查看: 1008|回复: 0
[ARX程序]:C#代码forCAD2007-2008 抛砖引玉,望大家多发些代码来.
发表于 2007-5-11 10:13:40 | 显示全部楼层 |阅读模式
C#-add a new annotative scale
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.Internal;
namespace AnnotationScaling
  public class Commands
    [CommandMethod("ADS")]
    static public void addScale()
      Dcument doc =
        Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      try
        ObjectContextManager ocm =
          db.ObjectContextManager;
        if (ocm != null)
          // Now get the Annotation Scaling context collection
          // (named ACDB_ANNOTATIONSCALES_COLLECTION)
          ObjectContextCollection occ =
            ocm.GetContextCollection("ACDB_ANNOTATIONSCALES");
          if (occ != null)
            // Create a brand new scale context
            AnnotationScale asc = new AnnotationScale();
            asc.Name = "MyScale 1:28";
            asc.PaperUnits = 1;
            asc.DrawingUnits = 28;
            // Add it to the drawing's context collection
            occ.AddContext(asc);
      catch (System.Exception ex)
        ed.WriteMessage(ex.ToString());
    [CommandMethod("ATS")]
    static public void attachScale()
      Document doc =
      Transaction tr =
        doc.TransactionManager.StartTransaction();
      using (tr)
        PromptEntityOptions opts =
          new PromptEntityOptions("\nSelect entity: ");
        opts.SetRejectMessage(
          "\nEntity must support annotation scaling."
        opts.AddAllowedClass(typeof(DBText), false);
        opts.AddAllowedClass(typeof(MText), false);
        opts.AddAllowedClass(typeof(Dimension), false);
        opts.AddAllowedClass(typeof(Leader), false);
        opts.AddAllowdClass(typeof(Hatch), false);
        PromptEntityResult per = ed.GetEntity(opts);
        if (per.ObjectId != ObjectId.Null)
          DBObject obj =
            tr.GetObject(per.ObjectId, OpenMode.ForRead);
          if (obj != null)
            obj.UpgradeOpen();
            obj.Annotative = AnnotativeStates.True;
            ObjectContexts.AddContext(obj, occ.GetContext("1:1"));
            ObjectContexts.AddContext(obj, occ.GetContext("1:2"));
            ObjectContexts.AddContext(obj, occ.GetContext("1:10"));
            ObjectContext oc = occ.GetContext("MyScale 1:28");
            if (oc != null)
              ObjectContexts.AddContext(obj, oc);
        tr.Commit();
GMT+8, 2026-11-4 06:24 , Processed in 0.654083 second(s), 31 queries , Gzip On.
