=strName.ReverseFind('\\');
                strName=strName.Mid(index+1);
                strName=strName.Left(strName.GetLength()-4);
        if (Acad::eOk!=pDb->insert(ObjectId,_T(strName),pDwg))
                delete pDwg;
        delete pDwg;
        return ObjectId;
AcDbObjectId CAdsGraphics::AddEntity(AcDbEntity * pEnt ,
        BOOL bInit /*= TRUE */,
        AcDbDatabase* pDb /*= NULL */,
        BOOL bClose /*= FALSE */ ) const
        AcDbObjectId idNew=AcDbObjectId::kNull;
        AcDbBlockTableRecord *pRecord=NULL;
        if(pDb==NULL)
                pRecord = GetBlockTableRecord();
        else
                AcDbBlockTable *pTable=NULL;
                pDb->getBlockTable(pTable, AcDb::kForRead);
                if(pTable==NULL)
                        return idNew;
                pTable->getAt(ACDB_MODEL_SPACE,pRecord,AcDb::kForWrite);
                pTable->close();
                if(pRecord==NULL)
                        return idNew;
        if (bInit)
                pEnt->setColor(m_Color);
                pEnt->setLayer(m_Layer);
                pEnt->setLinetype(m_LineType);
        pRecord->appendAcDbEntity(idNew,pEnt);
        pRecord->close();
        if(bClose)
                pEnt->close();
        return idNew;
GMT+8, 2026-11-4 04:22 , Processed in 0.546089 second(s), 37 queries , Gzip On.
