查看: 1397|回复: 3
[求助] [求助]:请教 DXF的知识
发表于 2007-5-24 12:18:06 | 显示全部楼层 |阅读模式
我想建立一选择集,包含 颜色为蓝色和白色的文字,但是白色的文字颜色是随层的
用DXF (62 .  ) 没法选取??? 请教高手...
发表于 2007-5-24 13:00:07 | 显示全部楼层
颜色号(如果不是“随层”,则出现);零表示“随块”(可变的)颜色;256 表示“随层”;负值表示层已关闭(可选)
 楼主| 发表于 2007-5-24 17:13:30 | 显示全部楼层
楼上说的是空话呀,我也知道你说的,在DXF的参考里,
有人帮忙给出截取÷解决办法吗????
发表于 2007-5-24 19:20:52 | 显示全部楼层
[php]
(defun getcolor_sslist (var colorlist / ss slen i ss_list na col)
  (setq ss (ssget (list (cons 0 var))))
  (setq slen (- (sslength ss) 1))
  (setq i 0)
  (setq ss_list (ssadd))
  (while (<= i slen)
    (setq na (ssname ss i))
    (setq ent (entget na))
    (cond
      ((setq col (cdr (assoc 62 ent))))
      ((setq
         col (cdr (assoc 62 (tblsearch "layer" (cdr (assoc 8 ent)))))
    (foreach n colorlist
      (if (= col (nth (1- n) colorlist))
        (ssadd na ss_list)
    (setq i (+ i 1))
  ss_list
(defun c:test ()
  (setq var "*text")
  (setq colorlist (list 1 2))
  (setq ss (getcolor_sslist var colorlist))
  (command "._move" ss "")
  (princ)
[/php]
GMT+8, 2026-11-22 09:14 , Processed in 0.433617 second(s), 16 queries , Gzip On, File On.
