查看: 1175|回复: 1
[编程申请]:求LSP程序,将选定的块各自以插入点为原点旋转40度,谢谢。
发表于 2007-4-17 16:52:37 | 显示全部楼层 |阅读模式
发表于 2007-4-17 23:12:42 | 显示全部楼层
(defun c:test(/ ss pt s1)
   (setvar "osmode" 0)
   (setq ss (ssget)
     i -1
   (while (setq s1 (ssname ss (setq i (1+ i))))
        (setq pt (cdr (assoc 10 (entget s1))))
        (command "rotate" s1 "" pt "40")
     (princ)
GMT+8, 2026-11-2 23:11 , Processed in 0.529068 second(s), 34 queries , Gzip On.
